Anruf wird abgelehnt
Habe 2 x snom 870 und 1 x snom m9 an der 3cx hängen. Das snom 870 an meinem Platz nimmt keine Anrufe mehr an. Hier das Log seit dem ich den Server neu gestartet habe incl. einem missglückten internen Anruf von 102 -> 100. Telefon und Server schon mehrmals neu gestartet, will einfach nicht mehr.
18:50:59.072 [CM503008]: Call(1): Call is terminated
18:50:55.227 Session 128 of leg C:1.1 is confirmed
18:50:55.117 [CM503007]: Call(1): Device joined: sip:[email protected]:40600;rinstance=8f0f054c0254e0c3
18:50:55.117 [CM503007]: Call(1): Device joined: sip:[email protected]:2324;transport=udp;line=l9qmr4
18:50:55.117 [MS210005] C:1.1:Answer provided. Connection(proxy mode):192.168.2.1:7000(7001)
18:50:55.117 [MS210001] C:1.2:Answer received. RTP connection[unsecure]: 127.0.0.1:40610(40611)
18:50:55.117 Remote SDP is set for legC:1.2
18:50:55.117 [CM505001]: Ext.999: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Voice Mail Menu;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] PBX contact: [sip:[email protected]:5060]
18:50:55.117 [CM503002]: Call(1): Alerting sip:[email protected]:40600;rinstance=8f0f054c0254e0c3
18:50:54.930 [CM503025]: Call(1): Calling Ext:Ext.999@[Dev:sip:[email protected]:40600;rinstance=8f0f054c0254e0c3]
18:50:54.930 [MS210004] C:1.2:Offer provided. Connection(proxy mode): 127.0.0.1:7002(7003)
18:50:54.915 [CM503005]: Call(1): Forwarding: Ext:Ext.999@[Dev:sip:[email protected]:40600;rinstance=8f0f054c0254e0c3]
18:50:54.899 [CM503016]: Call(1): Attempt to reach "100" failed. Reason: Busy
18:50:54.899 [CM503014]: Call(1): No known route to target: "100"
18:50:54.868 [CM503010]: Making route(s) to "100"
18:50:54.852 [MS210000] C:1.1:Offer received. RTP connection: 192.168.2.32:52046(52047)
18:50:54.837 Remote SDP is set for legC:1.1
18:50:54.837 [CM505001]: Ext.102: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom-m9/9.1.75] PBX contact: [sip:[email protected]:5060]
18:50:54.821 [CM503001]: Call(1): Incoming call from Ext.102 to "100"
18:50:54.805 [CM500002]: Info on incoming INVITE:
INVITE sip:[email protected];user=phone SIP/2.0
Via: SIP/2.0/UDP 192.168.2.32:2324;branch=z9hG4bK-9fmfl9;rport=2324
Max-Forwards: 70
Contact: ;reg-id=1;+sip.instance=""
To: "100"
Call-ID: 5eygc1o1m5
CSeq: 14443 INVITE
Proxy-Authorization: Digest realm="3CXPhoneSystem",nonce="414d535c02b15c6e72:67fa77aa5a68774858b21d55c8961f5b",response="04b0dfc98c4fb340ece299038c4a32de",username="102",uri="sip:[email protected];user=phone",algorithm=MD5
Supported: 100rel, replaces, norefersub
User-Agent: snom-m9/9.1.75
Content-Length: 0
18:50:53.901 [CM504001]: Ext.101: new contact is registered. Contact(s): [sip:[email protected]:3072;line=ckfv1cpw/101]
18:50:51.732 Currently active calls [none]
18:50:21.546 Currently active calls [none]
18:49:51.360 Currently active calls [none]
18:49:21.174 Currently active calls [none]
18:48:50.988 Currently active calls [none]
18:48:48.633 [CM504001]: Ext.100: new contact is registered. Contact(s): [sip:[email protected]:3072;line=uk28i8lh/100]
18:48:23.049 [CM504001]: Ext.102: new contact is registered. Contact(s): [sip:[email protected]:2324;transport=udp;line=l9qmr4/102]
18:48:20.802 Currently active calls [none]
18:48:06.372 [CM504001]: Ext.MakeCall: new contact is registered. Contact(s): [sip:[email protected]:40600;rinstance=5dfb0f81c8131eb0/MakeCall]
18:48:06.294 [CM504001]: Ext.IVRForward: new contact is registered. Contact(s): [sip:[email protected]:40600;rinstance=027df6ad32c4f5cc/IVRForward]
18:48:06.294 [CM504001]: Ext.EndCall: new contact is registered. Contact(s): [sip:[email protected]:40600;rinstance=ba3529b397ca7606/EndCall]
18:48:06.279 [CM504001]: Ext.850: new contact is registered. Contact(s): [sip:[email protected]:40600;rinstance=373844fefd65ea03/850]
18:48:06.263 [CM504001]: Ext.999: new contact is registered. Contact(s): [sip:[email protected]:40600;rinstance=8f0f054c0254e0c3/999]
18:47:59.031 [CM504004]: Registration succeeded for: 10003@Fritzbox-71101375
18:47:58.978 [CM504004]: Registration succeeded for: 10002@Fritzbox-71101376
18:47:58.953 [CM504004]: Registration succeeded for: 10001@Fritzbox-71101378
