Absence info in 3CX CTI
ManufacturerSame1870
14. September 2020
I have several users whose presence should be automatically updated in the 3CX client. The users have opened the Windows client or the web interface If a user leaves their workstation and locks their PC, the status should change to Absent. The user should be shown as offline when they shut down their PC.
I already know that in the 3cx client on Windows the status is automatically changed after a few minutes of inactivity. However, the status will not be changed when the program is closed or the PC is shut down. The user will then continue to be displayed as available.
Did the users also use the app on the phone?
yes the user also use the app on the phone?
Thats it.
You must change the status to "absent" before you shutdown the client, or inside the app.
But since people can forget their status to change, you can't rely on the system. The requirement would be that this happens automatically.
Thats not possible because the app is online. why should the system change the status, its still online.
And there is a big bug with the app.
Once registered, the app remains logged in and online. Even if the account is deactivated on the app or the app is deleted.
Thanks for the feedback.
The status of a user without a mobile app does not change even after the PC is shut down. So I don't think it's related with the mobile app.
