Hier das Log vom Snom D715
Sep 12 11:55:15.928 [INFO ] TLS: OpenSSL 1.0.2j 26 Sep 2016 initialised (1)
Sep 12 11:55:15.929 [INFO ] TLS: SnomTls initialised (1)
Sep 12 11:55:15.932 [INFO ] MEDIA: 1/Tcp:127.0.0.1:51830 connecting
Sep 12 11:55:15.941 [ALERT ] PHN: Starting up
Sep 12 11:55:15.942 [ALERT ] PHN: Starting up 2
Sep 12 11:55:15.942 [ALERT ] PHN: Starting up 3
Sep 12 11:55:15.946 [DEBUG2] PHN: KMSG: <5>Linux version 2.6.27.47 (hd@t460p) (gcc version 4.3.2 (Wind River Linux Sourcery G++ 4.3a-291) ) #32 PREEMPT Fri Jul 14 12:38:47 CEST 2017
Sep 12 11:55:15.947 [DEBUG2] PHN: KMSG: <4>CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387f
Sep 12 11:55:15.947 [DEBUG2] PHN: KMSG: <4>Machine: snom715
Sep 12 11:55:15.947 [DEBUG2] PHN: KMSG: <4>Memory policy: ECC disabled, Data cache writeback
Sep 12 11:55:15.947 [DEBUG2] PHN: KMSG: <7>On node 0 totalpages: 15872
Sep 12 11:55:15.947 [DEBUG2] PHN: KMSG: <7>free_area_init_node: node 0, pgdat c03dd6f8, node_mem_map c0413000
Sep 12 11:55:15.947 [DEBUG2] PHN: KMSG: <7> DMA zone: 15748 pages, LIFO batch:3
Sep 12 11:55:15.947 [DEBUG2] PHN: KMSG: <4>CPU0: D VIPT write-back cache
Sep 12 11:55:15.947 [DEBUG2] PHN: KMSG: <4>CPU0: I cache: 32768 bytes, associativity 4, 32 byte lines, 256 sets
Sep 12 11:55:15.947 [DEBUG2] PHN: KMSG: <4>CPU0: D cache: 32768 bytes, associativity 4, 32 byte lines, 256 sets
Sep 12 11:55:15.947 [DEBUG2] PHN: KMSG: <4>Built 1 zonelists in Zone order, mobility grouping on. Total pages: 15748
Sep 12 11:55:15.947 [DEBUG2] PHN: KMSG: <5>Kernel command line: console=ttyAMA0,115200n8 root=/dev/mtdblock7 rw rootfstype=jffs2 noinitrd ethaddr=00:04:13:75:C4:23 fwenv=/dev/mtd2,0x0,0x4000,0x20000 m... (truncated)
Sep 12 11:55:15.947 [DEBUG2] PHN: KMSG: <4>switch_ethaddr_setup: mac address 0- 4-13-75-c4-23
Sep 12 11:55:15.948 [DEBUG2] PHN: KMSG: <4>PID hash table entries: 256 (order: 8, 1024 bytes)
Sep 12 11:55:15.948 [DEBUG2] PHN: KMSG: <6>bcmring_init_timer
Sep 12 11:55:15.948 [DEBUG2] PHN: KMSG: <6>SVN Revision: UNKNOWN
Sep 12 11:55:15.948 [DEBUG2] PHN: KMSG: <4>Console: colour dummy device 80x30
Sep 12 11:55:15.948 [DEBUG2] PHN: KMSG: <6>Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Sep 12 11:55:15.948 [DEBUG2] PHN: KMSG: <6>Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Sep 12 11:55:15.948 [DEBUG2] PHN: KMSG: <6>Memory: 62MB = 62MB total
Sep 12 11:55:15.948 [DEBUG2] PHN: KMSG: <5>Memory: 58688KB available (3660K code, 359K data, 96K init)
Sep 12 11:55:15.948 [DEBUG2] PHN: KMSG: <6>Calibrating delay loop... 299.00 BogoMIPS (lpj=1495040)
Sep 12 11:55:15.948 [DEBUG2] PHN: KMSG: <4>Mount-cache hash table entries: 512
Sep 12 11:55:15.948 [DEBUG2] PHN: KMSG: <6>CPU: Testing write buffer coherency: ok
Sep 12 11:55:15.948 [DEBUG2] PHN: KMSG: <6>net_namespace: 780 bytes
Sep 12 11:55:15.948 [DEBUG2] PHN: KMSG: <6>NET: Registered protocol family 16
Sep 12 11:55:15.949 [DEBUG2] PHN: KMSG: <4>bcmring_ddrvpmphase_init: *** DDR Phase Value: 0x07
Sep 12 11:55:15.949 [DEBUG2] PHN: KMSG: <5>Chip: 0x00011198
Sep 12 11:55:15.949 [DEBUG2] PHN: KMSG: <4>gpio_init called
Sep 12 11:55:15.949 [DEBUG2] PHN: KMSG: <6>GPIO Control Driver: 1.00 (built on Jul 14 2017 12:38:33)
Sep 12 11:55:15.949 [DEBUG2] PHN: KMSG: <5>knllog_init
Sep 12 11:55:15.949 [DEBUG2] PHN: KMSG: <4>perfcnt_init
Sep 12 11:55:15.949 [DEBUG2] PHN: KMSG: <4>calling host_cpu_usage_init
Sep 12 11:55:15.949 [DEBUG2] PHN: KMSG: <4>*************Starting host ICP thread **************
Sep 12 11:55:15.949 [DEBUG2] PHN: KMSG: <5>SCSI subsystem initialized
Sep 12 11:55:15.949 [DEBUG2] PHN: KMSG: <6>usbcore: registered new interface driver usbfs
Sep 12 11:55:15.949 [DEBUG2] PHN: KMSG: <6>usbcore: registered new interface driver hub
Sep 12 11:55:15.949 [DEBUG2] PHN: KMSG: <6>usbcore: registered new device driver usb
Sep 12 11:55:15.949 [DEBUG2] PHN: KMSG: <6>SPU: driver probed. tx_ring virt=0x08ff000000 phys=0x083e2c000
Sep 12 11:55:15.950 [DEBUG2] PHN: KMSG: <6>Bluetooth: Core ver 2.13
Sep 12 11:55:15.950 [DEBUG2] PHN: KMSG: <6>NET: Registered protocol family 31
Sep 12 11:55:15.950 [DEBUG2] PHN: KMSG: <6>Bluetooth: HCI device and connection manager initialized
Sep 12 11:55:15.950 [DEBUG2] PHN: KMSG: <6>Bluetooth: HCI socket layer initialized
Sep 12 11:55:15.950 [DEBUG2] PHN: KMSG: <6>NET: Registered protocol family 2
Sep 12 11:55:15.950 [DEBUG2] PHN: KMSG: <7>Switched to high resolution mode on CPU 0
Sep 12 11:55:15.950 [DEBUG2] PHN: KMSG: <6>IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
Sep 12 11:55:15.950 [DEBUG2] PHN: KMSG: <6>TCP established hash table entries: 2048 (order: 2, 16384 bytes)
Sep 12 11:55:15.950 [DEBUG2] PHN: KMSG: <6>TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
Sep 12 11:55:15.950 [DEBUG2] PHN: KMSG: <6>TCP: Hash tables configured (established 2048 bind 2048)
Sep 12 11:55:15.950 [DEBUG2] PHN: KMSG: <6>TCP reno registered
Sep 12 11:55:15.950 [DEBUG2] PHN: KMSG: <6>NET: Registered protocol family 1
Sep 12 11:55:15.950 [DEBUG2] PHN: KMSG: <4>bcmring_pm_init: Initializing Power Management for BCMRING....
Sep 12 11:55:15.951 [DEBUG2] PHN: KMSG: <7>Synthetic TSC timer will fire each 131069 jiffies.
Sep 12 11:55:15.951 [DEBUG2] PHN: KMSG: <3>bootmemheap_init: Error - bootmemheap_setup() not called
Sep 12 11:55:15.951 [DEBUG2] PHN: KMSG: <6>JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
Sep 12 11:55:15.951 [DEBUG2] PHN: KMSG: <6>msgmni has been set to 114
Sep 12 11:55:15.951 [DEBUG2] PHN: KMSG: <6>pka_init
Sep 12 11:55:15.951 [DEBUG2] PHN: KMSG: <6>io scheduler noop registered (default)
Sep 12 11:55:15.951 [DEBUG2] PHN: KMSG: <6>Broadcom RNG Driver
Sep 12 11:55:15.951 [DEBUG2] PHN: KMSG: <6>RNG: Driver initialized
Sep 12 11:55:15.951 [DEBUG2] PHN: KMSG: <6>MMDMA: Using dedicated DMA channel
Sep 12 11:55:15.951 [DEBUG2] PHN: KMSG: <6>MMDMA: No memory allocation is allowed!
Sep 12 11:55:15.951 [DEBUG2] PHN: KMSG: <6>MMDMA: Module initialized
Sep 12 11:55:15.951 [DEBUG2] PHN: KMSG: <5>GE: Driver initialized
Sep 12 11:55:15.952 [DEBUG2] PHN: KMSG: <6>HPM Driver: 1.00 (built on Jul 13 2017 14:24:05)
Sep 12 11:55:15.952 [DEBUG2] PHN: KMSG: <4>
Sep 12 11:55:15.952 [DEBUG2] PHN: KMSG: <6>KNLLOGDRV: Driver initialized
Sep 12 11:55:15.952 [DEBUG2] PHN: KMSG: <6>HAL Audio Driver: 1.0
Sep 12 11:55:15.952 [DEBUG2] PHN: KMSG: <6>HAL Audio platform support installed. Built Jul 13 2017 14:24:05
Sep 12 11:55:15.952 [DEBUG2] PHN: KMSG: <6>Audio Mixer Driver: 1.0
Sep 12 11:55:15.952 [DEBUG2] PHN: KMSG: <6>Broadcom GPIO Driver: 1.00
Sep 12 11:55:15.952 [DEBUG2] PHN: KMSG: <6>BSC: Driver initialized
Sep 12 11:55:15.952 [DEBUG2] PHN: KMSG: <6>Serial: AMBA PL011 UART driver
Sep 12 11:55:15.952 [DEBUG2] PHN: KMSG: <6>UARTA: ttyAMA0 at MMIO 0x80012000 (irq = 46) is a AMBA/PL011
Sep 12 11:55:15.952 [DEBUG2] PHN: KMSG: <6>console [ttyAMA0] enabled
Sep 12 11:55:15.952 [DEBUG2] PHN: KMSG: <6>UARTB: ttyAMA1 at MMIO 0x80013000 (irq = 44) is a AMBA/PL011
Sep 12 11:55:15.952 [DEBUG2] PHN: KMSG: <4>------->bcmring_net_init(): <6><6>Broadcom BCMRING network driver 0.2.0
Sep 12 11:55:15.953 [DEBUG2] PHN: KMSG: <4>
Sep 12 11:55:15.953 [DEBUG2] PHN: KMSG: <4>------->bcmring_net_init(): <6>bcmring_net => RL: Packet based rate limit enable = 0
Sep 12 11:55:15.953 [DEBUG2] PHN: KMSG: <4>------->bcmring_net_probe(): <6>bcmring_net configuration: brcmMode=0, descRx=64, descTx=1024
Sep 12 11:55:15.953 [DEBUG2] PHN: KMSG: <4>------->ethStart(): <4>Ethernet initialization successful (rc=0)
Sep 12 11:55:15.953 [DEBUG2] PHN: KMSG: <6>tun: Universal TUN/TAP device driver, 1.6
Sep 12 11:55:15.953 [DEBUG2] PHN: KMSG: <6>tun: (C) 1999-2004 Max Krasnyansky <
[email protected]>
Sep 12 11:55:15.953 [DEBUG2] PHN: KMSG: <4>Driver 'sd' needs updating - please use bus_type methods
Sep 12 11:55:15.954 [DEBUG2] PHN: KMSG: <6>BCM UMI MTD NAND Driver: 1.00
Sep 12 11:55:15.954 [DEBUG2] PHN: KMSG: <6>NAND device: Manufacturer ID: 0xc2, Chip ID: 0xf1 (Macronix NAND 128MiB 3,3V 8-bit)
Sep 12 11:55:15.955 [DEBUG2] PHN: KMSG: <6>Scanning device for bad blocks
Sep 12 11:55:15.955 [DEBUG2] PHN: KMSG: <4>Bad eraseblock 81 at 0x00a20000
Sep 12 11:55:15.955 [DEBUG2] PHN: KMSG: <4>Bad eraseblock 104 at 0x00d00000
Sep 12 11:55:15.955 [DEBUG2] PHN: KMSG: <5>8 cmdlinepart partitions found on MTD device bcm_umi-nand
Sep 12 11:55:15.955 [DEBUG2] PHN: KMSG: <5>Creating 8 MTD partitions on "bcm_umi-nand":
Sep 12 11:55:15.955 [DEBUG2] PHN: KMSG: <5>0x00000000-0x000a0000 : "bootloader"
Sep 12 11:55:15.955 [DEBUG2] PHN: KMSG: <5>0x000a0000-0x00180000 : "uboot"
Sep 12 11:55:15.955 [DEBUG2] PHN: KMSG: <5>0x00180000-0x00200000 : "ubootenv"
Sep 12 11:55:15.955 [DEBUG2] PHN: KMSG: <5>0x00200000-0x00600000 : "rescuekernel"
Sep 12 11:55:15.955 [DEBUG2] PHN: KMSG: <5>0x00600000-0x00e00000 : "rescuefs"
Sep 12 11:55:15.955 [DEBUG2] PHN: KMSG: <5>0x00e00000-0x00ec0000 : "data"
Sep 12 11:55:15.955 [DEBUG2] PHN: KMSG: <5>0x00ec0000-0x012c0000 : "kernel"
Sep 12 11:55:15.955 [DEBUG2] PHN: KMSG: <5>0x012c0000-0x08000000 : "rootfs"
Sep 12 11:55:15.955 [DEBUG2] PHN: KMSG: <6>usbcore: registered new interface driver cdc_acm
Sep 12 11:55:15.955 [DEBUG2] PHN: KMSG: <6>cdc_acm: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapters
Sep 12 11:55:15.956 [DEBUG2] PHN: KMSG: <6>Initializing USB Mass Storage driver...
