Danke für die schnelle Antwort:
Ich habe jetzt folgenden Test gemacht:
1. Anwahl ohne Vorwahl geht über DUS.Net. Nach 2,5sec klingelt es schon
2. Anwahl mit Vorwahl geht über 1und1. Es braucht über 10 sec bis es klingelt!!!
Was kann ich da machen? Ich möchte aus Kostengründen bei 1und1 bleiben. Muß ich da etwas an der Konfiguration ändern?
22:28:34.093 [MS105000] C:18.1: No RTP packets were received:remoteAddr=192.168.1.51:40010,extAddr=0.0.0.0:0,localAddr=192.168.1.1:7034
22:28:34.093 [CM503008]: Call(18): Call is terminated
22:28:30.203 [CM505003]: Provider:[1und1] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:192.168.1.1:5060]
22:28:30.203 [MS210003] C:18.1:Answer provided. Connection(transcoding mode):192.168.1.1:7034(7035)
22:28:30.203 [MS210001] C:18.2:Answer received. RTP connection: 87.234.1.69:21918(21919)
22:28:30.203 Remote SDP is set for legC:18.2
22:28:30.203 [CM503002]: Call(18): Alerting sip:
[email protected]:5060
22:28:18.609 [MS210002] C:18.2:Offer provided. Connection(transcoding mode): 95.113.45.201:9034(9035)
22:28:17.468 [CM503004]: Call(18): Calling: VoIPline:07044930619@(Ln.10001@1und1)@[Dev:sip:
[email protected]:5060]
22:28:17.421 [CM503010]: Making route(s) to
22:28:17.421 [MS210000] C:18.1:Offer received. RTP connection: 192.168.1.51:40010(40011)
22:28:17.421 Remote SDP is set for legC:18.1
22:28:17.421 [CM505001]: Ext.46: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CXVoipPhone;Rev: 1] Capabilities:[reinvite, replaces, unable-no-sdp, recvonly] UserAgent: [3CXVoipPhone 3.1.6288.0] Transport: [sip:192.168.1.1:5060]
22:28:17.406 [CM503001]: Call(18): Incoming call from Ext.46 to
22:28:17.406 [CM500002]: Info on incoming INVITE:
INVITE sip:
[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.51:57660;branch=z9hG4bK-d8754z-231bdb6afe09f362-1---d8754z-;rport=57660
Max-Forwards: 70
Contact:
To:
Call-ID: MWU0OTc2NjE4OWQ5MjA0MWI0NzlmYTI3MTJlNzdmNzA.
CSeq: 2 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO
Proxy-Authorization: Digest username="46",realm="3CXPhoneSystem",nonce="414d535c000a9ae116:be8bdd75adfa01886067c1ddf18a8dfa",uri="sip:
[email protected]:5060",response="040b6bb4ee066c08dad2f68e94b5d189",algorithm=MD5
Supported: replaces
User-Agent: 3CXVoipPhone 3.1.6288.0
Content-Length: 0
22:28:16.171 [CM504008]: Fax Service: registered as sip:
[email protected]:5060 with contact sip:
[email protected]:5100;user=phone
22:28:15.656 [CM506003]: Resolved SIP external IP
ort has changed to (95.113.45.201:61587) on Transport 192.168.1.1:5060
22:28:15.531 [CM506001]: STUN request to resolve SIP external IP
ort mapping is sent to STUN server 75.101.138.128:3478 over Transport 192.168.1.1:5060
22:27:29.218 [MS105000] C:17.1: No RTP packets were received:remoteAddr=192.168.1.51:40008,extAddr=0.0.0.0:0,localAddr=192.168.1.1:7032
22:27:29.218 [CM503008]: Call(17): Call is terminated
22:27:25.968 [CM505003]: Provider:[DUS_NET] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [SIP_GW_1.4.2.PL3 helios.dus.net] Transport: [sip:192.168.1.1:5060]
22:27:25.968 [MS210003] C:17.1:Answer provided. Connection(transcoding mode):192.168.1.1:7032(7033)
22:27:25.968 [MS210001] C:17.2:Answer received. RTP connection: 83.125.8.80:42220(42221)
22:27:25.968 Remote SDP is set for legC:17.2
22:27:25.968 [CM503002]: Call(17): Alerting sip:
22:27:25.343 [MS210002] C:17.2:Offer provided. Connection(transcoding mode): 95.113.45.201:9032(9033)
22:27:24.046 [CM503004]: Call(17): Calling: VoIPline:07044930619@(Ln.10004@DUS_NET)@[Dev:sip:
22:27:23.984 [CM503010]: Making route(s) to
22:27:23.984 [MS210000] C:17.1:Offer received. RTP connection: 192.168.1.51:40008(40009)
22:27:23.984 Remote SDP is set for legC:17.1
22:27:23.984 [CM505001]: Ext.46: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CXVoipPhone;Rev: 1] Capabilities:[reinvite, replaces, unable-no-sdp, recvonly] UserAgent: [3CXVoipPhone 3.1.6288.0] Transport: [sip:192.168.1.1:5060]
22:27:23.968 [CM503001]: Call(17): Incoming call from Ext.46 to
22:27:23.968 [CM500002]: Info on incoming INVITE:
INVITE sip:
Via: SIP/2.0/UDP 192.168.1.51:57660;branch=z9hG4bK-d8754z-7a4628735d56366a-1---d8754z-;rport=57660
Max-Forwards: 70
Contact:
To:
Call-ID: MWM5NmM4YWJiYjhhOTQ3MTlhNmU4ZjQ1NGY0MmNkZGE.
CSeq: 2 INVITE
Proxy-Authorization: Digest username="46",realm="3CXPhoneSystem",nonce="414d535c000a9aab72:37c5b9cc934c3d578a2c6198c6e98e72",uri="sip:
[email protected]:5060",response="8ebfe1ae7a45cf92260c2542482a99e9",algorithm=MD5
Supported: replaces
Content-Length: 0
22:28:17.468 [CM503004]: Call(18): Calling: VoIPline:07044930610@(Ln.10001@1und1)@[Dev:sip:
INVITE sip:
Max-Forwards: 70
Contact:
To:
CSeq: 2 INVITE
Supported: replaces
Content-Length: 0
22:27:24.046 [CM503004]: Call(17): Calling: VoIPline:07044930610@(Ln.10004@DUS_NET)@[Dev:sip:
INVITE sip:
Max-Forwards: 70
Contact:
To:
CSeq: 2 INVITE
Supported: replaces
Content-Length: 0
