ich habe ein snom870-SIP 8.4.31 als Nebenstelle an einer 3CX. Bei eingehenden Anrufen brechen die Gespräche im Moment des Hörerabhebens ab. Dies tritt nur bei einem Kommunikationspartner auf, der ebenfalls eine 3CX einsetzt. VoIP-Provider sind 1&1 und sipbase.
Log - Abbruch ganz am Ende:
10:02:24.263|.Call.cpp(48)|Log5||??:Currently active calls [none]
10:02:37.896|.CallLeg.cpp(124)|Log5||CallLeg:
nNewCall:[CM500002]: Info on incoming INVITE:
INVITE sip:[email protected]:5060;rinstance=61e32e19781adaea SIP/2.0
Via: SIP/2.0/UDP 212.227.67.135;branch=z9hG4bK540f.dd25b46c4561ca0791890520322a7d4f.0
Via: SIP/2.0/UDP 212.227.67.228;branch=z9hG4bK540f.6484aa95c88673eefd092abc77d8c076.0
Via: SIP/2.0/UDP 212.227.67.198;branch=z9hG4bK540f.d343410f3cfc1679f14c98f2d33712ce.0
Via: SIP/2.0/UDP 217.188.44.83;branch=z9hG4bK540f.06e93955.0
Via: SIP/2.0/UDP 195.71.188.9:5060;branch=z9hG4bK2mnn660020u0ts4vr6h1.1
Max-Forwards: 11
Record-Route:
Record-Route:
Record-Route:
Contact: "+493088667911"
To: "+493069545132"
Call-ID: 477f3d12-5d7a5688-4e1ae2a9-b0de@1und1-5.sip.mgc.voip.telefonica.de
CSeq: 1 INVITE
Session-Expires: 1800
Min-SE: 1800
Allow: INVITE, ACK, PRACK, SUBSCRIBE, BYE, CANCEL, NOTIFY, INFO, REFER, UPDATE
Supported: timer
P-Asserted-Identity: +493088667911
Content-Length: 0
10:02:37.898|.Line.cpp(301)|Log5||LineCfg::getInboundTarget:Looking for inbound target: called=+493069545132; caller=+493088667911
10:02:37.898|.Line.cpp(355)|Log2||LineCfg::getInboundTarget:[CM503012]: Inbound out-of-office hours rule (unnamed) for 10629 forwards to DN:120
10:02:37.951|.CallCtrl.cpp(271)|Log2||CallCtrl:
nIncomingCall:[CM503001]: Call(7): Incoming call from +493088667911@(Ln.10629@1+1 Kunden) to
10:02:37.954|.Line.cpp(1441)|Log2||Line:
rintEndpointInfo:[CM505003]: Provider:[1+1 Kunden] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:[email protected]:5060]
10:02:37.955|.CallLeg.cpp(1126)|Log5||CallLeg::setRemoteSdp:Remote SDP is set for legC:7.1
10:02:37.956|.SLServer.cpp(832)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210000] C:7.1:Offer received. RTP connection: 62.52.146.156:38788(38789)
10:02:37.956|.CallCtrl.cpp(441)|Log3||CallCtrl:
nSelectRouteReq:[CM503010]: Making route(s) to
10:02:37.957|.CallCtrl.cpp(606)|Log2||CallCtrl:
nSelectRouteReq:[CM503004]: Call(7): Route 1: Ext:Ext.120@[Dev:sip:[email protected]:5488,Dev:sip:[email protected]:3072;line=tj0wkgms,Dev:sip:[email protected]:5060;transport=udp;line=1wzf9f]
10:02:38.004|.SLServer.cpp(832)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210002] C:7.2:Offer provided. Connection(transcoding mode): 127.0.0.1:7016(7017)
10:02:38.005|.Target.cpp(437)|Log2||Target::makeOneInvite:[CM503025]: Call(7): Calling Ext:Ext.120@[Dev:sip:[email protected]:5488]
10:02:38.010|.SLServer.cpp(832)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210002] C:7.3:Offer provided. Connection(transcoding mode): 192.168.100.105:7018(7019)
10:02:38.012|.Target.cpp(437)|Log2||Target::makeOneInvite:[CM503025]: Call(7): Calling Ext:Ext.120@[Dev:sip:[email protected]:3072;line=tj0wkgms]
10:02:38.018|.SLServer.cpp(832)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210002] C:7.4:Offer provided. Connection(transcoding mode): 192.168.100.105:7020(7021)
10:02:38.020|.Target.cpp(437)|Log2||Target::makeOneInvite:[CM503025]: Call(7): Calling Ext:Ext.120@[Dev:sip:[email protected]:5060;transport=udp;line=1wzf9f]
10:02:38.153|.CallLeg.cpp(289)|Log3||CallLeg:
nAnswer:[CM503002]: Call(7): Alerting sip:[email protected]:3072;line=tj0wkgms
10:02:38.154|.Extension.cpp(1404)|Log3||Extension:
rintEndpointInfo:[CM505001]: Ext.120: Device info: Device Identified: [Man: Snom;Mod: 8xx series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom870/8.4.31] PBX contact: [sip:[email protected]:5060]
10:02:38.192|.CallLeg.cpp(289)|Log3||CallLeg:
nAnswer:[CM503002]: Call(7): Alerting sip:[email protected]:5060;transport=udp;line=1wzf9f
10:02:38.192|.Extension.cpp(1404)|Log3||Extension:
rintEndpointInfo:[CM505001]: Ext.120: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom-m9/9.3.9-a] PBX contact: [sip:[email protected]:5060]
10:02:38.207|.CallLeg.cpp(289)|Log3||CallLeg:
nAnswer:[CM503002]: Call(7): Alerting sip:[email protected]:5488
10:02:38.207|.Extension.cpp(1404)|Log3||Extension:
rintEndpointInfo:[CM505001]: Ext.120: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Dialer for Ext.120] PBX contact: [sip:[email protected]:5060]
10:02:38.407|.CallLeg.cpp(124)|Log5||CallLeg:
INVITE sip:[email protected]:5060;nofwd=1 SIP/2.0
Via: SIP/2.0/UDP 127.0.0.1:5488;branch=z9hG4bK-d8754z-9527994ce119bc5d-1---d8754z-;rport=5488
Max-Forwards: 70
Contact:
To:
Call-ID: ODg4MTM4Nzk1YmQ3NzIzZDc1ZDQzMDZiY2U4ZGU5NzM.