18:47:58.879 [CM504004]: Registration succeeded for: 10000@Fritzbox-71101377
18:47:58.835 [CM504003]: Sent registration request for 10003@Fritzbox-71101375
18:47:58.773 [CM504003]: Sent registration request for 10002@Fritzbox-71101376
18:47:58.756 [CM504003]: Sent registration request for 10001@Fritzbox-71101378
18:47:58.695 [CM504003]: Sent registration request for 10000@Fritzbox-71101377
18:47:58.631 IP(s) added:[192.168.2.1]
18:47:57.296 [CM504001]: Ext.704: new contact is registered. Contact(s): [sip:[email protected]:40300;rinstance=4c2f290786b75387/704]
18:47:57.295 [CM504001]: Ext.703: new contact is registered. Contact(s): [sip:[email protected]:40300;rinstance=0f52c2fe52eb4b80/703]
18:47:57.295 [CM504001]: Ext.702: new contact is registered. Contact(s): [sip:[email protected]:40300;rinstance=36bf0392ff3637c5/702]
18:47:57.257 [CM504001]: Ext.701: new contact is registered. Contact(s): [sip:[email protected]:40300;rinstance=29b10546dc8daa28/701]
18:47:57.254 [CM504001]: Ext.700: new contact is registered. Contact(s): [sip:[email protected]:40300;rinstance=6da443004bf7afde/700]
18:47:57.122 [CM504001]: Ext.SP8: new contact is registered. Contact(s): [sip:[email protected]:40000;rinstance=eae61d7797518812/SP8]
18:47:57.122 [CM504001]: Ext.SP6: new contact is registered. Contact(s): [sip:[email protected]:40000;rinstance=e9424e2643ce96b2/SP6]
18:47:57.122 [CM504001]: Ext.SP4: new contact is registered. Contact(s): [sip:[email protected]:40000;rinstance=814f4575aed81e21/SP4]
18:47:57.069 [CM504001]: Ext.SP2: new contact is registered. Contact(s): [sip:[email protected]:40000;rinstance=dd4312da333bd3a8/SP2]
18:47:57.028 [CM504001]: Ext.SP0: new contact is registered. Contact(s): [sip:[email protected]:40000;rinstance=2f28e99cd84e68cd/SP0]
18:47:56.953 [CM504001]: Ext.*0: new contact is registered. Contact(s): [sip:*[email protected]:40000;rinstance=9654d9e07449051f/*0]
18:47:51.685 [CM504004]: Registration succeeded for: 10001@Fritzbox-71101378
18:47:51.558 [CM504008]: Fax Service: registered as sip:[email protected]:5060 with contact sip:[email protected]:5100;user=phone
18:47:51.446 [CM504004]: Registration succeeded for: 10003@Fritzbox-71101375
18:47:51.319 [CM504003]: Sent registration request for 10002@Fritzbox-71101376
18:47:50.938 [CM504003]: Sent registration request for 10003@Fritzbox-71101375
18:47:49.836 [EC200002]: Media server is connected: application:SRV01:0/MediaServer local:127.0.0.1:5482 remote:127.0.0.1:64170
18:47:49.665 [EC200004]: IVR server is connected: application:SRV01:0/IVRServer local:127.0.0.1:5482 remote:127.0.0.1:64166
18:47:48.854 [CM506002]: Resolved SIP external IP:port (94.218.46.70:63514) on Transport 192.168.2.1:5060
18:47:48.588 Transport [ V4 192.168.2.1:5060 UDP target domain=unspecified mFlowKey=776 ] is joined to SIP multicast group
18:47:48.588 [CM501006]: Default Local IP address: [192.168.2.1]
18:47:48.588 [CM501002]: Version: 9.0.13677.0
18:47:48.448 [EC200001]: Configuration server is connected: application:SRV01:5485/DBProvider local:127.0.0.1:64161 remote:127.0.0.1:5485
18:47:48.432 [CM501009]: License Info: Loaded Succeeded
1. Hast did DND Taste gedrückt am Snom 870?
2. Siehst du das Telefon in der "Telefon Übersicht?"
Liegt auf jeden Fall am SNOM. DND versehentlich gedrückt, oder Weiterleitung ohne Zielnummer drin.
Abgehende Gespräche funktionieren, unterstelle ich mal.
hatte ich überprüft, war nichts drin. Abgehende Gespräche gingen. Hatte das Snom auch mehrmals neu gestartet: keine Besserung.
Habe anschließend sowohl die Nebenstelle in der Telefonanlage als auch das snom selber neu eingerichtet. Dann funktionierte es.
Scheint irgendwas buggy zu sein. Welche 3CX Version setzt Du ein?
wenn du es nicht im Snom gedrückt hast hast du es ggf im Call Assistant gedrückt?
Das Syncen ist nicht von CA auf snom und zurück die können so alle den status durch die gegeb stellen.
Wähle einmal *60 von dem Telefon geht es dann weider?
Wie weiter oben schon erwähnt:
Hatte anschließend sowohl die Nebenstelle in der Telefonanlage als auch das snom selber neu eingerichtet. Dann funktionierte es.
as7h
