3cx auf iPhone mit Easybell
Probleme mit der Konfiguration, hier die Eingaben: Wo ist der Fehler? Danke für einen Hinweis.
• Name: Configure a name to identify this account.
xxx
• Display Name: Enter your first and last name here. This is the name that other phones will see on their display.
xxx
• User: Enter the extension number or user ID (sometimes referred to as Extension number, SIP ID, Phone number, Account)
0049xxxxx oder 0049xxxxx @sip.easybell.de
• ID: Enter your Authentication ID (sometimes referred to as Auth ID, Authentication Name, User name, Authentication user name).
0049xxxxx
• Password: Specify your password in the ‘Password’ field.• c) If you want to connect to a VoIP Provider select SIP Account
xxxxxx
• In the Local PBX IP field enter the IP Address of your PBX or SIP Server example 192.168.1.15. If you are connecting 3CXPhone to a VoIP Provider you can skip this step.
• In the “External PBX IP” field, specify the domain name or the public IP of the SIP server (also referred to as registrar server or SIP registrar) of your VoIP Provider or VoIP PBX. For example, sip.myvoipprovider.net.
sip.easybell.de
• If your VoIP provider has given you a STUN server name, specify it in the “STUN Server” field here. If not, you can leave the STUN server entry as stun3.3cx.com
stun.easybell.de
• If your provider needs a proxy server enter the address in the Proxy field
sip.easybell.de
• Click DONE to create the connection profile. This new profile will be displayed in the “Profiles” page. Once you have logged in successfully, your user name will be shown at the top on the right hand side
hier ein beispiel für Sipgate, leite dieses doch mal ab
Account:
Display name: Dein Name
Credentials:
User: SIP-ID
Password: SIP-Passwort
Server settings:
Use as: SIP Account
Local PBX IP: (leer lassen)
External PBX IP: sipgate.de
PBX port: 5060
STUN Server: stun.sipgate.net:10000
Elison Santana