Sep 12 11:55:15.956 [DEBUG2] PHN: KMSG: <6>usbcore: registered new interface driver usb-storage
Sep 12 11:55:15.956 [DEBUG2] PHN: KMSG: <6>USB Mass Storage support registered.
Sep 12 11:55:15.956 [DEBUG2] PHN: KMSG: <6>usbcore: registered new interface driver usbserial
Sep 12 11:55:15.956 [DEBUG2] PHN: KMSG: <6>usbserial: USB Serial support registered for generic
Sep 12 11:55:15.956 [DEBUG2] PHN: KMSG: <6>usbcore: registered new interface driver usbserial_generic
Sep 12 11:55:15.956 [DEBUG2] PHN: KMSG: <6>usbserial: USB Serial Driver core
Sep 12 11:55:15.956 [DEBUG2] PHN: KMSG: <6>BCMRING Keypad Input Driver: 1.00
Sep 12 11:55:15.956 [DEBUG2] PHN: KMSG: <6>input: keypad as /devices/virtual/input/input0
Sep 12 11:55:15.956 [DEBUG2] PHN: KMSG: <5>Keypad: rows=9 cols=9 scancode=81 Debounce count=200 Sampling freq=9004
Sep 12 11:55:15.956 [DEBUG2] PHN: KMSG: <4>BCMRING RTC, (c) 2009 Broadcom Corporation
Sep 12 11:55:15.956 [DEBUG2] PHN: KMSG: <6>Software Watchdog Timer: 0.07 initialized. soft_noboot=0 soft_margin=60 sec (nowayout= 0)
Sep 12 11:55:15.956 [DEBUG2] PHN: KMSG: <6>Bluetooth: Generic Bluetooth USB driver ver 0.3
Sep 12 11:55:15.957 [DEBUG2] PHN: KMSG: <6>usbcore: registered new interface driver btusb
Sep 12 11:55:15.957 [DEBUG2] PHN: KMSG: <6>usbcore: registered new interface driver hiddev
Sep 12 11:55:15.957 [DEBUG2] PHN: KMSG: <6>usbcore: registered new interface driver usbhid
Sep 12 11:55:15.957 [DEBUG2] PHN: KMSG: <6>usbhid: v2.6:USB HID core driver
Sep 12 11:55:15.957 [DEBUG2] PHN: KMSG: <6>TCP cubic registered
Sep 12 11:55:15.957 [DEBUG2] PHN: KMSG: <6>NET: Registered protocol family 10
Sep 12 11:55:15.957 [DEBUG2] PHN: KMSG: <6>lo: Disabled Privacy Extensions
Sep 12 11:55:15.957 [DEBUG2] PHN: KMSG: <6>IPv6 over IPv4 tunneling driver
Sep 12 11:55:15.957 [DEBUG2] PHN: KMSG: <6>sit0: Disabled Privacy Extensions
Sep 12 11:55:15.957 [DEBUG2] PHN: KMSG: <6>NET: Registered protocol family 17
Sep 12 11:55:15.957 [DEBUG2] PHN: KMSG: <5>Bridge firewalling registered
Sep 12 11:55:15.957 [DEBUG2] PHN: KMSG: <6>Ebtables v2.0 registered
Sep 12 11:55:15.957 [DEBUG2] PHN: KMSG: <6>Bluetooth: L2CAP ver 2.11
Sep 12 11:55:15.958 [DEBUG2] PHN: KMSG: <6>Bluetooth: L2CAP socket layer initialized
Sep 12 11:55:15.958 [DEBUG2] PHN: KMSG: <6>Bluetooth: SCO (Voice Link) ver 0.6
Sep 12 11:55:15.958 [DEBUG2] PHN: KMSG: <6>Bluetooth: SCO socket layer initialized
Sep 12 11:55:15.958 [DEBUG2] PHN: KMSG: <6>Bluetooth: RFCOMM socket layer initialized
Sep 12 11:55:15.958 [DEBUG2] PHN: KMSG: <6>Bluetooth: RFCOMM TTY layer initialized
Sep 12 11:55:15.958 [DEBUG2] PHN: KMSG: <6>Bluetooth: RFCOMM ver 1.10
Sep 12 11:55:15.958 [DEBUG2] PHN: KMSG: <6>Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Sep 12 11:55:15.958 [DEBUG2] PHN: KMSG: <6>Bluetooth: BNEP filters: protocol multicast
Sep 12 11:55:15.958 [DEBUG2] PHN: KMSG: <6>Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Sep 12 11:55:15.958 [DEBUG2] PHN: KMSG: <6>RPC: Registered udp transport module.
Sep 12 11:55:15.958 [DEBUG2] PHN: KMSG: <6>RPC: Registered tcp transport module.
Sep 12 11:55:15.958 [DEBUG2] PHN: KMSG: <6>802.1Q VLAN Support v1.8 Ben Greear <
[email protected]>
Sep 12 11:55:15.959 [DEBUG2] PHN: KMSG: <6>All bugs added by David S. Miller <
[email protected]>
Sep 12 11:55:15.959 [DEBUG2] PHN: KMSG: <4>initializing drivers/video/fb_snom715.c
Sep 12 11:55:15.959 [DEBUG2] PHN: KMSG: <6>fb0: snom715 frame buffer device, using 768Bytes of video memory
Sep 12 11:55:15.959 [DEBUG2] PHN: KMSG: <4>loading module:drivers/video/fb_snom715.c build @12:38:44
Sep 12 11:55:15.959 [DEBUG2] PHN: KMSG: <4>setup_gpio_out: Setting up the GPIOS for snom715!setup_gpio_out: label:A0 ST7567,pin:38,level:0
Sep 12 11:55:15.959 [DEBUG2] PHN: KMSG: <4>setup_gpio_out: Return value of gpio_request:0
Sep 12 11:55:15.959 [DEBUG2] PHN: KMSG: <4>setup_gpio_out: Setting up the GPIOS for snom715!setup_gpio_out: label:RESET ST7567,pin:16,level:1
Sep 12 11:55:15.959 [DEBUG2] PHN: KMSG: <4>setup_gpio_out:0
Sep 12 11:55:15.959 [DEBUG2] PHN: KMSG: <4>setup spi bus:0
Sep 12 11:55:15.959 [DEBUG2] PHN: KMSG: <4>VFS: Mounted root (jffs2 filesystem).
Sep 12 11:55:15.960 [DEBUG2] PHN: KMSG: <6>Freeing init memory: 96K
Sep 12 11:55:15.960 [DEBUG2] PHN: KMSG: <7>snom715fb: mmap framebuffer P(3fda000)->V(40024000), size 1000
Sep 12 11:55:15.960 [DEBUG2] PHN: KMSG: <4>bcmring_eth_sla: module license 'Proprietary' taints kernel.
Sep 12 11:55:15.960 [DEBUG2] PHN: KMSG: <6>USB: Port 1 has been brought up as Host
Sep 12 11:55:15.960 [DEBUG2] PHN: KMSG: <6>bcm-ehci: init device 1
Sep 12 11:55:15.960 [DEBUG2] PHN: KMSG: <6>bcm-ehci bcm-ehci.1: bcm-ehci
Sep 12 11:55:15.960 [DEBUG2] PHN: KMSG: <6>bcm-ehci bcm-ehci.1: new USB bus registered, assigned bus number 1
Sep 12 11:55:15.960 [DEBUG2] PHN: KMSG: <6>bcm-ehci bcm-ehci.1: irq 17, io mem 0xf8410800
Sep 12 11:55:15.960 [DEBUG2] PHN: KMSG: <6>bcm-ehci bcm-ehci.1: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
Sep 12 11:55:15.960 [DEBUG2] PHN: KMSG: <6>usb usb1: configuration #1 chosen from 1 choice
Sep 12 11:55:15.960 [DEBUG2] PHN: KMSG: <6>hub 1-0:1.0: USB hub found
Sep 12 11:55:15.960 [DEBUG2] PHN: KMSG: <6>hub 1-0:1.0: 1 port detected
Sep 12 11:55:15.961 [DEBUG2] PHN: KMSG: <6>usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Sep 12 11:55:15.961 [DEBUG2] PHN: KMSG: <6>usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Sep 12 11:55:15.961 [DEBUG2] PHN: KMSG: <6>usb usb1: Product: bcm-ehci
Sep 12 11:55:15.961 [DEBUG2] PHN: KMSG: <6>usb usb1: Manufacturer: Linux 2.6.27.47 ehci_hcd
Sep 12 11:55:15.961 [DEBUG2] PHN: KMSG: <6>usb usb1: SerialNumber: bcm-ehci
Sep 12 11:55:15.961 [DEBUG2] PHN: KMSG: <6>bcm-ohci: init device 1
Sep 12 11:55:15.961 [DEBUG2] PHN: KMSG: <6>bcm-ohci bcm-ohci.1: bcm-ohci
Sep 12 11:55:15.961 [DEBUG2] PHN: KMSG: <6>bcm-ohci bcm-ohci.1: new USB bus registered, assigned bus number 2
Sep 12 11:55:15.961 [DEBUG2] PHN: KMSG: <6>bcm-ohci bcm-ohci.1: irq 17, io mem 0xf8410000
Sep 12 11:55:15.961 [DEBUG2] PHN: KMSG: <6>usb usb2: configuration #1 chosen from 1 choice
Sep 12 11:55:15.961 [DEBUG2] PHN: KMSG: <6>hub 2-0:1.0: USB hub found
Sep 12 11:55:15.961 [DEBUG2] PHN: KMSG: <6>hub 2-0:1.0: 1 port detected
Sep 12 11:55:15.961 [DEBUG2] PHN: KMSG: <6>usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
Sep 12 11:55:15.961 [DEBUG2] PHN: KMSG: <6>usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Sep 12 11:55:15.962 [DEBUG2] PHN: KMSG: <6>usb usb2: Product: bcm-ohci
Sep 12 11:55:15.962 [DEBUG2] PHN: KMSG: <6>usb usb2: Manufacturer: Linux 2.6.27.47 ohci_hcd
Sep 12 11:55:15.962 [DEBUG2] PHN: KMSG: <6>usb usb2: SerialNumber: bcm-ohci
Sep 12 11:55:15.962 [DEBUG2] PHN: KMSG: <6>HAL Audio APM Driver: 1.0. Built Jul 30 2013 11:37:25
Sep 12 11:55:15.962 [DEBUG2] PHN: KMSG: <6>HAL Audio PCM Driver: 1.0. Built May 20 2015 14:51:16
Sep 12 11:55:15.962 [DEBUG2] PHN: KMSG: <6>channels=1 channel_select=0
Sep 12 11:55:15.962 [DEBUG2] PHN: KMSG: <6>BT GPIOs: RST_B=2 VREG_CTL=3 WAKE=4
Sep 12 11:55:15.962 [DEBUG2] PHN: KMSG: <6>BT GPIOs: RST_B2=7 VREG_CTL2=6 WAKE=4
Sep 12 11:55:15.962 [DEBUG2] PHN: KMSG: <6>HAL Audio USB Core Driver: 1.0. Built Nov 6 2014 16:47:05
Sep 12 11:55:15.962 [DEBUG2] PHN: KMSG: <6>usbcore: registered new interface driver HAL Audio USB
Sep 12 11:55:15.962 [DEBUG2] PHN: KMSG: <6>HAL Audio USB Driver: 1.0. Built Nov 5 2014 16:02:37
Sep 12 11:55:15.962 [DEBUG2] PHN: KMSG: <6>LDX Kernel Driver
Sep 12 11:55:15.962 [DEBUG2] PHN: KMSG: <6>@(#)IMAGE_ID:Endpoint Driver (built on Feb 5 2013 19:21:24)
Sep 12 11:55:15.963 [DEBUG2] PHN: KMSG: <4>ept:endpoint_init: entry
Sep 12 11:55:15.963 [DEBUG2] PHN: KMSG: <4>haltopInit: Booting TL3 processor
Sep 12 11:55:15.963 [DEBUG2] PHN: KMSG: <4>VPM Load address=0x30800000 size=624
Sep 12 11:55:15.963 [DEBUG2] PHN: KMSG: <4>VPM Load address=0x00010000 size=592632
Sep 12 11:55:15.963 [DEBUG2] PHN: KMSG: <4>VPM Load address=0x30a00000 size=65536
Sep 12 11:55:15.963 [DEBUG2] PHN: KMSG: <4>VPM Load address=0x000b22b0 size=271968
Sep 12 11:55:15.963 [DEBUG2] PHN: KMSG: <4>haltopInit: Booting TL3 processor - Complete
Sep 12 11:55:15.963 [DEBUG2] PHN: KMSG: <4>tl3AndLccInit: Initializing IPC for LCC
Sep 12 11:55:15.964 [DEBUG2] PHN: KMSG: <4>tl3AndLccInit: Initializing IPC for LCC - Complete
Sep 12 11:55:15.964 [DEBUG2] PHN: KMSG: <7>snom715fb: mmap framebuffer P(3fda000)->V(40024000), size 1000
Sep 12 11:55:15.965 [DEBUG2] PHN: KMSG: <7>snom715fb: mmap framebuffer P(3fda000)->V(40024000), size 1000
Sep 12 11:55:15.966 [DEBUG2] PHN: KMSG: <7>snom715fb: mmap framebuffer P(3fda000)->V(40024000), size 1000
Sep 12 11:55:15.966 [DEBUG2] PHN: KMSG: <4>ept:ldxEventCb: NetVHD handle 82. Error evt = HAPI_CODEC_EXCEPTION_EVT(PVEEXCEPTION_SUPERINTERVAL). max packet size = 960 bytes
Sep 12 11:55:15.966 [INFO ] MEDIA: Connected to MediaDaemon at Tcp:127.0.0.1:1299
Sep 12 11:55:16.504 [DEBUG2] PHN: SetMaxAllowedConferenceMembers: 2 conference members are allowed for this phone
Sep 12 11:55:16.516 [NOTICE] PHN: MacAddressMgr::GetMacFromKernelBootParams() cmdline: >console=ttyAMA0,115200n8 root=/dev/mtdblock7 rw rootfstype=jffs2 noinitrd ethaddr=00:04:13:75:C4:23 fwenv=/dev/mtd2,0x0,0x4000,0x20000 mtdparts=bcm_umi-nand:0x000a0000(bootloader),0x000e0000(uboot),0x00080000(ubootenv),0x00400000(rescuekernel),0x00800000(rescuefs),0x000c0000(data),0x00400000(kernel),0x06d40000(rootfs)<
Sep 12 11:55:16.516 [NOTICE] PHN: MacAddressMgr::GetMacFromKernelBootParams() mac: >00:04:13:75:C4:23<
Sep 12 11:55:16.516 [NOTICE] PHN: MacAddressMgr::Get() MAC = >00041375C423<
Sep 12 11:55:17.267 [INFO ] TLS: PhoneCtx: OpenSSL 1.0.2j 26 Sep 2016, Context 1. created
Sep 12 11:55:17.410 [ALERT ] PHN: read_old_settings: No /snom/snomconfig/raw_settings found for reading.
