Neue Version des Skype Gateways verfügbar
stefanw
16. Oktober 2014
Hallo Forum,
das nächste Update des Skypegateways steht seit heute im Wiki zum Download bereit.
Change Log:
Version: 3CX Gateway for Skype V2.0.8743.23
The performance of this version has been improved significantly. It can now easily support up to 8 simultaneous Skype calls by using both CPU cores. Testing was done on a Pentium D 3.0 GHz, running Windows XP. Faster CPUs may increase the number of simultaneous calls that can be handled.
Fixed issue if computer account name prefix contained an uppercase character
Fixed an issue with a missing parameter in Secure RTP handling
Fixed caller-ID on inbound Skype calls - Skype name will be passed as caller ID to the phone
Fixed Stuck Call in PBX when restarting Gateway
Added: Support for DTMF codes
Added: Various SIP error codes when SIP an in/outbound call is dropped (terminated)
Added support for an inbound "From" prefix to match corresponding PBX outbound rule, allowing call back in case of a missed call
Added: Skype Client now uses all available Cores of a CPU
- Blog: https://www.3cx.com/blog/releases/3cx-gateway-sip-to-skype/
- Download: https://www.3cx.com/downloads/3CXGatewayforSkype2.msi
- Brief configuration guide: https://www.3cx.com/voip-gateways/skype.html
Ein schönes Wochenende wünsche ich beim Testen.
Mit besten Grüßen
