Das Server-Aktivitäten-Protokoll von der 3CX bei den Anrufen
Rufnummer1 = Welchen ich anrufen möchte
LokalPC = IP vom PC, welcher mittels 3CX Softphone anrufen will
RufnummerOhneNeb = Meine Rufnummer ohne Nebenstellenanhang
VodafoneServerIP = SBC_IP vom Vodafoneserver
PBX_IP = Die IP unserer Telefonanlage
MEINNAME = Mein Name laut Nebenstelle
24-Feb-2016 09:08:06.947 Leg L:19.2[Line:10000>>Rufnummer1] is terminated: Cause: BYE from PBX
24-Feb-2016 09:08:06.947 [CM503008]: Call(C:19): Call is terminated
24-Feb-2016 09:08:06.942 Leg L:19.1[Extn:20] is terminated: Cause: BYE from 127.0.0.1:32850
24-Feb-2016 09:08:02.177 Currently active calls - 1: [19]
24-Feb-2016 09:07:43.905 [CM503007]: Call(C:19): Line:10000>>Rufnummer1 has joined, contact <sip:RufnummerOhneNeb@VodafoneServerIP:5060>
24-Feb-2016 09:07:43.902 [CM503007]: Call(C:19): Extn:20 has joined, contact <sip:20@LokalPC:50195>
24-Feb-2016 09:07:43.900 L:19.2[Line:10000>>Rufnummer1] has joined to L:19.1[Extn:20]
24-Feb-2016 09:07:43.895 NAT/ALG check:L:19.2[Line:10000>>Rufnummer1] RESPONSE 200 on 'INVITE' - basic check passed. No information for extended checks
24-Feb-2016 09:07:43.895 [CM505003]: Provider:[Vodafone] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip
BX_IP:5060]
24-Feb-2016 09:07:39.350 [CM503025]: Call(C:19): Calling T:Line:10000>>Rufnummer1@[Dev:sip:RufnummerOhneNeb@VodafoneServerIP:5060] for L:19.1[Extn:20]
24-Feb-2016 09:07:39.349 [MS006000] C:19.2: connection address is enforced to PBX_IP
24-Feb-2016 09:07:39.342 [CM503027]: Call(C:19): From: Extn:20 ("MEINNAME" <sip:20@PBX_IP:5060>) to T:Line:10000>>Rufnummer1@[Dev:sip:RufnummerOhneNeb@VodafoneServerIP:5060]
24-Feb-2016 09:07:39.342 [CM503004]: Call(C:19): Route 1: from L:19.1[Extn:20] to T:Line:10000>>Rufnummer1@[Dev:sip:RufnummerOhneNeb@VodafoneServerIP:5060]
24-Feb-2016 09:07:39.342 Line limit check: Current # of calls for line Lc:10000(@Vodafone[<sip:RufnummerOhneNeb@VodafoneServerIP:5060>]) is 0; limit is 2
24-Feb-2016 09:07:39.342 Call(C:19): Call from Extn:20 to Rufnummer1 matches outbound rule 'Rule for Vodafone'
24-Feb-2016 09:07:39.340 [CM503001]: Call(C:19): Incoming call from Extn:20 to <sip:Rufnummer1@PBX_IP:5060>
24-Feb-2016 09:07:39.340 NAT/ALG check:L:19.1[Extn:20] REQUEST 'INVITE' - some of SIP/SDP headers may contain inconsistent information or modified by intermediate hop
3. Versuch, hier hat der Anruf funktioniert
SIP proxy detected:
Via:SIP/2.0/TCP 127.0.0.1:5080;branch=z9hG4bK-d8754z-Pj61f9447fd5fe4ac8aaf10cc359811133-2---d8754z-;rport=32850
Via:SIP/2.0/UDP 217.68.186.115:53583;branch=z9hG4bK-d8754z-tunneltid-1---d8754z-;rport;tnlid=clnt.1-0bc8950d351f4219b71b3c2ed6a5a486
Via:SIP/2.0/TCP LokalPC:50195;rport;branch=z9hG4bKPj61f9447fd5fe4ac8aaf10cc359811133;alias
24-Feb-2016 09:07:39.250 Leg L:18.1[Extn:20] is terminated: Cause: BYE from PBX
24-Feb-2016 09:07:39.242 [CM503020]: Call(C:18): Normal call termination. Call originator: Extn:20. Reason: No answer
24-Feb-2016 09:07:39.242 L:18.1[Extn:20] failed to reach Line:10000>>Rufnummer1, reason No Answer
24-Feb-2016 09:07:39.241 Leg L:18.2[Line:10000>>Rufnummer1] is terminated: Cause: 408 Request Timeout/INVITE from local
24-Feb-2016 09:07:39.241 Call to T:Line:10000>>Rufnummer1@[Dev:sip:RufnummerOhneNeb@VodafoneServerIP:5060] from L:18.1[Extn:20] failed, cause: Cause: 408 Request Timeout/INVITE from local