Sep 12 11:55:17.441 [NOTICE] PHN: read_xml_settings: found phone-settings XML header
Sep 12 11:55:17.442 [NOTICE] PHN: read_xml_settings: found one byte encoding: 0
Sep 12 11:55:17.442 [DEBUG2] PHN: settings::read_one_setting: language = 'Deutsch', set.need_apply: 0, finished: 0, need reboot to apply: 0
Sep 12 11:55:17.443 [DEBUG2] PHN: settings::read_one_setting: setting_server = 'http://192.168.1.163:5000/provisioning/lmn2whmh6c/cfg{mac}', set.need_apply: 1, finished: 0, need reboot to apply: 0
Sep 12 11:55:17.444 [DEBUG2] PHN: settings::read_one_setting: ip_adr = '192.168.1.189', set.need_apply: 1, finished: 0, need reboot to apply: 0
Sep 12 11:55:17.445 [DEBUG2] PHN: settings::read_one_setting: netmask = '255.255.255.0', set.need_apply: 1, finished: 0, need reboot to apply: 0
Sep 12 11:55:17.445 [DEBUG2] PHN: settings::read_one_setting: dns_domain = 'Herrmann.local', set.need_apply: 0, finished: 0, need reboot to apply: 0
Sep 12 11:55:17.445 [DEBUG2] PHN: settings::read_one_setting: dns_server1 = '192.168.1.164', set.need_apply: 0, finished: 0, need reboot to apply: 0
Sep 12 11:55:17.445 [DEBUG2] PHN: settings::read_one_setting: gateway = '192.168.1.1', set.need_apply: 1, finished: 0, need reboot to apply: 0
Sep 12 11:55:17.446 [DEBUG2] PHN: settings::read_one_setting: utc_offset = '3600', set.need_apply: 0, finished: 0, need reboot to apply: 0
Sep 12 11:55:17.446 [DEBUG2] PHN: settings::read_one_setting: system_time = '1536753303', set.need_apply: 0, finished: 0, need reboot to apply: 0
Sep 12 11:55:17.446 [DEBUG2] PHN: settings::read_one_setting: ntp_server = 'pool.ntp.org', set.need_apply: 0, finished: 0, need reboot to apply: 0
Sep 12 11:55:17.446 [DEBUG2] PHN: settings::read_one_setting: dst = '3600 03.05.07 02:00:00 10.05.07 03:00:00', set.need_apply: 0, finished: 0, need reboot to apply: 0
Sep 12 11:55:17.447 [DEBUG2] PHN: settings::read_one_setting: timezone = 'GER+1', set.need_apply: 0, finished: 0, need reboot to apply: 0
Sep 12 11:55:17.447 [DEBUG2] PHN: settings::read_one_setting: tone_scheme = 'GER', set.need_apply: 0, finished: 0, need reboot to apply: 0
Sep 12 11:55:17.447 [DEBUG2] PHN: settings::read_one_setting: log_level = '4', set.need_apply: 0, finished: 0, need reboot to apply: 0
Sep 12 11:55:17.447 [DEBUG2] PHN: settings::read_one_setting: update_policy = 'auto_update', set.need_apply: 0, finished: 0, need reboot to apply: 0
Sep 12 11:55:17.448 [DEBUG2] PHN: settings::read_one_setting: web_language = 'Deutsch', set.need_apply: 0, finished: 0, need reboot to apply: 0
Sep 12 11:55:17.448 [DEBUG2] PHN: settings::read_one_setting: firmware_version = 'snom715-SIP 8.9.3.96', set.need_apply: 0, finished: 0, need reboot to apply: 0
Sep 12 11:55:17.448 [DEBUG2] PHN: settings::read_one_setting: uboot_version = '2010.12-00003-g3143800', set.need_apply: 0, finished: 0, need reboot to apply: 0
Sep 12 11:55:17.448 [DEBUG2] PHN: settings::read_one_setting: settings_refresh_timer = '86400', set.need_apply: 0, finished: 0, need reboot to apply: 0
Sep 12 11:55:17.450 [NOTICE] PHN: read_xml_settings: found network-settings XML header
Sep 12 11:55:17.451 [NOTICE] PHN: read_xml_settings: found one byte encoding: 1
Sep 12 11:55:17.451 [DEBUG2] PHN: Set: sip_port = '0', set.need_apply: 0, finished: 0, need reboot to apply: 0
Sep 12 11:55:17.452 [DEBUG2] PHN: Set: license_data = 'Mac:00041375C423;Hardware
715 (R3A, V1F);Date:07/15;Copyright(C) snom technology AG', set.need_apply: 1, finished: 0, need reboot to apply: 0
Sep 12 11:55:17.455 [DEBUG2] PHN: Set: mac = '00041375C423', set.need_apply: 0, finished: 0, need reboot to apply: 0
Sep 12 11:55:17.559 [NOTICE] PHN: read_xml_settings: found ReplacementPlan XML header
Sep 12 11:55:17.559 [NOTICE] PHN: read_xml_settings: found one byte encoding: 1
Sep 12 11:55:17.559 [DEBUG0] PHN: ReplacementPlan:
rocessReplacedPlans: new_id=BW-ServerBLF, it is valid
Sep 12 11:55:17.560 [DEBUG0] PHN: ReplacementPlan:
rocessReplacedPlans: type BW-ServerBLF replaces ResourceListBuddy
rocessReplacedPlans: id BW-ServerBLF replaces ResourceListBuddy
rocessReplacedPlans: new_id=BW-Anywhere, it is valid
rocessReplacedPlans: type BW-Anywhere replaces Locations
rocessReplacedPlans: id BW-Anywhere replaces Locations
rocessReplacedPlans: new_id=Starcode, it is valid
Sep 12 11:55:17.561 [DEBUG0] PHN: ReplacementPlan:
rocessReplacedPlans: new_id=BW-ACD, it is valid
rocessReplacedPlans: type BW-ACD replaces ACD
rocessReplacedPlans: id BW-ACD replaces ACD
rocessReplacedPlans: new_id=XMPP-ContactPresence, it is valid
rocessReplacedPlans: type XMPP-ContactPresence replaces XMPP Presence
rocessReplacedPlans: id XMPP-ContactPresence replaces XMPP Presence
rocessReplacedPlans: new_id=UserInputAndSendSipInfo, it is valid
Sep 12 11:55:17.562 [DEBUG0] PHN: ReplacementPlan:
rocessReplacedPlans: new_id=SendSipInfo, it is valid
rocessReplacedPlans: new_id=user_event_list_uri, it is valid
Sep 12 11:55:17.604 [DEBUG0] PHN: apply_value: codec_priority_list = 'g722,pcmu,pcma,amr-0,amrwb-0,gsm,g723,g726-32,aal2-g726-32,g729,telephone-event', set.need_apply: 0, finished: 0, need reboot to apply: 0
Sep 12 11:55:17.605 [DEBUG0] PHN: apply_value: codec_priority_list = 'g722,pcmu,pcma,amr-0,amrwb-0,gsm,g723,g726-32,aal2-g726-32,g729,telephone-event', set.need_apply: 0, finished: 0, need reboot to apply: 0
Sep 12 11:55:17.606 [DEBUG0] PHN: apply_value: codec_priority_list = 'g722,pcmu,pcma,amr-0,amrwb-0,gsm,g723,g726-32,aal2-g726-32,g729,telephone-event', set.need_apply: 0, finished: 0, need reboot to apply: 0
Sep 12 11:55:17.607 [NOTICE] TOOLS: Disabling core dump succeeded
Sep 12 11:55:17.607 [INFO ] PHN: Settings init : 21 ms
Sep 12 11:55:17.607 [INFO ] PHN: Settings old : 54 ms
Sep 12 11:55:17.608 [INFO ] PHN: Settings xml : 85 ms
Sep 12 11:55:17.608 [INFO ] PHN: Settings extra : 238 ms
Sep 12 11:55:17.608 [INFO ] PHN: Settings repair: 243 ms
Sep 12 11:55:17.609 [NOTICE] PHN: Starting dns proxy...
Sep 12 11:55:17.942 [INFO ] PHN: SwitchDevice::SetPortProperties() Port:LAN | Properties:auto
Sep 12 11:55:17.943 [INFO ] PHN: SwitchDeviceEthtool::SetPortProperties() PRE - Port: LAN | AutoNeg: 1 | Speed: 1000 | Duplex: 1 | Advertise: 239 | PAutoNeg: 1 | PRx: 0 | PTx: 0
Sep 12 11:55:17.943 [INFO ] PHN: SwitchDevice::SetPortProperties() Port
C | Properties:auto
Sep 12 11:55:17.944 [INFO ] PHN: SwitchDeviceEthtool::SetPortProperties() PRE - Port: PC | AutoNeg: 1 | Speed: 10 | Duplex: 0 | Advertise: 239 | PAutoNeg: 1 | PRx: 0 | PTx: 0
Sep 12 11:55:17.961 [INFO ] UDEV: Udev monitor is initialised
Sep 12 11:55:17.964 [DEBUG0] UXM: USB expansion module manager initialization
Sep 12 11:55:17.965 [DEBUG0] UXM: Connect to USB device manager.
Sep 12 11:55:17.965 [NOTICE] DSK: Storage manager initialization
Sep 12 11:55:17.966 [INFO ] PHN: BOTV is empty.
Sep 12 11:55:17.966 [NOTICE] GUI: Display re-enabled.
Sep 12 11:55:17.978 [DEBUG0] UXM: Request LED 0 0 Off Orange
Sep 12 11:55:17.978 [DEBUG0] UXM: Requested device 0 isn't connected
Sep 12 11:55:17.978 [DEBUG0] UXM: Request LED 0 1 Off Orange
Sep 12 11:55:17.978 [DEBUG0] UXM: Request LED 0 2 Off Orange
Sep 12 11:55:17.979 [DEBUG0] UXM: Request LED 0 3 Off Orange
Sep 12 11:55:17.979 [DEBUG0] UXM: Requested device 0 isn't connected
Sep 12 11:55:17.979 [DEBUG0] UXM: Request LED 0 4 Off Orange
Sep 12 11:55:17.979 [DEBUG0] UXM: Request LED 0 5 Off Orange
Sep 12 11:55:17.980 [DEBUG0] UXM: Request LED 0 6 Off Orange
Sep 12 11:55:17.980 [DEBUG0] UXM: Requested device 0 isn't connected
Sep 12 11:55:17.980 [DEBUG0] UXM: Request LED 0 7 Off Orange
Sep 12 11:55:17.980 [DEBUG0] UXM: Request LED 0 8 Off Orange
Sep 12 11:55:17.980 [DEBUG0] UXM: Request LED 0 9 Off Orange
Sep 12 11:55:17.981 [DEBUG0] UXM: Requested device 0 isn't connected
Sep 12 11:55:17.981 [DEBUG0] UXM: Request LED 0 10 Off Orange
Sep 12 11:55:17.981 [DEBUG0] UXM: Request LED 0 11 Off Orange
Sep 12 11:55:17.981 [DEBUG0] UXM: Request LED 0 12 Off Orange
Sep 12 11:55:17.982 [DEBUG0] UXM: Request LED 0 13 Off Orange
Sep 12 11:55:17.982 [DEBUG0] UXM: Requested device 0 isn't connected
Sep 12 11:55:17.982 [DEBUG0] UXM: Request LED 0 14 Off Orange
Sep 12 11:55:17.982 [DEBUG0] UXM: Request LED 0 15 Off Orange
Sep 12 11:55:17.982 [DEBUG0] UXM: Request LED 0 16 Off Orange
Sep 12 11:55:17.983 [DEBUG0] UXM: Requested device 0 isn't connected
Sep 12 11:55:17.983 [DEBUG0] UXM: Request LED 0 17 Off Orange
Sep 12 11:55:17.984 [DEBUG0] UXM: Request LED 1 18 Off Orange
Sep 12 11:55:17.984 [DEBUG0] UXM: Requested device 1 isn't connected
Sep 12 11:55:17.984 [DEBUG0] UXM: Request LED 1 19 Off Orange
Sep 12 11:55:17.985 [DEBUG0] UXM: Requested device 1 isn't connected
Sep 12 11:55:17.985 [DEBUG0] UXM: Request LED 1 20 Off Orange
Sep 12 11:55:17.985 [DEBUG0] UXM: Request LED 1 21 Off Orange
Sep 12 11:55:17.985 [DEBUG0] UXM: Request LED 1 22 Off Orange
Sep 12 11:55:17.986 [DEBUG0] UXM: Request LED 1 23 Off Orange
Sep 12 11:55:17.986 [DEBUG0] UXM: Requested device 1 isn't connected
Sep 12 11:55:17.986 [DEBUG0] UXM: Request LED 1 24 Off Orange
Sep 12 11:55:17.986 [DEBUG0] UXM: Request LED 1 25 Off Orange
Sep 12 11:55:17.986 [DEBUG0] UXM: Request LED 1 26 Off Orange
Sep 12 11:55:17.987 [DEBUG0] UXM: Requested device 1 isn't connected
Sep 12 11:55:17.987 [DEBUG0] UXM: Request LED 1 27 Off Orange
Sep 12 11:55:17.987 [DEBUG0] UXM: Request LED 1 28 Off Orange
Sep 12 11:55:17.987 [DEBUG0] UXM: Request LED 1 29 Off Orange
Sep 12 11:55:17.988 [DEBUG0] UXM: Request LED 1 30 Off Orange
Sep 12 11:55:17.988 [DEBUG0] UXM: Requested device 1 isn't connected
Sep 12 11:55:17.988 [DEBUG0] UXM: Request LED 1 31 Off Orange
Sep 12 11:55:17.988 [DEBUG0] UXM: Request LED 1 32 Off Orange
Sep 12 11:55:17.989 [DEBUG0] UXM: Request LED 1 33 Off Orange
Sep 12 11:55:17.989 [DEBUG0] UXM: Requested device 1 isn't connected
Sep 12 11:55:17.989 [DEBUG0] UXM: Request LED 1 34 Off Orange
Sep 12 11:55:17.989 [DEBUG0] UXM: Request LED 1 35 Off Orange
Sep 12 11:55:17.990 [DEBUG0] UXM: Request LED 2 36 Off Orange
Sep 12 11:55:17.990 [DEBUG0] UXM: Requested device 2 isn't connected
Sep 12 11:55:17.990 [DEBUG0] UXM: Request LED 2 37 Off Orange
Sep 12 11:55:17.990 [DEBUG0] UXM: Request LED 2 38 Off Orange
Sep 12 11:55:17.990 [DEBUG0] UXM: Request LED 2 39 Off Orange
Sep 12 11:55:17.991 [DEBUG0] UXM: Requested device 2 isn't connected
Sep 12 11:55:17.991 [DEBUG0] UXM: Request LED 2 40 Off Orange
Sep 12 11:55:17.991 [DEBUG0] UXM: Request LED 2 41 Off Orange
Sep 12 11:55:17.991 [DEBUG0] UXM: Request LED 2 42 Off Orange
Sep 12 11:55:17.992 [DEBUG0] UXM: Request LED 2 43 Off Orange
Sep 12 11:55:17.992 [DEBUG0] UXM: Requested device 2 isn't connected
Sep 12 11:55:17.992 [DEBUG0] UXM: Request LED 2 44 Off Orange
Sep 12 11:55:17.992 [DEBUG0] UXM: Request LED 2 45 Off Orange
Sep 12 11:55:17.992 [DEBUG0] UXM: Request LED 2 46 Off Orange
Sep 12 11:55:17.993 [DEBUG0] UXM: Requested device 2 isn't connected
Sep 12 11:55:17.993 [DEBUG0] UXM: Request LED 2 47 Off Orange
Sep 12 11:55:17.994 [DEBUG0] UXM: Request LED 2 48 Off Orange
Sep 12 11:55:17.995 [DEBUG0] UXM: Requested device 2 isn't connected
Sep 12 11:55:17.995 [DEBUG0] UXM: Request LED 2 49 Off Orange
Sep 12 11:55:17.995 [DEBUG0] UXM: Request LED 2 50 Off Orange
Sep 12 11:55:17.995 [DEBUG0] UXM: Request LED 2 51 Off Orange
Sep 12 11:55:17.996 [DEBUG0] UXM: Request LED 2 52 Off Orange
Sep 12 11:55:17.996 [DEBUG0] UXM: Requested device 2 isn't connected
Sep 12 11:55:17.996 [DEBUG0] UXM: Request LED 2 53 Off Orange
Sep 12 11:55:18.000 [INFO ] PHN: Entering setup_language(): gui:1, web:1, add:1
Sep 12 11:55:18.000 [INFO ] PHN: Gui lang old:unknown, new
eutsch
Sep 12 11:55:18.000 [INFO ] PHN: Web lang old:, new
eutsch
Sep 12 11:55:18.000 [INFO ] PHN: Currently displaying: gui:, web:
Sep 12 11:55:18.000 [INFO ] PHN: Adding local gui languages from flash to list!
