Exchange GAL Sync geht nicht
bonow
30. August 2019
folgendes Setup:
Exchange 2016 CU11
3CX V16 auf Windows Basis
Die Synchronisation der Adressbücher ist eingerichtet, aber es werden nur die persönlichen Adressbücher gesynct, die GAL leider nicht. Im Log sind auch keine Fehler zu finden:
2019/08/30 07:10:15.750|2104|0023|Info|Synchronization of GAL started...
2019/08/30 07:10:15.760|2104|0023|Info|Synchronization of public folders started...
2019/08/30 07:10:15.762|2104|0023|Info|No Public Folders configured for sync
2019/08/30 07:10:15.778|2104|0023|Info|Synchronization of personal contacts started...
2019/08/30 07:10:15.861|2104|0023|Info|Synchronization from personal addressbook(xx) for extension 06 started...
2019/08/30 07:10:16.146|2104|0023|Info|WM: getserversettings for command 1 completed successfully
2019/08/30 07:10:16.147|2104|0004|Info|WM: Requesting extensionstate for command 2
2019/08/30 07:10:16.441|2104|0005|Info|Autodiscover succeeded
2019/08/30 07:10:16.610|2104|0024|Info|WM: extensionstate for command 2 completed successfully
2019/08/30 07:10:16.612|2104|0023|Info|Synchronization from personal addressbook(xx) for extension 06 finished(3 contacts)...
2019/08/30 07:10:16.614|2104|0004|Info|WM: Requesting savemeeting for command 3
2019/08/30 07:10:16.635|2104|0023|Info|Synchronization from personal addressbook(xx) for extension 01 started...
2019/08/30 07:10:16.766|2104|0023|Info|Synchronization from personal addressbook(xx) for extension 01 finished(69 contacts)...
2019/08/30 07:10:16.766|2104|0023|Info|Synchronization from personal addressbook(xx) for extension 03 started...
2019/08/30 07:10:16.808|2104|0023|Info|WM: savemeeting for command 3 completed successfully
2019/08/30 07:10:17.586|2104|0005|Info|Synchronization from personal addressbook(xx) for extension 03 finished(1042 contacts)...
2019/08/30 07:10:17.586|2104|0005|Info|Synchronization from personal addressbook(xx) for extension 02 started...
2019/08/30 07:10:17.725|2104|0005|Info|Synchronization from personal addressbook(xx) for extension 02 finished(224 contacts)...
2019/08/30 07:10:17.725|2104|0005|Info|Synchronization from personal addressbook(xx) for extension 05 started...
2019/08/30 07:10:17.819|2104|0024|Info|Synchronization from personal addressbook(xx) for extension 05 finished(69 contacts)...
2019/08/30 07:10:17.822|2104|0024|Info|Sync-Job execution finished on: 30.08.2019 07:10:17 taking 2,0782583 seconds
Bitte um Unterstützung.
Danke
Von den logs her erkennen ich dass du vom Exchange Server eine Meldung bekommst dass ein Public Ordner nicht eingerichtet wurde.
Hats du alles nach anleitung eingerichtet?
Ja, habe ich. Nur verstehe ich nicht, warum ich einen Public Folder angeben muss, wenn ich die GAL (Global Adressliste) vom Exchange Server syncen will. Was muss bei den Public Foldern eingetragen werden, damit die GAL gesynct wird?
