FAX bricht nach dem ersten Verbinden sofort ab
Hallo Leute,
als mit dem Fax zeugs in 3cx das ist ein Kreuz :-(
Foldgende Konstellation:
Patton 4554 2 Lines Block 0-99
3cx Mini 4 Calls 8.0.10824.716
Telefone SNOM 320 + 370 gehen wunderbar.
Fax Brother an Fritzbox 7170 geht nicht, -> Fax wählt -> Verbindet und bei ersten quitschen kommt besetzt und nix geht.
Bei einen anderen Kunden geht es ohne Probleme.
Ich hoffe jemand kann mir helfen.
Gruß Mario
Log vom der 3cx
12:44:43.182 [CM503008]: Call(138): Call is terminated
12:44:42.400 Remote SDP is set for legC:138.1
12:44:41.260 Session 9025 of leg C:138.1 is confirmed
12:44:41.150 [CM503007]: Call(138): Device joined: sip:[email protected]:5060
12:44:41.135 [CM503007]: Call(138): Device joined: sip:[email protected]:5060;uniq=207DC1C474D3F779ED6ABAF5A73CC
12:44:41.135 [MS210007] C:138.1:Answer provided. Connection(by pass mode): 192.168.0.220:5094(5095)
12:44:41.135 [MS210001] C:138.2:Answer received. RTP connection[unsecure]: 192.168.0.220:5094(5095)
12:44:41.135 Remote SDP is set for legC:138.2
12:44:40.291 [CM503002]: Call(138): Alerting sip:[email protected]:5060
12:44:36.541 [CM503025]: Call(138): Calling Unknown:09535188467@(Ln.10000@4554)@[Dev:sip:[email protected]:5060]
12:44:36.541 [MS210006] C:138.2:Offer provided. Connection(by pass mode): 192.168.0.63:7078(7079)
12:44:36.525 [CM503004]: Call(138): Route 1: Unknown:09535188467@(Ln.10000@4554)@[Dev:sip:[email protected]:5060,Dev:sip:[email protected]:5062]
12:44:36.509 [CM503010]: Making route(s) to
12:44:36.509 [MS210000] C:138.1:Offer received. RTP connection: 192.168.0.63:7078(7079)
12:44:36.494 Remote SDP is set for legC:138.1
12:44:36.494 [CM505001]: Ext.10: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [AVM FRITZ!Box Fon WLAN 7170 29.04.80 (Jan 27 2010)] PBX contact: [sip:[email protected]:5060]
12:44:36.494 [CM503001]: Call(138): Incoming call from Ext.10 to
12:44:36.478 [CM500002]: Info on incoming INVITE:
INVITE sip:[email protected] SIP/2.0
Via: SIP/2.0/UDP 192.168.0.63:5060;rport=5060;branch=z9hG4bK3F20AC985AF26435
Max-Forwards: 70
Contact:
To:
Call-ID: 3C21595F9A2F4E5A @192.168.0.63
CSeq: 240 INVITE
Expires: 120
Accept: application/sdp, multipart/mixed
Accept-Encoding: identity
Allow: INVITE, ACK, OPTIONS, CANCEL, BYE, UPDATE, PRACK, INFO, SUBSCRIBE, NOTIFY, REFER, MESSAGE, PUBLISH
Proxy-Authorization: Digest username="10",realm="3CXPhoneSystem",nonce="414d535c0227ea9411:660d2078b18f3734b08fec8a479ee8b9",uri="sip:[email protected]",response="6507a41c41768e5903f78089a8b52349",algorithm=MD5
Supported: 100rel, replaces
User-Agent: AVM FRITZ!Box Fon WLAN 7170 29.04.80 (Jan 27 2010)
Allow-Events: telephone-event, refer
Content-Length: 0
X-Designated-Service: fax/t38
Config Patton
# For Patton SmartNode 4554 2-port BRI
# Supported firmware versions R5.x
# Author: Kevin Attard Compagno
# Contact: [email protected]
webserver port 80 language en
system
ic voice 0
system
clock-source 0 0
profile ppp default
profile call-progress-tone defaultDialtone
flush-play-list
play 1 1000 425 0
profile call-progress-tone defaultAlertingtone
flush-play-list
play 1 1000 425 -7
pause 2 4000
profile call-progress-tone defaultBusytone
flush-play-list
play 1 480 425 -7
pause 2 480