Sep 12 11:55:18.037 [NOTICE] PHN: Fast read of /snom/snomlang/gui_lang_AE.xml successful.
Sep 12 11:55:18.037 [INFO ] PHN: Adding gui lang:Arabic, fn:/snom/snomlang/gui_lang_AE.xml, stored
eutsch
Sep 12 11:55:18.051 [NOTICE] PHN: Fast read of /snom/snomlang/gui_lang_CA.xml successful.
Sep 12 11:55:18.051 [INFO ] PHN: Adding gui lang:Català, fn:/snom/snomlang/gui_lang_CA.xml, stored
eutsch
Sep 12 11:55:18.069 [NOTICE] PHN: Fast read of /snom/snomlang/gui_lang_BS.xml successful.
Sep 12 11:55:18.069 [INFO ] PHN: Adding gui lang:Bosanski, fn:/snom/snomlang/gui_lang_BS.xml, stored
eutsch
Sep 12 11:55:18.089 [NOTICE] PHN: Fast read of /snom/snomlang/gui_lang_DA.xml successful.
Sep 12 11:55:18.090 [INFO ] PHN: Adding gui lang
ansk, fn:/snom/snomlang/gui_lang_DA.xml, stored
eutsch
Sep 12 11:55:18.105 [NOTICE] PHN: Fast read of /snom/snomlang/gui_lang_DE.xml successful.
Sep 12 11:55:18.105 [INFO ] PHN: Adding gui lang
eutsch, fn:/snom/snomlang/gui_lang_DE.xml, stored
eutsch
Sep 12 11:55:18.120 [NOTICE] PHN: Fast read of /snom/snomlang/gui_lang_CS.xml successful.
Sep 12 11:55:18.120 [INFO ] PHN: Adding gui lang:Čeština, fn:/snom/snomlang/gui_lang_CS.xml, stored
eutsch
Sep 12 11:55:18.148 [NOTICE] PHN: Fast read of /snom/snomlang/gui_lang_EL.xml successful.
Sep 12 11:55:18.148 [INFO ] PHN: Adding gui lang:Ελληνικά, fn:/snom/snomlang/gui_lang_EL.xml, stored
eutsch
Sep 12 11:55:18.163 [NOTICE] PHN: Fast read of /snom/snomlang/gui_lang_EN.xml successful.
Sep 12 11:55:18.163 [INFO ] PHN: Adding gui lang:English, fn:/snom/snomlang/gui_lang_EN.xml, stored
eutsch
Sep 12 11:55:18.176 [NOTICE] PHN: Fast read of /snom/snomlang/gui_lang_ES.xml successful.
Sep 12 11:55:18.177 [INFO ] PHN: Adding gui lang:Español, fn:/snom/snomlang/gui_lang_ES.xml, stored
eutsch
Sep 12 11:55:18.190 [NOTICE] PHN: Fast read of /snom/snomlang/gui_lang_FI.xml successful.
Sep 12 11:55:18.190 [INFO ] PHN: Adding gui lang:Suomi, fn:/snom/snomlang/gui_lang_FI.xml, stored
eutsch
Sep 12 11:55:18.205 [NOTICE] PHN: Fast read of /snom/snomlang/gui_lang_ET.xml successful.
Sep 12 11:55:18.205 [INFO ] PHN: Adding gui lang:Eesti, fn:/snom/snomlang/gui_lang_ET.xml, stored
eutsch
Sep 12 11:55:18.218 [NOTICE] PHN: Fast read of /snom/snomlang/gui_lang_FR.xml successful.
Sep 12 11:55:18.218 [INFO ] PHN: Adding gui lang:Français, fn:/snom/snomlang/gui_lang_FR.xml, stored
eutsch
Sep 12 11:55:18.233 [NOTICE] PHN: Fast read of /snom/snomlang/gui_lang_HE.xml successful.
Sep 12 11:55:18.233 [INFO ] PHN: Adding gui lang:Hebrew, fn:/snom/snomlang/gui_lang_HE.xml, stored
eutsch
Sep 12 11:55:18.249 [NOTICE] PHN: Fast read of /snom/snomlang/gui_lang_HU.xml successful.
Sep 12 11:55:18.249 [INFO ] PHN: Adding gui lang:Magyar, fn:/snom/snomlang/gui_lang_HU.xml, stored
eutsch
Sep 12 11:55:18.263 [NOTICE] PHN: Fast read of /snom/snomlang/gui_lang_IT.xml successful.
Sep 12 11:55:18.263 [INFO ] PHN: Adding gui lang:Italiano, fn:/snom/snomlang/gui_lang_IT.xml, stored
eutsch
Sep 12 11:55:18.279 [NOTICE] PHN: Fast read of /snom/snomlang/gui_lang_LT.xml successful.
Sep 12 11:55:18.279 [INFO ] PHN: Adding gui lang:Lietuvių, fn:/snom/snomlang/gui_lang_LT.xml, stored
eutsch
Sep 12 11:55:18.295 [NOTICE] PHN: Fast read of /snom/snomlang/gui_lang_LV.xml successful.
Sep 12 11:55:18.295 [INFO ] PHN: Adding gui lang:Latviešu, fn:/snom/snomlang/gui_lang_LV.xml, stored
eutsch
Sep 12 11:55:18.308 [NOTICE] PHN: Fast read of /snom/snomlang/gui_lang_NL.xml successful.
Sep 12 11:55:18.308 [INFO ] PHN: Adding gui lang:Nederlands, fn:/snom/snomlang/gui_lang_NL.xml, stored
eutsch
Sep 12 11:55:18.323 [NOTICE] PHN: Fast read of /snom/snomlang/gui_lang_NO.xml successful.
Sep 12 11:55:18.323 [INFO ] PHN: Adding gui lang:Norsk, fn:/snom/snomlang/gui_lang_NO.xml, stored
eutsch
Sep 12 11:55:18.340 [NOTICE] PHN: Fast read of /snom/snomlang/gui_lang_PL.xml successful.
Sep 12 11:55:18.340 [INFO ] PHN: Adding gui lang
olski, fn:/snom/snomlang/gui_lang_PL.xml, stored
eutsch
Sep 12 11:55:18.356 [NOTICE] PHN: Fast read of /snom/snomlang/gui_lang_PT.xml successful.
Sep 12 11:55:18.356 [INFO ] PHN: Adding gui lang
ortuguês, fn:/snom/snomlang/gui_lang_PT.xml, stored
eutsch
Sep 12 11:55:18.370 [NOTICE] PHN: Fast read of /snom/snomlang/gui_lang_SI.xml successful.
Sep 12 11:55:18.370 [INFO ] PHN: Adding gui lang:Slovenščina, fn:/snom/snomlang/gui_lang_SI.xml, stored
eutsch
Sep 12 11:55:18.391 [NOTICE] PHN: Fast read of /snom/snomlang/gui_lang_RU.xml successful.
Sep 12 11:55:18.391 [INFO ] PHN: Adding gui lang:Русский, fn:/snom/snomlang/gui_lang_RU.xml, stored
eutsch
Sep 12 11:55:18.407 [NOTICE] PHN: Fast read of /snom/snomlang/gui_lang_SV.xml successful.
Sep 12 11:55:18.407 [INFO ] PHN: Adding gui lang:Svenska, fn:/snom/snomlang/gui_lang_SV.xml, stored
eutsch
Sep 12 11:55:18.421 [NOTICE] PHN: Fast read of /snom/snomlang/gui_lang_TR.xml successful.
Sep 12 11:55:18.421 [INFO ] PHN: Adding gui lang:Türkçe, fn:/snom/snomlang/gui_lang_TR.xml, stored
eutsch
Sep 12 11:55:18.436 [NOTICE] PHN: Fast read of /snom/snomlang/gui_lang_UK.xml successful.
Sep 12 11:55:18.436 [INFO ] PHN: Adding gui lang:English(UK), fn:/snom/snomlang/gui_lang_UK.xml, stored
eutsch
Sep 12 11:55:18.437 [NOTICE] PHN: Using gui lang Deutsch at index:4 from: /snom/snomlang/gui_lang_DE.xml
Sep 12 11:55:18.437 [INFO ] PHN: ProvisioningReplacements: URL >/snom/snomlang/gui_lang_DE.xml<
Sep 12 11:55:18.438 [DEBUG0] PHN: Uri Replace >{mac}< in >/snom/snomlang/gui_lang_DE.xml<
Sep 12 11:55:18.438 [DEBUG0] PHN: Uri Replaced result: >/snom/snomlang/gui_lang_DE.xml<
Sep 12 11:55:18.439 [DEBUG0] PHN: ReplaceQueryVariables in >/snom/snomlang/gui_lang_DE.xml<
Sep 12 11:55:18.439 [DEBUG0] PHN: ReplaceQueryVariables replaced: >/snom/snomlang/gui_lang_DE.xml<
Sep 12 11:55:18.462 [DEBUG1] PHN: reading language /snom/snomlang/gui_lang_DE.xml
Sep 12 11:55:18.832 [DEBUG0] PHN: MonochromeFontInterface::ReloadFonts: reloading fonts
Sep 12 11:55:18.833 [ERROR ] PHN: FreeType::ReplaceFont: /snom/fonts/snomfont_v02.bdf not found
Sep 12 11:55:18.833 [ERROR ] PHN: FreeType::ReplaceFont: /snom/fonts/mono.ttf not found
Sep 12 11:55:18.833 [ERROR ] PHN: FreeType::ReplaceFont: /snom/fonts/mono-bold.ttf not found
Sep 12 11:55:18.833 [INFO ] PHN: Adding local web languages from flash to list!
Sep 12 11:55:18.852 [NOTICE] PHN: Fast read of /snom/snomlang/web_lang_BS.xml successful.
Sep 12 11:55:18.853 [INFO ] PHN: Adding web lang:Bosanski, fn:/snom/snomlang/web_lang_BS.xml
Sep 12 11:55:18.867 [NOTICE] PHN: Fast read of /snom/snomlang/web_lang_DA.xml successful.
Sep 12 11:55:18.867 [INFO ] PHN: Adding web lang
ansk, fn:/snom/snomlang/web_lang_DA.xml
Sep 12 11:55:18.882 [NOTICE] PHN: Fast read of /snom/snomlang/web_lang_DE.xml successful.
Sep 12 11:55:18.882 [INFO ] PHN: Adding web lang
eutsch, fn:/snom/snomlang/web_lang_DE.xml
Sep 12 11:55:18.898 [NOTICE] PHN: Fast read of /snom/snomlang/web_lang_CS.xml successful.
Sep 12 11:55:18.899 [INFO ] PHN: Adding web lang:Čeština, fn:/snom/snomlang/web_lang_CS.xml
Sep 12 11:55:18.913 [NOTICE] PHN: Fast read of /snom/snomlang/web_lang_EN.xml successful.
Sep 12 11:55:18.913 [INFO ] PHN: Adding web lang:English, fn:/snom/snomlang/web_lang_EN.xml
Sep 12 11:55:18.932 [NOTICE] PHN: Fast read of /snom/snomlang/web_lang_ES.xml successful.
Sep 12 11:55:18.932 [INFO ] PHN: Adding web lang:Español, fn:/snom/snomlang/web_lang_ES.xml
Sep 12 11:55:18.947 [NOTICE] PHN: Fast read of /snom/snomlang/web_lang_FI.xml successful.
