AVM Fritzbox cannot be connected to hosted 3CX
as seen on the screenshot I have tried to set up an extension in my FB.
It does not work.
I have tried anything. This is the log I receive:
15-Jan-2013 17:37:45.098 [IPBL] Packet from banned IP/range: ip = XXXXXXXXXXXXXX; Comment: PBX: blocked for too many failed authentications
15-Jan-2013 17:37:44.371 Blacklisted (Too many failed auth)
IP = 92.161.230.16; Failed auth: 5; unauth: 1; auth: 6; 407: 0
15-Jan-2013 17:37:43.738 [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from XXXXXXXXXXXXXXXXX:5060 tid=2C046B7BCC4A303F [email protected]:
REGISTER sip:xxxxxxxxxxxxxxx SIP/2.0
Via: SIP/2.0/UDP XXXXXXXXXXXXXXXXX:5060;rport=5060;branch=z9hG4bK2C046B7BCC4A303F
Max-Forwards: 70
Route:
To:
Call-ID: [email protected]
CSeq: 6 REGISTER
Accept: application/sdp, multipart/mixed
Accept-Encoding: identity
Allow: INVITE, ACK, OPTIONS, CANCEL, BYE, UPDATE, PRACK, INFO, SUBSCRIBE, NOTIFY, REFER, MESSAGE, PUBLISH
Proxy-Authorization: Digest username="vpbx101",realm="3CXPhoneSystem",nonce="414d535c070616b814:be83c23b33305b314cc82c29173a1fec",uri="sip:externalIP",response="82dc68ba4749a4694ceb6b49b6a6d00c",algorithm=MD5
Supported: 100rel, replaces
User-Agent: AVM FRITZ!Box Fon WLAN 7270 v2 54.05.06 (Sep 8 2011)
Allow-Events: telephone-event, refer, reg
Content-Length: 0
It seems that ID and Pasword are not OK. I have however checked the many many times and I have of course always deleted the banned IP Adress.
Thank you very much for the help.
With kind regards.
I.
You have to set the option "Internetrufnummer für die Anmeldung verwenden". That should be all. All other settings looks well.
Ok. Thank you. It was OK.
I.
sixdotfive