profile call-progress-tone defaultReleasetone
flush-play-list
play 1 240 425 -7
pause 2 240
profile call-progress-tone defaultCongestiontone
flush-play-list
play 1 240 425 -7
pause 2 240
profile tone-set default
profile voip default
codec 1 g711alaw64k rx-length 20 tx-length 20
codec 2 g711ulaw64k rx-length 20 tx-length 20
fax transmission relay t38-udp
profile pstn default
profile sip default
profile aaa default
method 1 local
method 2 none
context ip router
interface IF_IP_LAN
ipaddress 192.168.0.220 255.255.255.0
tcp adjust-mss rx mtu
tcp adjust-mss tx mtu
context cs switch
mapping-table calling-pi to calling-e164 MAP_REMOVE_BLANK_CALLERID
map restricted to ""
mapping-table calling-e164 to calling-e164 MAP_LEADING_ZERO
map (.%) to 01
mapping-table calling-e164 to calling-name MAP_CID_TO_CNAME
map (.%) to 1
complex-function MAPPING_INCOMING_CALLS
execute 1 MAP_REMOVE_BLANK_CALLERID
execute 2 MAP_LEADING_ZERO
routing-table called-e164 RT_ISDN_TO_SIP_0
route T2 dest-interface IF_SIP_0 MAPPING_INCOMING_CALLS
routing-table called-e164 RT_ISDN_TO_SIP_1
route T2 dest-interface IF_SIP_1 MAPPING_INCOMING_CALLS
interface isdn IF_ISDN_0
route call dest-table RT_ISDN_TO_SIP_0
user-side-ringback-tone
call-hold disable
interface isdn IF_ISDN_1
route call dest-table RT_ISDN_TO_SIP_1
call-hold disable
interface sip IF_SIP_0
bind context sip-gateway GW_SIP_0
early-connect
early-disconnect
route call dest-interface IF_ISDN_0
remote 192.168.0.221
address-translation outgoing-call request-uri user-part fix 10000 host-part to-header target-param none
address-translation incoming-call called-e164 request-uri
interface sip IF_SIP_1
bind context sip-gateway GW_SIP_1
early-connect
early-disconnect
route call dest-interface IF_ISDN_1
address-translation outgoing-call request-uri user-part fix 10001 host-part to-header target-param none
context cs switch
no shutdown
authentication-service AS_ALL_LINES
realm 1 3CXPhoneSystem
username 10000 password 10000
username 10001 password 10001
location-service LS_10000
domain 1 192.168.0.221
identity-group default
authentication outbound
authenticate 1 authentication-service AS_ALL_LINES username 10000
identity 10000
registration outbound
registrar 192.168.0.221
lifetime 300
register auto
location-service LS_10001
authenticate 1 authentication-service AS_ALL_LINES username 10001
identity 10001
lifetime 300
register auto
interface LAN
bind interface IF_IP_LAN context router port 5060
bind location-service LS_10000
no shutdown
interface LAN
bind interface IF_IP_LAN context router port 5062
bind location-service LS_10001
no shutdown
port ethernet 0 0
encapsulation ip
bind interface IF_IP_LAN router
no shutdown
port bri 0 0
clock auto
encapsulation q921
q921
protocol pp
uni-side auto
encapsulation q931
q931
protocol dss1
uni-side user
encapsulation cc-isdn
bind interface IF_ISDN_0 switch
port bri 0 0
no shutdown
port bri 0 1
clock auto
encapsulation q921
q921
protocol pp
uni-side auto
encapsulation q931
q931
protocol dss1
uni-side user
bind interface IF_ISDN_1 switch
port bri 0 1
no shutdown
Welche Firmware läuft auf dem Patton? Am Brother auch mal versuchen den Kompatibiltätsmodus zu aktivieren. Ist bei vielen Brothergeräten möglich. Und Geschwindigkeit auf 14 setzen.