Sep 12 11:55:18.948 [INFO ] PHN: Adding web lang:Suomi, fn:/snom/snomlang/web_lang_FI.xml
Sep 12 11:55:18.962 [NOTICE] PHN: Fast read of /snom/snomlang/web_lang_FR.xml successful.
Sep 12 11:55:18.962 [INFO ] PHN: Adding web lang:Français, fn:/snom/snomlang/web_lang_FR.xml
Sep 12 11:55:18.982 [NOTICE] PHN: Fast read of /snom/snomlang/web_lang_HE.xml successful.
Sep 12 11:55:18.982 [INFO ] PHN: Adding web lang:עברית, fn:/snom/snomlang/web_lang_HE.xml
Sep 12 11:55:18.999 [NOTICE] PHN: Fast read of /snom/snomlang/web_lang_HU.xml successful.
Sep 12 11:55:18.999 [INFO ] PHN: Adding web lang:Magyar, fn:/snom/snomlang/web_lang_HU.xml
Sep 12 11:55:19.014 [NOTICE] PHN: Fast read of /snom/snomlang/web_lang_IT.xml successful.
Sep 12 11:55:19.014 [INFO ] PHN: Adding web lang:Italiano, fn:/snom/snomlang/web_lang_IT.xml
Sep 12 11:55:19.032 [NOTICE] PHN: Fast read of /snom/snomlang/web_lang_LT.xml successful.
Sep 12 11:55:19.032 [INFO ] PHN: Adding web lang:Lietuvių, fn:/snom/snomlang/web_lang_LT.xml
Sep 12 11:55:19.046 [NOTICE] PHN: Fast read of /snom/snomlang/web_lang_NL.xml successful.
Sep 12 11:55:19.047 [INFO ] PHN: Adding web lang:Nederlands, fn:/snom/snomlang/web_lang_NL.xml
Sep 12 11:55:19.061 [NOTICE] PHN: Fast read of /snom/snomlang/web_lang_NO.xml successful.
Sep 12 11:55:19.061 [INFO ] PHN: Adding web lang:Norsk, fn:/snom/snomlang/web_lang_NO.xml
Sep 12 11:55:19.076 [NOTICE] PHN: Fast read of /snom/snomlang/web_lang_PT.xml successful.
Sep 12 11:55:19.076 [INFO ] PHN: Adding web lang
ortuguês, fn:/snom/snomlang/web_lang_PT.xml
Sep 12 11:55:19.090 [NOTICE] PHN: Fast read of /snom/snomlang/web_lang_SI.xml successful.
Sep 12 11:55:19.090 [INFO ] PHN: Adding web lang:Slovenščina, fn:/snom/snomlang/web_lang_SI.xml
Sep 12 11:55:19.115 [NOTICE] PHN: Fast read of /snom/snomlang/web_lang_RU.xml successful.
Sep 12 11:55:19.115 [INFO ] PHN: Adding web lang:Русский, fn:/snom/snomlang/web_lang_RU.xml
Sep 12 11:55:19.135 [NOTICE] PHN: Fast read of /snom/snomlang/web_lang_SV.xml successful.
Sep 12 11:55:19.135 [INFO ] PHN: Adding web lang:Svenska, fn:/snom/snomlang/web_lang_SV.xml
Sep 12 11:55:19.148 [NOTICE] PHN: Fast read of /snom/snomlang/web_lang_TR.xml successful.
Sep 12 11:55:19.148 [INFO ] PHN: Adding web lang:Türkçe, fn:/snom/snomlang/web_lang_TR.xml
Sep 12 11:55:19.149 [NOTICE] PHN: Using web lang /snom/snomlang/web_lang_DE.xml at index:2 from: /snom/snomlang/web_lang_DE.xml
Sep 12 11:55:19.149 [INFO ] PHN: ProvisioningReplacements: URL >/snom/snomlang/web_lang_DE.xml<
Sep 12 11:55:19.150 [DEBUG0] PHN: Uri Replace >{mac}< in >/snom/snomlang/web_lang_DE.xml<
Sep 12 11:55:19.150 [DEBUG0] PHN: Uri Replaced result: >/snom/snomlang/web_lang_DE.xml<
Sep 12 11:55:19.150 [DEBUG0] PHN: ReplaceQueryVariables in >/snom/snomlang/web_lang_DE.xml<
Sep 12 11:55:19.150 [DEBUG0] PHN: ReplaceQueryVariables replaced: >/snom/snomlang/web_lang_DE.xml<
Sep 12 11:55:19.180 [DEBUG1] PHN: reading language /snom/snomlang/web_lang_DE.xml
Sep 12 11:55:19.608 [NOTICE] GUI: Display disabled.
Sep 12 11:55:19.612 [DEBUG0] UXM: Request backlight for module -1 with value 15
Sep 12 11:55:19.612 [NOTICE] PHN: ProvUtils::UcLookUpFirmwareUpdateViaDNS: domain: >Herrmann.local<
Sep 12 11:55:19.612 [NOTICE] PHN: ProvUtils::UcSendFirmwareUpdateAvailableRequest: enabled: 1; url: >https://ucupdates-r2.Herrmann.local/RequestHandler/ucdevice.upx<; id: ><
Sep 12 11:55:19.613 [NOTICE] PHN: ProvUtils::UcSendFirmwareUpdateAvailableRequest: request: ><Request><DeviceType>3PIP</DeviceType><MacAddress>00-04-13-75-C4-23</MacAddress><SerialNumber>NA</SerialNumber><IP>192.168.1.189</IP><UserID></UserID><NumOfFiles>1</NumOfFiles><LocaleID>ENU</LocaleID><Vendor>Snom</Vendor><Model>snom715</Model><Revision>AB</Revision><CurrentTime>2011-10-14T08:07:30</CurrentTime><CurrentModule><FileName>cpe.nbt</FileName><FileVersion><Major>8</Major><Minor>9</Minor><Build>3</Build><QFE>96</QFE><TimeStamp>2009-12-10T11:31:30</TimeStamp></FileVersion></CurrentModule></Request><
Sep 12 11:55:19.618 [DEBUG2] WEBCLIENT: Send TCP none
Sep 12 11:55:19.620 [DEBUG2] WEBCLIENT: Socket 17 dns_resolving
Sep 12 11:55:19.647 [DEBUG0] SIP: Udp listener connected
Sep 12 11:55:19.648 [INFO ] SIP: opened udp port 34275
Sep 12 11:55:19.648 [DEBUG0] SIP: sip_interface::SipIcmpStateCb: ICMP listener connected
Sep 12 11:55:19.649 [DEBUG2] PHN: IPv4 Defending: ip 192.168.1.189, mode detect_defend
Sep 12 11:55:19.651 [INFO ] PHN: IPv4: Start Defending 192.168.1.189 (0) on device eth0
Sep 12 11:55:19.673 [INFO ] PHN: IPv4: Init Device eth0 with mac 00:04:13:75:C4:23
Sep 12 11:55:19.673 [DEBUG1] PHN: IPv4: Device eth0, IP , State device init
Sep 12 11:55:19.674 [DEBUG0] PHN: IPv4: Start Defending on eth0, IP 192.168.1.189
Sep 12 11:55:19.675 [DEBUG1] PHN: IPv4: Device eth0, IP 192.168.1.189, State defend no conflict
Sep 12 11:55:19.675 [DEBUG2] PHN: SNMP: socket 18/connected Udp:0.0.0.0:161
Sep 12 11:55:19.675 [INFO ] PHN: SNMP: listen on 161
Sep 12 11:55:19.708 [DEBUG0] PHN: Requested phone certificate type is 'best'.
Sep 12 11:55:19.709 [DEBUG0] PHN: Failed to load individual SHA-256 phone certificate and private key!
Sep 12 11:55:19.788 [DEBUG0] PHN: Individual SHA-1 phone certificate and private key loaded.
Sep 12 11:55:19.790 [NOTICE] PHN: Phone certificate and private key successfully loaded.
Sep 12 11:55:19.792 [WARN ] TLS: PhoneCtx: cert verification disabled!
Sep 12 11:55:19.921 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//5D56499BE4D2E08BCFCAD08A3E38723D50503BDE706948E42F55603019E528AE.der
Sep 12 11:55:19.930 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//5EDB7AC43B82A06A8761E8D7BE4979EBF2611F7DD79BF91C1C6B566A219ED766.der
Sep 12 11:55:19.936 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//73C176434F1BC6D5ADF45B0E76E727287C8DE57616C1E6E6141A2B2CBC7D8E4C.der
Sep 12 11:55:19.939 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//7431E5F4C3C1CE4690774F0B61E05440883BA9A01ED00BA6ABD7806ED3B118CF.der
Sep 12 11:55:19.945 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//C0A6F4DC63A24BFDCF54EF2A6A082A0A72DE35803E2FF5FF527AE5D87206DFD5.der
Sep 12 11:55:19.948 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//BD71FDF6DA97E4CF62D1647ADD2581B07D79ADF8397EB4ECBA9C5E8488821423.der
Sep 12 11:55:19.955 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//46EDC3689046D53A453FB3104AB80DCAEC658B2660EA1629DD7E867990648716.der
Sep 12 11:55:19.958 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//A1339D33281A0B56E557D3D32B1CE7F9367EB094BD5FA72A7E5004C8DED7CAFE.der
Sep 12 11:55:19.964 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//4B03F45807AD70F21BFC2CAE71C9FDE4604C064CF5FFB686BAE5DBAAD7FDD34C.der
Sep 12 11:55:19.967 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//GeoTrust_Global_CA2_DER.cer.DER
Sep 12 11:55:19.973 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//8D722F81A9C113C0791DF136A2966DB26C950A971DB46B4199F4EA54B78BFB9F.der
Sep 12 11:55:19.978 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//69DDD7EA90BB57C93E135DC85EA6FCD5480B603239BDC454FC758B2A26CF7F79.der
Sep 12 11:55:19.981 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//16AF57A9F676B0AB126095AA5EBADEF22AB31119D644AC95CD4B93DBF3F26AEB.der
Sep 12 11:55:19.988 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//0C2CD63DF7806FA399EDE809116B575BF87989F06518F9808C860503178BAF66.der
Sep 12 11:55:19.993 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//4FF460D54B9C86DABFBCFC5712E0400D2BED3FBC4D4FBDAA86E06ADCD2A9AD7A.der
Sep 12 11:55:19.999 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//CB627D18B58AD56DDE331A30456BC65C601A4E9B18DEDCEA08E7DAAA07815FF0.der
Sep 12 11:55:20.004 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//43F257412D440D627476974F877DA8F1FC2444565A367AE60EDDC27A412531AE.der
Sep 12 11:55:20.009 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//4D2491414CFE956746EC4CEFA6CF6F72E28A1329432F9D8A907AC4CB5DADC15A.der
Sep 12 11:55:20.015 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//37D51006C512EAAB626421F1EC8C92013FC5F82AE98EE533EB4619B8DEB4D06C.der
Sep 12 11:55:20.018 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//49E7A442ACF0EA6287050054B52564B650E4F49E42E348D6AA38E039E957B1C1.der
Sep 12 11:55:20.025 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//568D6905A2C88708A4B3025190EDCFEDB1974A606A13C6E5290FCB2AE63EDAB5.der
Sep 12 11:55:20.028 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//A0234F3BC8527CA5628EEC81AD5D69895DA5680DC91D1CB8477F33F878B95B0B.der
Sep 12 11:55:20.035 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//B6191A50D0C3977F7DA99BCDAAC86A227DAEB9679EC70BA3B0C9D92271C170D3.der
Sep 12 11:55:20.040 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//1793927A0614549789ADCE2F8F34F7F0B66D0F3AE3A3B84D21EC15DBBA4FADC7.der
Sep 12 11:55:20.045 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//EF3CB417FC8EBF6F97876C9E4ECE39DE1EA5FE649141D1028B7D11C0B2298CED.der
Sep 12 11:55:20.050 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//CA42DD41745FD0B81EB902362CF9D8BF719DA1BD1B1EFC946F5B4C99F42C1B9E.der
Sep 12 11:55:20.056 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//A45EDE3BBBF09C8AE15C72EFC07268D693A21C996FD51E67CA079460FD6D8873.der
Sep 12 11:55:20.061 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//2CE1CB0BF9D2F9E102993FBE215152C3B2DD0CABDE1C68E5319B839154DBB7F5.der
Sep 12 11:55:20.067 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//4348A0E9444C78CB265E058D5E8944B4D84F9662BD26DB257F8934A443C70161.der
Sep 12 11:55:20.070 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//30D0895A9A448A262091635522D1F52010B5867ACAE12C78EF958FD4F4389F2F.der
Sep 12 11:55:20.073 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//DD6936FE21F8F077C123A1A521C12224F72255B73E03A7260693E8A24B0FA389.der
Sep 12 11:55:20.078 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//85A0DD7DD720ADB7FF05F83D542B209DC7FF4528F7D677B18389FEA5E5C49E86.der
Sep 12 11:55:20.081 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//EB04CF5EB1F39AFA762F2BB120F296CBA520C1B97DB1589565B81CB9A17B7244.der
Sep 12 11:55:20.087 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//B7C36231706E81078C367CB896198F1E3208DD926949DD8F5709A410F75B6292.der
Sep 12 11:55:20.092 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//92A9D9833FE1944DB366E8BFAE7A95B6480C2D6C6C2A1BE65D4236B608FCA1BB.der
Sep 12 11:55:20.097 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//CECDDC905099D8DADFC5B1D209B737CBE2C18CFB2C10C0FF0BCF0D3286FC1AA2.der
Sep 12 11:55:20.102 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//Thawte_SSL_CA.crt.DER
Sep 12 11:55:20.108 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//Thawte_SGC_CA_-_G2.crt.DER
Sep 12 11:55:20.111 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//FF856A2D251DCD88D36656F450126798CFABAADE40799C722DE4D2B5DB36A73A.der
Sep 12 11:55:20.117 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//152A402BFCDF2CD548054D2275B39C7FCA3EC0978078B0F0EA76E561A6C7433E.der
Sep 12 11:55:20.122 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//8FE4FB0AF93A4D0D67DB0BEBB23E37C71BF325DCBCDD240EA04DAF58B47E1840.der
Sep 12 11:55:20.131 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//FD73DAD31C644FF1B43BEF0CCDDA96710B9CD9875ECA7E31707AF3E96D522BBD.der
Sep 12 11:55:20.135 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//960ADF0063E96356750C2965DD0A0867DA0B9CBD6E77714AEAFB2349AB393DA3.der
Sep 12 11:55:20.140 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//BFFF8FD04433487D6A8AA60C1A29767A9FC2BBB05E420F713A13B992891D3893.der
Sep 12 11:55:20.147 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//88497F01602F3154246AE28C4D5AEF10F1D87EBB76626F4AE0B7F95BA7968799.der
Sep 12 11:55:20.152 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//A6C51E0DA5CA0A9309D2E4C0E40C2AF9107AAE8203857FE198E3E769E343085C.der
Sep 12 11:55:20.157 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//0C258A12A5674AEF25F28BA7DCFAECEEA348E541E6F5CC4EE63B71B361606AC3.der
Sep 12 11:55:20.161 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//4200F5043AC8590EBB527D209ED1503029FBCBD41CA1B506EC27F15ADE7DAC69.der
Sep 12 11:55:20.165 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//24F91C0705A0A5338641B365FB0D9D9709B56297CFF1857E73C02C1636D486AA.der
Sep 12 11:55:20.171 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//GTE_CyberTrust_Global_Root.pem.DER
Sep 12 11:55:20.176 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//Verisign_Class_3_Public_Primary_Certification_Authority.cer.DER
Sep 12 11:55:20.180 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//3C5F81FEA5FAB82C64BFA2EAECAFCDE8E077FC8620A7CAE537163DF36EDBF378.der
Sep 12 11:55:20.186 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//668C83947DA63B724BECE1743C31A0E6AED0DB8EC5B31BE377BB784F91B6716F.der
Sep 12 11:55:20.190 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//7600295EEFE85B9E1FD624DB76062AAAAE59818A54D2774CD4C0B2C01131E1B3.der
Sep 12 11:55:20.195 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//D8E0FEBC1DB2E38D00940F37D27D41344D993E734B99D5656D9778D4D8143624.der
Sep 12 11:55:20.198 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//Equifax_Secure_eBusiness_CA-1_DER.cer.DER
Sep 12 11:55:20.204 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//70A73F7F376B60074248904534B11482D5BF0E698ECC498DF52577EBF2E93B9A.der
