Anrufe klingeln, abheben nicht möglich, anrufen auch nicht möglich
mynameisdanio
29. August 2021
hallo alle zusammen! [CM503003]: Call(C:5): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminat
01.09.2021 13:33:17 - [CM503003]: Call(C:5): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5063
01.09.2021 13:32:53 - [CM503003]: Call(C:4): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5063
01.09.2021 13:29:56 - [CM506004]: STUN request to STUN server 77.237.51.83:3478 has timed out; used Transport: 0.0.0.0:5060/UDP fk=0 tgt=
01.09.2021 13:09:52 - There's another STUN server that resolves to the same IP: 54.37.20.144:3478/UNKNOWN_TRANSPORT fk=0 tgt=; ignored
01.09.2021 12:49:52 - [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
01.09.2021 12:29:52 - There's another STUN server that resolves to the same IP: 54.37.20.144:3478/UNKNOWN_TRANSPORT fk=0 tgt=; ignored
01.09.2021 12:09:52 - [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
01.09.2021 11:49:52 - There's another STUN server that resolves to the same IP: 54.37.20.144:3478/UNKNOWN_TRANSPORT fk=0 tgt=; ignored
01.09.2021 11:45:23 - [CM503003]: Call(C:3): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5063
01.09.2021 11:45:04 - [CM503003]: Call(C:2): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5063
01.09.2021 11:29:52 - [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
01.09.2021 11:09:52 - There's another STUN server that resolves to the same IP: 54.37.20.144:3478/UNKNOWN_TRANSPORT fk=0 tgt=; ignored
01.09.2021 10:49:52 - [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
etc etc
Das bekomm ich in den Logs, außerdem, kann ich keine Anrufe abheben oder andere anrufen. Wenn ich aber meine Nummer anrufe, klingelt es und wenn ich probiere abzuheben wird mir angezeigt:
"Answer not accepted".
Mein Provider ist Fairytel (fairytel.at).
Mfg
hast du ein dynamisches oder Static IP?
Was verwendest du hier um zu Telefonieren?
Hallo! Buh, dynamisch oder statisch, das weiß ich nicht genau. Die Telefonanlage wird aber auf Google Cloud gehostet. Vielleicht hilft das ja weiter?
Um zu telefonieren, habe ich den Webclient probiert.
Mfg
(@AristotelisK_3CX )
Das siehst du in der Managementkonsole unter Einstellungen >> Netzwerk.
Läuft der Firewall durch?
Das ist jetzt die Einstellung im Netzwerk Ding. Ich habe auch ein FirewallCheck gemacht und es war alles grün d.h. ok.
Leider konnte mir der Provider mit dieser Standard Email auch nicht helfen
Ich hab alles gemacht, was dort stand
Mfg
( @AristotelisK_3CX )
Hast du für deinen Provider ein Generic SIP-Trunk eingerichtet?
wupdie