R5.4 2010-03-15 SIP
Um alle Fehlerquellen auszuschließen, würde ich zunächst der Firmware-Empfehlung von 3CX versuchen: https://www.3cx.de/topic/patton-info-firmware-stand-4-03-2010/
Sollte es dann immer noch nicht gehen, auch noch mal die Fritzbox auf die neuste Firmware aktualisieren.
Zunächst aber vielleicht noch mal prüfen, ob für die Nebenstelle Re-Invite und Replaces aktiviert ist.
geht nicht Box sagt das das Image nicht dafür paßt.
Patton? Hier auch auf die Hardwareversion achten!
Ich habe leider das gleiche Problem !
Habe ein Faxgerät an den Patton Smartlink M-ATA angeschlossen.
Dafür gibt es scheinbar auch nur eine Firmware.
Es kommt ja in erster Linie auf das Zusammenspiel mit dem Gateway zur Außenwelt an. Welches hast Du denn?
hier war das Problem das die FB und das Patton in 5ms unterschied das Re-Invite auf T38 geschickt haben.
Das führt dann zu einem "DeadLock" denn was wurde denn nun zuerstgeschickt? Also nicht angekommen an der PBX durch Dalay und etc. Das Patton wollte dann nicht die FB verstehen und vice versa...
Aber M-Ata in der letzte FW geht es dann auch mit Patton.
Aber Bero ist da doch was stabiler..
Danke für die Info. Wodurch kam es denn zu dem Delay, konntet ihr das herausfinden?
Bei mir geht das auch intern nicht. Da spielt also noch gar kein Gateway mit oder ?
M-ATA Version
Application Code Version: SIP version 4.01.001 OE EN MA (0309)
Downloader Code Version: 3.1 EN (OEMA 011103)
auch mit gesetztem Fax without T.38 geht es nicht.
Habe auch ein Linksys PAP2T auch mit dem kein Erfolg
Das M-ATA Teil hab ich dann extra wegen T38 gekauft weil das das Linksys nicht kann
Hallo wks,
ich hatte das gleiche Problem mit dem Linksys PAP2 aber auch die Frizbox 7170 mit neuester Firmware ging nicht.
Jedesmal brach sofort bei übertragen des ersten Tons die Verbindung wieder ab.
Ich denke es liegt am Patton 4554 da bei anderen Kunden mit gleicher Konfig die das Patton 4638 haben geht es ohne Probleme.
Ich habe es nun so gelößt, Patton 4554 neueste Firmware http://upgrades.patton.com/license.asp?model=SmartNode 4554&path=SN4554_SIP_R5.5_2010-05-18.zip
Dann aufs Patton M-ATA auch die neueste ist vom 1. Juni 2010!! Die muss drauf wegen dem ReInvite bei t38.
http://upgrades.patton.com/license.asp?model=M-ATA&path=MATA_1213.zip
Das M-ATA läßt sich nur per TFTP Server upgraden ich nehm immer den pumkin gibts hier http://kin.klever.net/pumpkin/
Und dann gibt es eine 3cx Wiki Seite fürs M-ATA dann ging es bei mir sofort und wie geschmiert senden sowie empfang.
Google 3cx patton m-ata
Gruß Mario
Hallo Mario vielen Dank für deine Antwort
Leider hatte ich damit keinen Erfolg.
Das Fax wird bei mir innerhalb meines Netzwerkes vom MATA auf den Faxserver am 3CX Server geschickt.