24-Feb-2016 09:07:39.236 [CM503003]: Call(C:18): Call to <sip:Rufnummer1@VodafoneServerIP:5060> has failed; Cause: 408 Request Timeout/INVITE from local
24-Feb-2016 09:07:32.162 Currently active calls - 1: [18]
2. Versuch
24-Feb-2016 09:07:08.202 Leg L:17.1[Extn:20] is terminated: Cause: BYE from PBX
24-Feb-2016 09:07:08.152 [CM503020]: Call(C:17): Normal call termination. Call originator: Extn:20. Reason: No answer
24-Feb-2016 09:07:08.152 L:17.1[Extn:20] failed to reach Line:10000>>Rufnummer1, reason No Answer
24-Feb-2016 09:07:08.152 Leg L:17.2[Line:10000>>Rufnummer1] is terminated: Cause: 408 Request Timeout/INVITE from local
24-Feb-2016 09:07:08.152 Call to T:Line:10000>>Rufnummer1@[Dev:sip:RufnummerOhneNeb@VodafoneServerIP:5060] from L:17.1[Extn:20] failed, cause: Cause: 408 Request Timeout/INVITE from local
24-Feb-2016 09:07:08.146 [CM503003]: Call(C:17): Call to <sip:Rufnummer1@VodafoneServerIP:5060> has failed; Cause: 408 Request Timeout/INVITE from local
24-Feb-2016 09:07:07.186 [CM503025]: Call(C:18): Calling T:Line:10000>>Rufnummer1@[Dev:sip:RufnummerOhneNeb@VodafoneServerIP:5060] for L:18.1[Extn:20]
24-Feb-2016 09:07:07.185 [MS006000] C:18.2: connection address is enforced to PBX_IP
24-Feb-2016 09:07:07.137 [CM503027]: Call(C:18): From: Extn:20 ("MEINNAME" <sip:20@PBX_IP:5060>) to T:Line:10000>>Rufnummer1@[Dev:sip:RufnummerOhneNeb@VodafoneServerIP:5060]
24-Feb-2016 09:07:07.137 [CM503004]: Call(C:18): Route 1: from L:18.1[Extn:20] to T:Line:10000>>Rufnummer1@[Dev:sip:RufnummerOhneNeb@VodafoneServerIP:5060]
24-Feb-2016 09:07:07.137 Line limit check: Current # of calls for line Lc:10000(@Vodafone[<sip:RufnummerOhneNeb@VodafoneServerIP:5060>]) is 1; limit is 2
24-Feb-2016 09:07:07.137 Call(C:18): Call from Extn:20 to Rufnummer1 matches outbound rule 'Rule for Vodafone'
24-Feb-2016 09:07:07.135 [CM503001]: Call(C:18): Incoming call from Extn:20 to <sip:Rufnummer1@PBX_IP:5060>
24-Feb-2016 09:07:07.135 NAT/ALG check:L:18.1[Extn:20] REQUEST 'INVITE' - some of SIP/SDP headers may contain inconsistent information or modified by intermediate hop
SIP proxy detected:
Via:SIP/2.0/TCP 127.0.0.1:5080;branch=z9hG4bK-d8754z-Pja6fca75c008440eca85508ddab9e7679-2---d8754z-;rport=32850
Via:SIP/2.0/TCP LokalPC:50195;rport;branch=z9hG4bKPja6fca75c008440eca85508ddab9e7679;alias
24-Feb-2016 09:07:02.146 Currently active calls - 1: [17]
24-Feb-2016 09:06:36.022 [CM503025]: Call(C:17): Calling T:Line:10000>>Rufnummer1@[Dev:sip:RufnummerOhneNeb@VodafoneServerIP:5060] for L:17.1[Extn:20]
24-Feb-2016 09:06:36.020 [MS006000] C:17.2: connection address is enforced to PBX_IP
24-Feb-2016 09:06:35.972 [CM503027]: Call(C:17): From: Extn:20 ("MEINNAME" <sip:20@PBX_IP:5060>) to T:Line:10000>>Rufnummer1@[Dev:sip:RufnummerOhneNeb@VodafoneServerIP:5060]
24-Feb-2016 09:06:35.972 [CM503004]: Call(C:17): Route 1: from L:17.1[Extn:20] to T:Line:10000>>Rufnummer1@[Dev:sip:RufnummerOhneNeb@VodafoneServerIP:5060]
24-Feb-2016 09:06:35.972 Line limit check: Current # of calls for line Lc:10000(@Vodafone[<sip:RufnummerOhneNeb@VodafoneServerIP:5060>]) is 0; limit is 2
24-Feb-2016 09:06:35.972 Call(C:17): Call from Extn:20 to Rufnummer1 matches outbound rule 'Rule for Vodafone'
24-Feb-2016 09:06:35.970 [CM503001]: Call(C:17): Incoming call from Extn:20 to <sip:Rufnummer1@PBX_IP:5060>
24-Feb-2016 09:06:35.970 NAT/ALG check:L:17.1[Extn:20] REQUEST 'INVITE' - some of SIP/SDP headers may contain inconsistent information or modified by intermediate hop
1. Versuch