Sep 12 11:55:20.208 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//3E84BA4342908516E77573C0992F0979CA084E4685681FF195CCBA8A229B8A76.der
Sep 12 11:55:20.215 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//Snom_Certification_Authority.pem.DER
Sep 12 11:55:20.220 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//9A6EC012E1A7DA9DBE34194D478AD7C0DB1822FB071DF12981496ED104384113.der
Sep 12 11:55:20.226 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//CB3CCBB76031E5E0138F8DD39A23F9DE47FFC35E43C1144CEA27D46A5AB1CB5F.der
Sep 12 11:55:20.230 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//27995829FE6A7515C1BFE848F9C4761DB16C225929257BF40D0894F29EA8BAF2.der
Sep 12 11:55:20.236 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//9A114025197C5BB95D94E63D55CD43790847B646B23CDF11ADA4A00EFF15FB48.der
Sep 12 11:55:20.241 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//3B222E566711E992300DC0B15AB9473DAFDEF8C84D0CEF7D3317B4C1821D1436.der
Sep 12 11:55:20.246 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//Verisign_Class_1_Public_Primary_Certification_Authority_-_G2.pem.DER
Sep 12 11:55:20.252 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//B0BFD52BB0D7D9BD92BF5D4DC13DA255C02C542F378365EA893911F55E55F23C.der
Sep 12 11:55:20.259 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//44B545AA8A25E65A73CA15DC27FC36D24C1CB9953A066539B11582DC487B4833.der
Sep 12 11:55:20.263 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//Verisign_Class_2_Public_Primary_Certification_Authority.pem.DER
Sep 12 11:55:20.267 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//F356BEA244B7A91EB35D53CA9AD7864ACE018E2D35D5F8F96DDF68A6F41AA474.der
Sep 12 11:55:20.272 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//BF0FEEFB9E3A581AD5F9E9DB7589985743D261085C4D314F6F5D7259AA421612.der
Sep 12 11:55:20.278 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//5CC3D78E4E1D5E45547A04E6873E64F90CF9536D1CCC2EF800F355C4C5FD70FD.der
Sep 12 11:55:20.282 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//F9E67D336C51002AC054C632022D66DDA2E7E3FFF10AD061ED31D8BBB410CFB2.der
Sep 12 11:55:20.286 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//GTE_CyberTrust_Global_Root.crt.DER
Sep 12 11:55:20.292 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//2530CC8E98321502BAD96F9B1FBA1B099E2D299E0F4548BB914F363BC0D4531F.der
Sep 12 11:55:20.298 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//45140B3247EB9CC8C5B4F0D7B53091F73292089E6E5A63E2749DD3ACA9198EDA.der
Sep 12 11:55:20.302 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//88EF81DE202EB018452E43F864725CEA5FBD1FC2D9D205730709C5D8B8690F46.der
Sep 12 11:55:20.308 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//EEC5496B988CE98625B934092EEC2908BED0B0F316C2D4730C84EAF1F3D34881.der
Sep 12 11:55:20.315 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//9D190B2E314566685BE8A889E27AA8C7D7AE1D8AADDBA3C1ECF9D24863CD34B9.der
Sep 12 11:55:20.319 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//3E9099B5015E8F486C00BCEA9D111EE721FABA355A89BCF1DF69561E3DC6325C.der
Sep 12 11:55:20.330 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//F09B122C7114F4A09BD4EA4F4A99D558B46E4C25CD81140D29C05613914C3841.der
Sep 12 11:55:20.337 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//E793C9B02FD8AA13E21C31228ACCB08119643B749C898964B1746D46C3D4CBD2.der
Sep 12 11:55:20.342 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//1465FA205397B876FAA6F0A9958E5590E40FCC7FAA4FB7C2C8677521FB5FB658.der
Sep 12 11:55:20.348 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//6CC05041E6445E74696C4CFBC9F80F543B7EABBB44B4CE6F787C6A9971C42F17.der
Sep 12 11:55:20.353 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//2E7BF16CC22485A7BBE2AA8696750761B0AE39BE3B2FE9D0CC6D4EF73491425C.der
Sep 12 11:55:20.360 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//31AD6648F8104138C738F39EA4320133393E3A18CC02296EF97C2AC9EF6731D0.der
Sep 12 11:55:20.366 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//F1C1B50AE5A20DD8030EC9F6BC24823DD367B5255759B4E71B61FCE9F7375D73.der
Sep 12 11:55:20.369 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//18CE6CFE7BF14E60B2E347B8DFE868CB31D02EBB3ADA271569F50343B46DB3A4.der
Sep 12 11:55:20.376 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//CBB5AF185E942A2402F9EACBC0ED5BB876EEA3C1223623D00447E4F3BA554B65.der
Sep 12 11:55:20.381 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//EDF7EBBCA27A2A384D387B7D4010C666E2EDB4843E4C29B4AE1D5B9332E6B24D.der
Sep 12 11:55:20.388 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//54455F7129C20B1447C418F997168F24C58FC5023BF5DA5BE2EB6E1DD8902ED5.der
Sep 12 11:55:20.395 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//entrust_ssl_ca.der
Sep 12 11:55:20.399 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//7D05EBB682339F8C9451EE094EEBFEFA7953A114EDB2F44949452FAB7D2FC185.der
Sep 12 11:55:20.405 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//7E37CB8B4C47090CAB36551BA6F45DB840680FBA166A952DB100717F43053FC2.der
Sep 12 11:55:20.409 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//AE4457B40D9EDA96677B0D3C92D57B5177ABD7AC1037958356D1E094518BE5F2.der
Sep 12 11:55:20.413 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//www.valicert.com.der
Sep 12 11:55:20.420 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//52F0E1C4E58EC629291B60317F074671B85D7EA80D5B07273463534B32B40234.der
Sep 12 11:55:20.425 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//A1A86D04121EB87F027C66F53303C28E5739F943FC84B38AD6AF009035DD9457.der
Sep 12 11:55:20.430 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//6C61DAC3A2DEF031506BE036D2A6FE401994FBD13DF9C8D466599274C446EC98.der
Sep 12 11:55:20.435 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//Verisign_Class_1_Public_Primary_Certification_Authority.pem.DER
Sep 12 11:55:20.439 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//7908B40314C138100B518D0735807FFBFCF8518A0095337105BA386B153DD927.der
Sep 12 11:55:20.445 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//A040929A02CE53B4ACF4F2FFC6981CE4496F755E6D45FE0B2A692BCD52523F36.der
Sep 12 11:55:20.449 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//513B2CECB810D4CDE5DD85391ADFC6C2DD60D87BB736D2B521484AA47A0EBEF6.der
Sep 12 11:55:20.456 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//Snom_Certification_Authority_SHA256.pem.DER
Sep 12 11:55:20.462 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//B676F2EDDAE8775CD36CB0F63CD1D4603961F49E6265BA013A2F0307B6D0B804.der
Sep 12 11:55:20.466 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//0F993C8AEF97BAAF5687140ED59AD1821BB4AFACF0AA9A58B5D57A338A3AFBCB.der
Sep 12 11:55:20.472 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//1BA5B2AA8C65401A82960118F80BEC4F62304D83CEC4713A19C39C011EA46DB4.der
Sep 12 11:55:20.477 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//EBC5570C29018C4D67B1AA127BAF12F703B4611EBC17B7DAB5573894179B93FA.der
Sep 12 11:55:20.482 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//E75E72ED9F560EEC6EB4800073A43FC3AD19195A392282017895974A99026B6C.der
Sep 12 11:55:20.487 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//9ACFAB7E43C8D880D06B262A94DEEEE4B4659989C3D0CAF19BAF6405E41AB7DF.der
Sep 12 11:55:20.491 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//C1B48299ABA5208FE9630ACE55CA68A03EDA5A519C8802A0D3A673BE8F8E557D.der
Sep 12 11:55:20.497 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//552F7BDCF1A7AF9E6CE672017F4F12ABF77240C78E761AC203D1D9D20AC89988.der
Sep 12 11:55:20.501 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//15F0BA00A3AC7AF3AC884C072B1011A077BD77C097F40164B2F8598ABD83860C.der
Sep 12 11:55:20.505 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//E35D28419ED02025CFA69038CD623962458DA5C695FBDEA3C22B0BFB25897092.der
Sep 12 11:55:20.511 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//687FA451382278FFF0C8B11F8D43D576671C6EB2BCEAB413FB83D965D06D2FF2.der
Sep 12 11:55:20.518 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//0753E940378C1BD5E3836E395DAEA5CB839E5046F1BD0EAE1951CF10FEC7C965.der
Sep 12 11:55:20.528 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//0687260331A72403D909F105E69BCF0D32E1BD2493FFC6D9206D11BCD6770739.der
Sep 12 11:55:20.536 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//6DC47172E01CBCB0BF62580D895FE2B8AC9AD4F873801E0C10B9C837D21EB177.der
Sep 12 11:55:20.541 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//BE6C4DA2BBB9BA59B6F3939768374246C3C005993FA98F020D1DEDBED48A81D5.der
Sep 12 11:55:20.548 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//2399561127A57125DE8CEFEA610DDF2FA078B5C8067F4E828290BFB860E84B3C.der
Sep 12 11:55:20.552 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//22A2C1F7BDED704CC1E701B5F408C310880FE956B5DE2A4A44F99C873A25A7C8.der
Sep 12 11:55:20.558 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//Verisign_Class_4_Public_Primary_Certification_Authority_-_G3.pem.DER
Sep 12 11:55:20.565 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//B478B812250DF878635C2AA7EC7D155EAA625EE82916E2CD294361886CD1FBD4.der
Sep 12 11:55:20.569 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//FE863D0822FE7A2353FA484D5924E875656D3DC9FB58771F6F616F9D571BC592.der
Sep 12 11:55:20.576 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//E23D4A036D7B70E9F595B1422079D2B91EDFBB1FB651A0633EAA8A9DC5F80703.der
Sep 12 11:55:20.580 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//56C77128D98C18D91B4CFDFFBC25EE9103D4758EA2ABAD826A90F3457D460EB4.der
Sep 12 11:55:20.586 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//02ED0EB28C14DA45165C566791700D6451D7FB56F0B2AB1D3B8EB070E56EDFF5.der
Sep 12 11:55:20.592 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//Start_Commercial_Ltd.pem.DER
Sep 12 11:55:20.599 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//A4310D50AF18A6447190372A86AFAF8B951FFB431D837F1E5688B45971ED1557.der
Sep 12 11:55:20.605 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//04048028BF1F2864D48F9AD4D83294366A828856553F3B14303F90147F5D40EF.der
Sep 12 11:55:20.611 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//59769007F7685D0FCD50872F9F95D5755A5B2B457D81F3692B610A98672F0E1B.der
Sep 12 11:55:20.616 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//96BCEC06264976F37460779ACF28C5A7CFE8A3C0AAE11A8FFCEE05C0BDDF08C6.der
Sep 12 11:55:20.621 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//5A885DB19C01D912C5759388938CAFBBDF031AB2D48E91EE15589B42971D039C.der
Sep 12 11:55:20.628 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//55926084EC963A64B96E2ABE01CE0BA86A64FBFEBCC7AAB5AFC155B37FD76066.der
Sep 12 11:55:20.635 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//2A99F5BC1174B73CBB1D620884E01C34E51CCB3978DA125F0E33268883BF4158.der
Sep 12 11:55:20.640 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//69FAC9BD55FB0AC78D53BBEE5CF1D597989FD0AAAB20A25151BDF1733EE7D122.der
Sep 12 11:55:20.646 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//8A866FD1B276B57E578E921C65828A2BED58E9F2F288054134B7F1F4BFC9CC74.der
Sep 12 11:55:20.651 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//D40E9C86CD8FE468C1776959F49EA774FA548684B6C406F3909261F4DCE2575C.der
Sep 12 11:55:20.657 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//BEC94911C2955676DB6C0A550986D76E3BA005667C442C9762B4FBB773DE228C.der
Sep 12 11:55:20.661 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//5C58468D55F58E497E743982D2B50010B6D165374ACF83A7D4A32DB768C4408E.der
Sep 12 11:55:20.667 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//EAA962C4FA4A6BAFEBE415196D351CCD888D4F53F3FA8AE6D7C466A94E6042BB.der
Sep 12 11:55:20.671 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//18F1FC7F205DF8ADDDEB7FE007DD57E3AF375A9C4D8D73546BF4F1FED1E18D35.der
Sep 12 11:55:20.677 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//A0459B9F63B22559F5FA5D4C6DB3F9F72FF19342033578F073BF1D1B46CBB912.der
Sep 12 11:55:20.682 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//EBD41040E4BB3EC742C9E381D31EF2A41A48B6685C96E7CEF3C1DF6CD4331C99.der
Sep 12 11:55:20.688 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//41C923866AB4CAD6B7AD578081582E020797A6CBDF4FFF78CE8396B38937D7F5.der
Sep 12 11:55:20.695 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//62DD0BE9B9F50A163EA0F8E75C053B1ECA57EA55C8688F647C6881F2C8357B95.der
Sep 12 11:55:20.700 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//063E4AFAC491DFD332F3089B8542E94617D893D7FE944E10A7937EE29D9693C0.der
Sep 12 11:55:20.707 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//91E2F5788D5810EBA7BA58737DE1548A8ECACD014598BC0B143E041B17052552.der
Sep 12 11:55:20.713 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//363F3C849EAB03B0A2A0F636D7B86D04D3AC7FCFE26A0A9121AB9795F6E176DF.der
Sep 12 11:55:20.718 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//CBB522D7B7F127AD6A0113865BDF1CD4102E7D0759AF635A7CF4720DC963C53B.der
Sep 12 11:55:20.729 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//3417BB06CC6007DA1B961C920B8AB4CE3FAD820E4AA30B9ACBC4A74EBDCEBC65.der
Sep 12 11:55:20.735 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//6B9C08E86EB0F767CFAD65CD98B62149E5494A67F5845E7BD1ED019F27B86BD6.der