Den M-ATA Adapter habe ich laut der 3CX Wiki eingestellt
Hier ein Auszug aus dem Faxserver Log :
11:46:51.532|4400|(0):FAXServer,
Local Media IP address = [192.168.120.20] (10002)
Media Audio (G.711 Mu Law - G.711 A Law)
11:46:51.767|4400|(0):FAXServer,
(nai 0, conn_id 20) SSC Evt: Receive SSC_INVITE_CO (Ret code: (100) SIP_RET_TRYING (100 Trying))
11:46:52.079|4400|(0):FAXServer,
(nai 0, conn_id 20) SSC Evt: Receive SSC_INVITE_CO (Ret code: (180) SIP_RET_RINGING (180 Ringing))
11:46:54.143|4400|(0):FAXServer,
(nai 0, conn_id 20) SSC Evt: Receive SSC_INVITE_CO (Ret code: (200) SIP_RET_SUCCESS (200 OK))
(nai 0, conn_id 20) SSC Evt: Send SSC_ACK_RQ
11:46:55.143|4400|(0):FAXServer,
(nai 0, conn_id 20) SSC Evt: Send SSC_INVITE_RQ (re-invite)
Local Media IP address = [192.168.120.20] (10000)
Media T.38 (UDP (UDPTL))
T38FaxVersion : 0
T38MaxBitRate : 14400
T38FaxRateManagement : transferredTCF
T38FaxFillBitRemoval : OFF
T38FaxTranscodingMMR : OFF
T38FaxTranscodingJBIG : OFF
T38FaxMaxBuffer : 10500
T38FaxMaxDatagram : 1500
T38FaxUdpEC : t38UDPRedundancy
11:46:55.252|4400|(0):FAXServer,
11:46:55.456|4400|(0):FAXServer,
>> Remote Media IP address = [192.168.120.203] (8000)
From remote T38FaxVersion : 0
From remote T38MaxBitRate : 14400
From remote T38FaxRateManagement : transferredTCF
From remote T38FaxFillBitRemoval : OFF
From remote T38FaxTranscodingMMR : OFF
From remote T38FaxTranscodingJBIG : OFF
From remote T38FaxMaxBuffer : 400
From user (missing) T38FaxMaxDatagram : 1024
From user (missing) T38FaxUdpEC : t38UDPRedundancy
Session activated (NAI) = 1
(nai 1) Start T.38 session [User info: nai 1 Session cnt 1 Batch cnt 8] (Snd Fax) (UDP)
---- Error (Nai #01)
Error reported thru T38__SET_CONFIG_CO (nai = 1)
error source = (238) FOIP__START_ERR_SRC__T38_SESSION_CONFIG, Process: Session Configuration of T.38 entity (T38__SET_CONFIG_RQ (T38__SESSION_CNF))
error code = (111) T38__CFG_ERR_T38_CAP__2_FAX_MAX_BUFFER_SIZE, T38__cap__fax_max_buffer_size < T38__cap__max_datagram_size
11:46:55.471|4400|(0):FAXServer,
Stop SIP session [User info: nai 1 Session cnt 1 Batch cnt 8]
(nai 0, conn_id 20) SSC Evt: Send SSC_CLOSE_SESSION_RQ
11:46:55.565|4400|(0):FAXServer,
Hallo wks,
dann hast Du wahrscheinlich das M-ATA eine Nebenstelle zugewiesen das eingehende Faxe von von FaxServer annehmen soll.
Das darf nicht sein!! Mit der Konfig kann man sich keien Faxe schicken, das ging bei mir auch nicht. Und kein Kunde macht auch das.
mach folgendes lege eine Nebenstelle an mit der du das M-ATA verbindest. eingehend wie ausgehend sollen an das M-ATA gesendet werden. Caller ID erstmal lehr lassen.
Dann probieren ob es geht und gebe bitte rückmeldung.
Welches Patton nimmst Du? Wie geschrieben sind die neuesten Firmware drauf?
Gruß Mario
Hallo Mario
Sorry war den ganzen Tag unterwegs.
Die M-ATA ist als normale Nebenstelle definiert an der ein Faxgerät angeschlossen ist.
(Telefonieren mit einem Analog Apperat funktioniert.
Zusätzlich ist am 3CX ein Faxserver installiert der auch Faxe empfangen kann und per Mail weiterleitet.
Funktioniert auch.
Ich wollte das erstmal im eigenen LAN testen um Providerprobleme und Firewall auszuschließen.
Anbindung an extern erfolgt über SIP Trunk zu Inode.
Ein Patton 4554 ist da nicht im Einsatz.
Ich müsste doch intern ebenfalls Faxe schicken können?? (In größeren Firmen kommt das oft vor.)
Hallo wks,
an der 3cx den Faxserver zusäzlich installiert? Der ist schon mit der Installation am start, da muss man nix installieren.
Du meinnt wahrscheinlich den FaxServer zu verschicken von Faxen von Rechner aus.
Du mußt mal das volle Debug log posten da steht mehr drinnen.
Das Fax Log ist nur bedingt aussagekräftig.
Gruß Mario