CSeq: 2 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
Proxy-Authorization: Digest username="120",realm="3CXPhoneSystem",nonce="414d535c0412329e18:0a5aee51c543fac6d0a5e208579ed565",uri="sip:[email protected]:5060;nofwd=1",response="615ee22c300629b5bd7727afb1b52802",algorithm=MD5
Supported: replaces
User-Agent: 3CX Dialer for Ext.120
Content-Length: 0
10:02:38.412|.CallCtrl.cpp(271)|Log2||CallCtrl:
nIncomingCall:[CM503001]: Call(8): Incoming call from Ext.120 to
10:02:38.418|.Extension.cpp(1404)|Log3||Extension:
10:02:38.418|.CallLeg.cpp(1126)|Log5||CallLeg::setRemoteSdp:Remote SDP is set for legC:8.1
10:02:38.420|.SLServer.cpp(832)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210000] C:8.1:Offer received. RTP connection: 127.0.0.1:32004(32005)
10:02:38.420|.CallCtrl.cpp(441)|Log3||CallCtrl:
10:02:38.421|.CallCtrl.cpp(606)|Log2||CallCtrl:
nSelectRouteReq:[CM503004]: Call(8): Route 1: VoIPline:01788442200@(Ln.10629@1+1 Kunden)@[Dev:sip:[email protected]:5060]
10:02:38.514|.SLServer.cpp(832)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210002] C:8.2:Offer provided. Connection(transcoding mode): 79.194.67.234:9014(9015)
10:02:38.514|.Target.cpp(437)|Log2||Target::makeOneInvite:[CM503025]: Call(8): Calling VoIPline:01788442200@(Ln.10629@1+1 Kunden)@[Dev:sip:[email protected]:5060]
10:02:41.118|.CallLeg.cpp(1126)|Log5||CallLeg::setRemoteSdp:Remote SDP is set for legC:7.3
10:02:41.119|.SLServer.cpp(832)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210001] C:7.3:Answer received. RTP connection[unsecure]: 192.168.100.220:65072(65073)
10:02:41.121|.SLServer.cpp(832)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210003] C:7.1:Answer provided. Connection(transcoding mode[unsecure]):79.194.67.234:9012(9013)
10:02:41.124|.CallCtrl.cpp(782)|Log2||CallCtrl:
nLegConnected:[CM503007]: Call(7): Device joined: sip:[email protected]:5060
10:02:41.127|.CallCtrl.cpp(782)|Log2||CallCtrl:
nLegConnected:[CM503007]: Call(7): Device joined: sip:[email protected]:3072;line=tj0wkgms
10:02:41.228|.CallLeg.cpp(300)|Log2||CallLeg:
nFailure:[CM503003]: Call(7): Call to sip:[email protected] has failed; Cause: 487 Request Terminated; from IP:192.168.100.230:5060
10:02:41.322|.CallLeg.cpp(300)|Log2||CallLeg:
nFailure:[CM503003]: Call(7): Call to sip:[email protected] has failed; Cause: 487 Request Terminated; from IP:127.0.0.1:5488
10:02:41.337|.Call.cpp(1293)|Log2||Call::Terminate:[CM503008]: Call(8): Call is terminated
10:02:41.338|.CallLeg.cpp(564)|Log5||CallLeg:
nConfirmed:Session 16400 of leg C:7.1 is confirmed
10:02:41.403|.CallLeg.cpp(1126)|Log5||CallLeg::setRemoteSdp:Remote SDP is set for legC:7.1
10:02:41.404|.SLServer.cpp(832)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210000] C:7.1:Offer received. RTP connection: 62.52.146.156:38788(38789)
10:02:41.405|.SLServer.cpp(832)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210002] C:7.3:Offer provided. Connection(transcoding mode): 192.168.100.105:7018(7019)
10:02:41.466|.Call.cpp(1293)|Log2||Call::Terminate:[CM503008]: Call(7): Call is terminated
10:02:42.850|.SLServer.cpp(800)|Error1|MediaServer|MediaServerReporting::RTPReceiver:[MS105000] C:7.1: No RTP packets were received:remoteAddr=62.52.146.156:38788,extAddr=79.194.67.234:9012,localAddr=79.194.67.234:9012
Max-Forwards: 11
Record-Route:
Record-Route:
Record-Route:
To: "+493069545132"
CSeq: 1 INVITE
Min-SE: 1800
Supported: timer
Content-Length: 0
Max-Forwards: 70
Contact:
To:
CSeq: 2 INVITE
Supported: replaces
Content-Length: 0