Sep 12 11:55:20.741 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//85666A562EE0BE5CE925C1D8890A6F76A87EC16D4D7D5F29EA7419CF20123B69.der
Sep 12 11:55:20.747 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//0A81EC5A929777F145904AF38D5D509F66B5E2C58FCDB531058B0E17F3F0B41B.der
Sep 12 11:55:20.751 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//C3846BF24B9E93CA64274C0EC67C1ECC5E024FFCACD2D74019350E81FE546AE4.der
Sep 12 11:55:20.757 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//3C4FB0B95AB8B30032F432B86F535FE172C185D0FD39865837CF36187FA6F428.der
Sep 12 11:55:20.764 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//Verisign_Class_2_Public_Primary_Certification_Authority_-_G2.pem.DER
Sep 12 11:55:20.769 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//Verisign_Class_4_Public_Primary_Certification_Authority_-_G2.pem.DER
Sep 12 11:55:20.775 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//43DF5774B03E7FEF5FE40D931A7BEDF1BB2E6B42738C4E6D3841103D3AA7F339.der
Sep 12 11:55:20.781 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//BFD88FE1101C41AE3E801BF8BE56350EE9BAD1A6B9BD515EDC5C6D5B8711AC44.der
Sep 12 11:55:20.788 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//8C7209279AC04E275E16D07FD3B775E80154B5968046E31F52DD25766324E9A7.der
Sep 12 11:55:20.795 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//E3B6A2DB2ED7CE48842F7AC53241C7B71D54144BFB40C11F3F1D0B42F5EEA12D.der
Sep 12 11:55:20.799 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//0376AB1D54C5F9803CE4B2E201A0EE7EEF7B57B636E8A93C9B8D4860C96F5FA7.der
Sep 12 11:55:20.803 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//8ECDE6884F3D87B1125BA31AC3FCB13D7016DE7F57CC904FE1CB97C6AE98196E.der
Sep 12 11:55:20.809 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//BC104F15A48BE709DCA542A7E1D4B9DF6F054527E802EAA92D595444258AFE71.der
Sep 12 11:55:20.816 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//D7A7A0FB5D7E2731D771E9484EBCDEF71D5F0C3E0A2948782BC83EE0EA699EF4.der
Sep 12 11:55:20.822 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//179FBC148A3DD00FD24EA13458CC43BFA7F59C8182D783A513F6EBEC100C8924.der
Sep 12 11:55:20.830 [DEBUG0] TLS: Added CertFile /snom/snomconfig/certificates/authority_certs//136335439334A7698016A0D324DE72284E079D7B5220BB8FBD747816EEBEBACA.der
Sep 12 11:55:20.830 [INFO ] TLS: PhoneCtx: added 167 certs from /snom/snomconfig/certificates/authority_certs/
Sep 12 11:55:20.830 [NOTICE] PHN: Added 167 Authority Certs
Sep 12 11:55:20.830 [INFO ] TLS: PhoneCtx: added 0 certs from /snom/snomconfig/certificates/server_certs/
Sep 12 11:55:20.830 [NOTICE] PHN: Added 0 User Certs
Sep 12 11:55:20.831 [NOTICE] SIP: Initiating PNP setup
Sep 12 11:55:20.855 [DEBUG1] PHN: Parse features in license string 'Mac:00041375C423;Hardware
Sep 12 11:55:20.855 [DEBUG1] PHN: No feature string found in license
Sep 12 11:55:20.856 [INFO ] PHN: WEBSV: init http_https, protected 0
Sep 12 11:55:20.856 [DEBUG2] PHN: WEB: HTTP listening on Tcp:[::]:80
Sep 12 11:55:20.856 [DEBUG2] PHN: WEB: HTTP listening on Tls:[::]:443
Sep 12 11:55:20.856 [DEBUG2] PHN: Phone init done
Sep 12 11:55:20.905 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyAMA0 device_path: /devices/UARTA/tty/ttyAMA0
Sep 12 11:55:20.906 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyAMA0 /devices/UARTA/tty/ttyAMA0 0 0
Sep 12 11:55:20.908 [ERROR ] UXM: Devpath /devices/UARTA/tty/ttyAMA0 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:20.910 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyAMA1 device_path: /devices/UARTB/tty/ttyAMA1
Sep 12 11:55:20.911 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyAMA1 /devices/UARTB/tty/ttyAMA1 0 0
Sep 12 11:55:20.912 [ERROR ] UXM: Devpath /devices/UARTB/tty/ttyAMA1 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:20.915 [DEBUG2] UDEV: action: add subsystem: usb devtype: usb_device device_path: /devices/platform/bcm-ehci.1/usb1
Sep 12 11:55:20.918 [DEBUG2] UDEV: action: add subsystem: usb devtype: usb_interface device_path: /devices/platform/bcm-ehci.1/usb1/1-0:1.0 vid: 1d6b pid: 0002 name: bcm-ehci
Sep 12 11:55:20.920 [DEBUG2] UDEV: action: add subsystem: usb devtype: usb_device device_path: /devices/platform/bcm-ohci.1/usb2
Sep 12 11:55:20.928 [DEBUG2] UDEV: action: add subsystem: usb devtype: usb_interface device_path: /devices/platform/bcm-ohci.1/usb2/2-0:1.0 vid: 1d6b pid: 0001 name: bcm-ohci
Sep 12 11:55:20.929 [DEBUG2] UDEV: No parent for devpath /devices/virtual/block/mtdblock0.
Sep 12 11:55:20.930 [DEBUG2] UDEV: action: add subsystem: block devtype: disk device_file_name: /dev/mtdblock0 device_path: /devices/virtual/block/mtdblock0
Sep 12 11:55:20.930 [WARN ] UDEV: unknown device file for USB device: /dev/mtdblock0
Sep 12 11:55:20.931 [DEBUG2] UDEV: No parent for devpath /devices/virtual/block/mtdblock1.
Sep 12 11:55:20.931 [DEBUG2] UDEV: action: add subsystem: block devtype: disk device_file_name: /dev/mtdblock1 device_path: /devices/virtual/block/mtdblock1
Sep 12 11:55:20.931 [WARN ] UDEV: unknown device file for USB device: /dev/mtdblock1
Sep 12 11:55:20.932 [DEBUG2] UDEV: No parent for devpath /devices/virtual/block/mtdblock2.
Sep 12 11:55:20.933 [DEBUG2] UDEV: action: add subsystem: block devtype: disk device_file_name: /dev/mtdblock2 device_path: /devices/virtual/block/mtdblock2
Sep 12 11:55:20.934 [WARN ] UDEV: unknown device file for USB device: /dev/mtdblock2
Sep 12 11:55:20.936 [DEBUG2] UDEV: No parent for devpath /devices/virtual/block/mtdblock3.
Sep 12 11:55:20.936 [DEBUG2] UDEV: action: add subsystem: block devtype: disk device_file_name: /dev/mtdblock3 device_path: /devices/virtual/block/mtdblock3
Sep 12 11:55:20.936 [WARN ] UDEV: unknown device file for USB device: /dev/mtdblock3
Sep 12 11:55:20.937 [DEBUG2] UDEV: No parent for devpath /devices/virtual/block/mtdblock4.
Sep 12 11:55:20.937 [DEBUG2] UDEV: action: add subsystem: block devtype: disk device_file_name: /dev/mtdblock4 device_path: /devices/virtual/block/mtdblock4
Sep 12 11:55:20.937 [WARN ] UDEV: unknown device file for USB device: /dev/mtdblock4
Sep 12 11:55:20.939 [DEBUG2] UDEV: No parent for devpath /devices/virtual/block/mtdblock5.
Sep 12 11:55:20.939 [DEBUG2] UDEV: action: add subsystem: block devtype: disk device_file_name: /dev/mtdblock5 device_path: /devices/virtual/block/mtdblock5
Sep 12 11:55:20.939 [WARN ] UDEV: unknown device file for USB device: /dev/mtdblock5
Sep 12 11:55:20.940 [DEBUG2] UDEV: No parent for devpath /devices/virtual/block/mtdblock6.
Sep 12 11:55:20.941 [DEBUG2] UDEV: action: add subsystem: block devtype: disk device_file_name: /dev/mtdblock6 device_path: /devices/virtual/block/mtdblock6
Sep 12 11:55:20.941 [WARN ] UDEV: unknown device file for USB device: /dev/mtdblock6
Sep 12 11:55:20.942 [DEBUG2] UDEV: No parent for devpath /devices/virtual/block/mtdblock7.
Sep 12 11:55:20.942 [DEBUG2] UDEV: action: add subsystem: block devtype: disk device_file_name: /dev/mtdblock7 device_path: /devices/virtual/block/mtdblock7
Sep 12 11:55:20.942 [WARN ] UDEV: unknown device file for USB device: /dev/mtdblock7
Sep 12 11:55:20.945 [DEBUG2] UDEV: No parent for devpath /devices/virtual/input/input0.
Sep 12 11:55:20.945 [DEBUG2] UDEV: action: add subsystem: input device_path: /devices/virtual/input/input0
Sep 12 11:55:20.946 [DEBUG2] UDEV: action: add subsystem: input device_file_name: /dev/input/event0 device_path: /devices/virtual/input/input0/event0
Sep 12 11:55:20.948 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/console.
Sep 12 11:55:20.948 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/console
Sep 12 11:55:20.949 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptmx.
Sep 12 11:55:20.949 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptmx
Sep 12 11:55:20.951 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyp0.
Sep 12 11:55:20.951 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyp0
Sep 12 11:55:20.952 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyp1.
Sep 12 11:55:20.952 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyp1
Sep 12 11:55:20.955 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyp2.
Sep 12 11:55:20.955 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyp2
Sep 12 11:55:20.956 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyp3.
Sep 12 11:55:20.956 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyp3
Sep 12 11:55:20.958 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyp4.
Sep 12 11:55:20.958 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyp4
Sep 12 11:55:20.959 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyp5.
Sep 12 11:55:20.959 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyp5
Sep 12 11:55:20.961 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyp6.
Sep 12 11:55:20.961 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyp6
Sep 12 11:55:20.962 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyp7.
Sep 12 11:55:20.962 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyp7
Sep 12 11:55:20.964 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyp8.
Sep 12 11:55:20.965 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyp8
Sep 12 11:55:20.966 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyp9.
Sep 12 11:55:20.966 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyp9
Sep 12 11:55:20.967 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptypa.
Sep 12 11:55:20.968 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptypa
Sep 12 11:55:20.969 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptypb.
Sep 12 11:55:20.969 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptypb
Sep 12 11:55:20.970 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptypc.
Sep 12 11:55:20.970 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptypc
Sep 12 11:55:20.972 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptypd.
Sep 12 11:55:20.972 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptypd
Sep 12 11:55:20.974 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptype.
Sep 12 11:55:20.975 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptype
Sep 12 11:55:20.976 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptypf.
Sep 12 11:55:20.976 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptypf
Sep 12 11:55:20.977 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyq0.
Sep 12 11:55:20.977 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyq0
Sep 12 11:55:20.979 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyq1.
Sep 12 11:55:20.979 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyq1
Sep 12 11:55:20.980 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyq2.
Sep 12 11:55:20.980 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyq2
Sep 12 11:55:20.982 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyq3.
Sep 12 11:55:20.982 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyq3
Sep 12 11:55:20.984 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyq4.
Sep 12 11:55:20.984 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyq4
Sep 12 11:55:20.986 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyq5.
Sep 12 11:55:20.986 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyq5
Sep 12 11:55:20.987 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyq6.
Sep 12 11:55:20.987 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyq6
Sep 12 11:55:20.988 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyq7.
Sep 12 11:55:20.989 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyq7
Sep 12 11:55:20.990 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyq8.
Sep 12 11:55:20.990 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyq8
Sep 12 11:55:20.991 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyq9.
Sep 12 11:55:20.992 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyq9
Sep 12 11:55:20.993 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyqa.
Sep 12 11:55:20.993 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyqa
Sep 12 11:55:20.995 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyqb.
Sep 12 11:55:20.996 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyqb
Sep 12 11:55:20.997 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyqc.
Sep 12 11:55:20.997 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyqc
Sep 12 11:55:20.998 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyqd.
Sep 12 11:55:20.999 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyqd
Sep 12 11:55:21.000 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyqe.
Sep 12 11:55:21.000 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyqe
Sep 12 11:55:21.001 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyqf.
Sep 12 11:55:21.002 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyqf
Sep 12 11:55:21.003 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyr0.
Sep 12 11:55:21.003 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyr0
Sep 12 11:55:21.005 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyr1.
Sep 12 11:55:21.005 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyr1
Sep 12 11:55:21.007 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyr2.
Sep 12 11:55:21.007 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyr2
Sep 12 11:55:21.008 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyr3.
