Snom M900 - Original 3cx Template seems to be defect
ckoster
13. Januar 2015
Hello,
we have just renewed our snom M700 to m900.
It is working fine but we have ERROR in 3cx Log and in snom900
The snom m900 Log says:
XmlParse warning: Tag <phone-settings>: not valid as parent to tag <firmware-settings> ]
M900-LOG:
loc3 .Info 2023-12-05T19:55:45.770Z 60 [ RemCfg: Attempting fetch of file: https://yyy.fff-zzzzzl.de:5001/provisioning/XXXXX/cfg0004FFFF ]
loc3 .Info 2023-12-05T19:55:45.770Z 114 [ GFT Task: Found 1 IP's for: YYY.FFF-ZZZZZl.de ]
loc0 .Info 2023-12-05T19:55:47.430Z 92 [ Statistics: ROS_0 mail queue new MAX 1 % ]
loc3 .Info 2023-12-05T19:55:57.650Z 60 [ RemCfg: File loaded successfully ]
loc3 .Info 2023-12-05T19:55:57.650Z 60 [ RemCfg: Detected XML file ]
loc3 .Info 2023-12-05T19:55:57.650Z 60 [ RemCfg: Redirection detected ]
loc7 .Warn 2023-12-05T19:55:57.650Z 95 [ XmlParse warning: Tag <phone-settings>: not valid as parent to tag <firmware-settings> ]
loc3 .Info 2023-12-05T19:55:57.650Z 60 [ RemCfg: Attempting fetch of file: https://yyy.fff-zzzzzl.de:5001/provisioning/XXXXX/cfg0004FFFF ]
loc3 .Info 2023-12-05T19:55:57.650Z 114 [ GFT Task: Found 1 IP's for: YYY.FFF-ZZZZZl.de ]
loc3 .Info 2023-12-05T19:56:06.520Z 60 [ RemCfg: File loaded successfully ]
loc3 .Info 2023-12-05T19:56:06.520Z 60 [ RemCfg: Detected XML file ]
loc7 .Warn 2023-12-05T19:56:06.520Z 95 [ XmlParse warning: Tag <phone-settings>: not valid as parent to tag <firmware-settings> ]
loc3 .Info 2023-12-05T19:56:06.520Z 60 [ RemCfg: Attempting fetch of file: https://yyy.fff-zzzzzl.de:5001/provisioning/XXXXX/cfg0004FFFF-0004FFFF ]
loc3 .Info 2023-12-05T19:56:06.520Z 114 [ GFT Task: Found 1 IP's for: YYY.FFF-ZZZZZl.de ]
loc3 .Info 2023-12-05T19:56:06.710Z 60 [ RemCfg: Error loading file ]
loc3 .Info 2023-12-05T19:56:06.710Z 60 [ RemCfg: Attempting fetch of file: https://yyy.fff-zzzzzl.de:5001/provisioning/XXXXX/cfg0004FFFF-firmware ]
loc3 .Info 2023-12-05T19:56:06.710Z 114 [ GFT Task: Found 1 IP's for: YYY.FFF-ZZZZZl.de ]
loc3 .Info 2023-12-05T19:56:07.770Z 60 [ RemCfg: Error loading file ]
loc3 .Info 2023-12-05T19:56:07.770Z 60 [ RemCfg: Provisioning completed ]
loc3 .Info 2023-12-05T19:56:07.770Z 60 [ UpdateAllTimestamps ]
loc3 .Info 2023-12-05T19:56:07.770Z 60 [ RemCfg: Attempting fetch of file: https://yyy.fff-zzzzzl.de:5001/provisioning/XXXXX/cfg0004FFFF_phonebook.xml ]
loc3 .Info 2023-12-05T19:56:07.770Z 114 [ GFT Task: Found 1 IP's for: ]
loc6 .Info 2023-12-05T19:56:07.970Z 76 [ Multi cell Enabled: FpIdx#000 FpName: aaaaaaM900-001 ]
loc6 .Info 2023-12-05T19:56:07.970Z 76 [ IP Multicast creating socket 224.1.2.0:49712 ]
loc6 .Info 2023-12-05T19:56:07.970Z 76 [ This base is ready to be Primary in a Chain ]
loc6 .Info 2023-12-05T19:56:07.970Z 76 [ This base cannot join into another chain cause it contain subscriber data. ]
loc6 .Info 2023-12-05T19:56:07.970Z 76 [ Default base station to be able to join into a chain ]
loc6 .Info 2023-12-05T19:56:07.970Z 76 [ Subscriber data: Accounts:8; Registered:5 ]
loc3 .Info 2023-12-05T19:56:08.270Z 42 [ Cloud Service: Broker address is not applied - Cloud Service is disabled ]
loc7 .Info 2023-12-05T19:56:08.270Z 42 [ DECT protocol activation delayed. Multi cell is enabled ]
loc0 .Info 2023-12-05T19:56:12.770Z 92 [ Statistics: ROS_1 mail queue new MAX 4 % ]
3CX-LOG:
  • Provisioning file /provisioning/XXXXX/cfg0004FFFF-firmware requested by 10.1.200.2 could not be generated
    3CX Template Parser ID: 30040 05.12.2023 20:31:00
  • Provisioning file /provisioning/XXXXX/cfg0004FFFF-cfg0004FFFFrequested by 10.1.200.2 could not be generated
Best wishes
Carsten
War die M900 schon eingerichtet? Ich würde die noch mal auf Werkseinstellungen setzen und erneut versuchen. Wir haben gerade erst über 60 solcher Basen eingerichtet ohne Probleme. Wo ist die 3CX installiert?
