Problem mit SBC Verbindung
spuky
17. Dezember 2019
Seit ein paar tagen spinnt unser SBC habe den schon neu aufgesetzt... (unter siptrunks und die DebianVM ) aber es bleibt bei solchen Abbrüchen hatte jemand schon einmal so was... und kann einen Tipp geben wo ich das Problem suchen kann..
ERR | 20210225-081253.058 | 3CX | SBC | 139923501516992 | TunnelTcp.cpp:591 | Tunnel connection to [ V4 XXX.XXX.XXX.XXX:5090 TCP ] is disconnected; error: Connection is terminated by peer - while begin to read a packet from tunnel
ERR | 20210225-081253.058 | 3CX | SBC | 139923501516992 | TunnelTcp.cpp:295 | Bridge failure 'Connection is terminated by peer - while begin to read a packet from tunnel' on TCP connection:
CRIT | 20210225-081253.058 | 3CX | SBC | 139923501516992 | Log.h:103 | Remote: fetch logs at level -1
ERR | 20210225-095859.440 | 3CX | SBC | 139923501516992 | TunnelTcp.cpp:591 | Tunnel connection to [ V4 XXX.XXX.XXX.XXX:5090 TCP ] is disconnected; error: Connection is terminated by peer - while begin to read a packet from tunnel
ERR | 20210225-095859.440 | 3CX | SBC | 139923501516992 | TunnelTcp.cpp:295 | Bridge failure 'Connection is terminated by peer - while begin to read a packet from tunnel' on TCP connection:
CRIT | 20210225-095859.440 | 3CX | SBC | 139923501516992 | Log.h:103 | Remote: fetch logs at level -1
ERR | 20210225-120425.865 | 3CX | SBC | 139923501516992 | TunnelTcp.cpp:591 | Tunnel connection to [ V4 XXX.XXX.XXX.XXX:5090 TCP ] is disconnected; error: Connection is terminated by peer - while begin to read a packet from tunnel
ERR | 20210225-120425.865 | 3CX | SBC | 139923501516992 | TunnelTcp.cpp:295 | Bridge failure 'Connection is terminated by peer - while begin to read a packet from tunnel' on TCP connection:
CRIT | 20210225-120425.865 | 3CX | SBC | 139923501516992 | Log.h:103 | Remote: fetch logs at level -1
ERR | 20210225-120531.380 | 3CX | SBC | 139923501516992 | TunnelTcp.cpp:591 | Tunnel connection to [ V4 XXX.XXX.XXX.XXX:5090 TCP ] is disconnected; error: Connection is terminated by peer - while begin to read a packet from tunnel
ERR | 20210225-120531.380 | 3CX | SBC | 139923501516992 | TunnelTcp.cpp:295 | Bridge failure 'Connection is terminated by peer - while begin to read a packet from tunnel' on TCP connection:
CRIT | 20210225-120531.380 | 3CX | SBC | 139923501516992 | Log.h:103 | Remote: fetch logs at level -1
welche Debian Version hast du? ist das ein Raspberry Pi?
nein eine VM auf VM ware fusion... installiert mit dem letzten 3cx iso..(vorher lief das 1 Jahr lang ohne Unterbrechung...)
hab das gleiche jetzt mal auf meiner Qnap virtualisation station gemacht und da läuft es.. (immerhin jetzt wieder ein SBC der funktioniert ...
Zu früh gefreut.... das hat mal so 2 Stunden gehalten und dann war es auch da das gleiche ... Bild.... die selben abbrüche...
Alberto Ariotti
