3CX Phone System for Windows RC2 available
stefanw
16. Oktober 2014
3CX Assistant in a new jacket
We have added a bunch of new features to RC2 – little stuff but very handy. Probably the biggest visible change is the new look of 3CX Assistant – we’ve made it look more ‘universally appealing’. Other improvements:
Polycom Personal Directories are now provisioned.Improved Myphone interfaceAbility to trigger a call from the Extension status page in MyPhoneRemoved SIP AUTHENTICATION tab in the MyPhone page – Can be enabled from the global parameters page MYPHONESIPAUTHPhone book directories are now updated automatically each time an extension is added, Reeboot using SIP notify is possible for Snom, Linksys by commenting out reboot link in templateAdded support for G7Eleven VoIP providerImproved Inphonex and Voip Unlimited templatesFaxes can now be received from VoIP providers that correctly support T38 fax. (BroadVox and Nexvortex for now)Faxes can now be received behind NAT (documentation to be provided)
You can now provision your Polycom with the Personal Phone Directory
Ability to trigger a call from the Extension status page in MyPhone portal
Removed SIP AUTHENTICATION tab in the MyPhone page – Can be enabled from the global parameters page MYPHONESIPAUTH if needed
Remote reboot of phones using SIP notify is possible for Snom, Linksys by commenting out reboot link in template
Improved Inphonex and VoIP Unlimited templates
You can download 3Cx Phone System RC 2 here
https://www.3cx.com/downloads/3CXPhoneSystem8.exe
You can download 3CX Assistant here
https://www.3cx.com/downloads/3CXAssistantSetup_80.exe
We look forward to your feedback!