Sep 12 11:55:21.008 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyr3
Sep 12 11:55:21.010 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyr4.
Sep 12 11:55:21.010 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyr4
Sep 12 11:55:21.011 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyr5.
Sep 12 11:55:21.011 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyr5
Sep 12 11:55:21.012 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyr6.
Sep 12 11:55:21.013 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyr6
Sep 12 11:55:21.015 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyr7.
Sep 12 11:55:21.015 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyr7
Sep 12 11:55:21.016 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyr8.
Sep 12 11:55:21.017 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyr8
Sep 12 11:55:21.018 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyr9.
Sep 12 11:55:21.018 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyr9
Sep 12 11:55:21.019 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyra.
Sep 12 11:55:21.020 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyra
Sep 12 11:55:21.021 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyrb.
Sep 12 11:55:21.021 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyrb
Sep 12 11:55:21.022 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyrc.
Sep 12 11:55:21.023 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyrc
Sep 12 11:55:21.025 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyrd.
Sep 12 11:55:21.025 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyrd
Sep 12 11:55:21.026 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyre.
Sep 12 11:55:21.026 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyre
Sep 12 11:55:21.028 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyrf.
Sep 12 11:55:21.028 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyrf
Sep 12 11:55:21.029 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptys0.
Sep 12 11:55:21.029 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptys0
Sep 12 11:55:21.031 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptys1.
Sep 12 11:55:21.031 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptys1
Sep 12 11:55:21.032 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptys2.
Sep 12 11:55:21.032 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptys2
Sep 12 11:55:21.035 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptys3.
Sep 12 11:55:21.035 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptys3
Sep 12 11:55:21.036 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptys4.
Sep 12 11:55:21.036 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptys4
Sep 12 11:55:21.038 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptys5.
Sep 12 11:55:21.038 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptys5
Sep 12 11:55:21.039 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptys6.
Sep 12 11:55:21.039 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptys6
Sep 12 11:55:21.040 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptys7.
Sep 12 11:55:21.041 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptys7
Sep 12 11:55:21.042 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptys8.
Sep 12 11:55:21.042 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptys8
Sep 12 11:55:21.044 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptys9.
Sep 12 11:55:21.045 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptys9
Sep 12 11:55:21.046 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptysa.
Sep 12 11:55:21.046 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptysa
Sep 12 11:55:21.047 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptysb.
Sep 12 11:55:21.048 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptysb
Sep 12 11:55:21.049 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptysc.
Sep 12 11:55:21.049 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptysc
Sep 12 11:55:21.050 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptysd.
Sep 12 11:55:21.051 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptysd
Sep 12 11:55:21.052 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptyse.
Sep 12 11:55:21.052 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptyse
Sep 12 11:55:21.054 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ptysf.
Sep 12 11:55:21.055 [DEBUG2] UDEV: action: add subsystem: tty device_path: /devices/virtual/tty/ptysf
Sep 12 11:55:21.056 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty.
Sep 12 11:55:21.056 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty device_path: /devices/virtual/tty/tty
Sep 12 11:55:21.057 [DEBUG0] UXM: UsbEventHandler: add /dev/tty /devices/virtual/tty/tty 0 0
Sep 12 11:55:21.058 [ERROR ] UXM: Devpath /devices/virtual/tty/tty doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.059 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty0.
Sep 12 11:55:21.060 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty0 device_path: /devices/virtual/tty/tty0
Sep 12 11:55:21.060 [DEBUG0] UXM: UsbEventHandler: add /dev/tty0 /devices/virtual/tty/tty0 0 0
Sep 12 11:55:21.061 [ERROR ] UXM: Devpath /devices/virtual/tty/tty0 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.063 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty1.
Sep 12 11:55:21.063 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty1 device_path: /devices/virtual/tty/tty1
Sep 12 11:55:21.065 [DEBUG0] UXM: UsbEventHandler: add /dev/tty1 /devices/virtual/tty/tty1 0 0
Sep 12 11:55:21.066 [ERROR ] UXM: Devpath /devices/virtual/tty/tty1 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.067 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty10.
Sep 12 11:55:21.067 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty10 device_path: /devices/virtual/tty/tty10
Sep 12 11:55:21.068 [DEBUG0] UXM: UsbEventHandler: add /dev/tty10 /devices/virtual/tty/tty10 0 0
Sep 12 11:55:21.069 [ERROR ] UXM: Devpath /devices/virtual/tty/tty10 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.070 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty11.
Sep 12 11:55:21.071 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty11 device_path: /devices/virtual/tty/tty11
Sep 12 11:55:21.072 [DEBUG0] UXM: UsbEventHandler: add /dev/tty11 /devices/virtual/tty/tty11 0 0
Sep 12 11:55:21.073 [ERROR ] UXM: Devpath /devices/virtual/tty/tty11 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.075 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty12.
Sep 12 11:55:21.075 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty12 device_path: /devices/virtual/tty/tty12
Sep 12 11:55:21.076 [DEBUG0] UXM: UsbEventHandler: add /dev/tty12 /devices/virtual/tty/tty12 0 0
Sep 12 11:55:21.077 [ERROR ] UXM: Devpath /devices/virtual/tty/tty12 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.078 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty13.
Sep 12 11:55:21.079 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty13 device_path: /devices/virtual/tty/tty13
Sep 12 11:55:21.080 [DEBUG0] UXM: UsbEventHandler: add /dev/tty13 /devices/virtual/tty/tty13 0 0
Sep 12 11:55:21.080 [ERROR ] UXM: Devpath /devices/virtual/tty/tty13 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.082 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty14.
Sep 12 11:55:21.082 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty14 device_path: /devices/virtual/tty/tty14
Sep 12 11:55:21.083 [DEBUG0] UXM: UsbEventHandler: add /dev/tty14 /devices/virtual/tty/tty14 0 0
Sep 12 11:55:21.085 [ERROR ] UXM: Devpath /devices/virtual/tty/tty14 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.086 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty15.
Sep 12 11:55:21.086 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty15 device_path: /devices/virtual/tty/tty15
Sep 12 11:55:21.087 [DEBUG0] UXM: UsbEventHandler: add /dev/tty15 /devices/virtual/tty/tty15 0 0
Sep 12 11:55:21.088 [ERROR ] UXM: Devpath /devices/virtual/tty/tty15 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.090 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty16.
Sep 12 11:55:21.090 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty16 device_path: /devices/virtual/tty/tty16
Sep 12 11:55:21.091 [DEBUG0] UXM: UsbEventHandler: add /dev/tty16 /devices/virtual/tty/tty16 0 0
Sep 12 11:55:21.092 [ERROR ] UXM: Devpath /devices/virtual/tty/tty16 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.094 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty17.
Sep 12 11:55:21.095 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty17 device_path: /devices/virtual/tty/tty17
Sep 12 11:55:21.095 [DEBUG0] UXM: UsbEventHandler: add /dev/tty17 /devices/virtual/tty/tty17 0 0
Sep 12 11:55:21.096 [ERROR ] UXM: Devpath /devices/virtual/tty/tty17 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.098 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty18.
Sep 12 11:55:21.098 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty18 device_path: /devices/virtual/tty/tty18
Sep 12 11:55:21.099 [DEBUG0] UXM: UsbEventHandler: add /dev/tty18 /devices/virtual/tty/tty18 0 0
Sep 12 11:55:21.100 [ERROR ] UXM: Devpath /devices/virtual/tty/tty18 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.101 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty19.
Sep 12 11:55:21.101 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty19 device_path: /devices/virtual/tty/tty19
Sep 12 11:55:21.102 [DEBUG0] UXM: UsbEventHandler: add /dev/tty19 /devices/virtual/tty/tty19 0 0
Sep 12 11:55:21.104 [ERROR ] UXM: Devpath /devices/virtual/tty/tty19 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.106 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty2.
Sep 12 11:55:21.106 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty2 device_path: /devices/virtual/tty/tty2
Sep 12 11:55:21.107 [DEBUG0] UXM: UsbEventHandler: add /dev/tty2 /devices/virtual/tty/tty2 0 0
Sep 12 11:55:21.108 [ERROR ] UXM: Devpath /devices/virtual/tty/tty2 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.109 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty20.
Sep 12 11:55:21.109 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty20 device_path: /devices/virtual/tty/tty20
Sep 12 11:55:21.110 [DEBUG0] UXM: UsbEventHandler: add /dev/tty20 /devices/virtual/tty/tty20 0 0
Sep 12 11:55:21.111 [ERROR ] UXM: Devpath /devices/virtual/tty/tty20 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.113 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty21.
Sep 12 11:55:21.113 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty21 device_path: /devices/virtual/tty/tty21
Sep 12 11:55:21.115 [DEBUG0] UXM: UsbEventHandler: add /dev/tty21 /devices/virtual/tty/tty21 0 0
Sep 12 11:55:21.116 [ERROR ] UXM: Devpath /devices/virtual/tty/tty21 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.117 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty22.
Sep 12 11:55:21.117 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty22 device_path: /devices/virtual/tty/tty22
Sep 12 11:55:21.118 [DEBUG0] UXM: UsbEventHandler: add /dev/tty22 /devices/virtual/tty/tty22 0 0
Sep 12 11:55:21.119 [ERROR ] UXM: Devpath /devices/virtual/tty/tty22 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.121 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty23.
Sep 12 11:55:21.121 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty23 device_path: /devices/virtual/tty/tty23
Sep 12 11:55:21.122 [DEBUG0] UXM: UsbEventHandler: add /dev/tty23 /devices/virtual/tty/tty23 0 0
Sep 12 11:55:21.123 [ERROR ] UXM: Devpath /devices/virtual/tty/tty23 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.129 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty24.
Sep 12 11:55:21.129 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty24 device_path: /devices/virtual/tty/tty24
Sep 12 11:55:21.130 [DEBUG0] UXM: UsbEventHandler: add /dev/tty24 /devices/virtual/tty/tty24 0 0
Sep 12 11:55:21.131 [ERROR ] UXM: Devpath /devices/virtual/tty/tty24 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.132 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty25.
Sep 12 11:55:21.133 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty25 device_path: /devices/virtual/tty/tty25
Sep 12 11:55:21.135 [DEBUG0] UXM: UsbEventHandler: add /dev/tty25 /devices/virtual/tty/tty25 0 0
Sep 12 11:55:21.136 [ERROR ] UXM: Devpath /devices/virtual/tty/tty25 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.137 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty26.
Sep 12 11:55:21.137 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty26 device_path: /devices/virtual/tty/tty26
Sep 12 11:55:21.138 [DEBUG0] UXM: UsbEventHandler: add /dev/tty26 /devices/virtual/tty/tty26 0 0
Sep 12 11:55:21.139 [ERROR ] UXM: Devpath /devices/virtual/tty/tty26 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.141 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty27.
Sep 12 11:55:21.141 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty27 device_path: /devices/virtual/tty/tty27
Sep 12 11:55:21.142 [DEBUG0] UXM: UsbEventHandler: add /dev/tty27 /devices/virtual/tty/tty27 0 0
Sep 12 11:55:21.143 [ERROR ] UXM: Devpath /devices/virtual/tty/tty27 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.145 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty28.
Sep 12 11:55:21.145 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty28 device_path: /devices/virtual/tty/tty28
Sep 12 11:55:21.146 [DEBUG0] UXM: UsbEventHandler: add /dev/tty28 /devices/virtual/tty/tty28 0 0
Sep 12 11:55:21.147 [ERROR ] UXM: Devpath /devices/virtual/tty/tty28 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.148 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty29.
Sep 12 11:55:21.149 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty29 device_path: /devices/virtual/tty/tty29
Sep 12 11:55:21.149 [DEBUG0] UXM: UsbEventHandler: add /dev/tty29 /devices/virtual/tty/tty29 0 0
Sep 12 11:55:21.150 [ERROR ] UXM: Devpath /devices/virtual/tty/tty29 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.152 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty3.
Sep 12 11:55:21.152 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty3 device_path: /devices/virtual/tty/tty3
Sep 12 11:55:21.153 [DEBUG0] UXM: UsbEventHandler: add /dev/tty3 /devices/virtual/tty/tty3 0 0
Sep 12 11:55:21.155 [ERROR ] UXM: Devpath /devices/virtual/tty/tty3 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.156 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty30.
Sep 12 11:55:21.156 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty30 device_path: /devices/virtual/tty/tty30
Sep 12 11:55:21.157 [DEBUG0] UXM: UsbEventHandler: add /dev/tty30 /devices/virtual/tty/tty30 0 0
Sep 12 11:55:21.158 [ERROR ] UXM: Devpath /devices/virtual/tty/tty30 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.160 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty31.
Sep 12 11:55:21.160 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty31 device_path: /devices/virtual/tty/tty31
Sep 12 11:55:21.161 [DEBUG0] UXM: UsbEventHandler: add /dev/tty31 /devices/virtual/tty/tty31 0 0
Sep 12 11:55:21.162 [ERROR ] UXM: Devpath /devices/virtual/tty/tty31 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.163 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty32.
Sep 12 11:55:21.164 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty32 device_path: /devices/virtual/tty/tty32
Sep 12 11:55:21.165 [DEBUG0] UXM: UsbEventHandler: add /dev/tty32 /devices/virtual/tty/tty32 0 0
Sep 12 11:55:21.166 [ERROR ] UXM: Devpath /devices/virtual/tty/tty32 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.167 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty33.
Sep 12 11:55:21.168 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty33 device_path: /devices/virtual/tty/tty33
Sep 12 11:55:21.169 [DEBUG0] UXM: UsbEventHandler: add /dev/tty33 /devices/virtual/tty/tty33 0 0
Sep 12 11:55:21.170 [ERROR ] UXM: Devpath /devices/virtual/tty/tty33 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.171 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty34.
Sep 12 11:55:21.171 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty34 device_path: /devices/virtual/tty/tty34
Sep 12 11:55:21.172 [DEBUG0] UXM: UsbEventHandler: add /dev/tty34 /devices/virtual/tty/tty34 0 0
Sep 12 11:55:21.173 [ERROR ] UXM: Devpath /devices/virtual/tty/tty34 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.175 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty35.
Sep 12 11:55:21.176 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty35 device_path: /devices/virtual/tty/tty35
Sep 12 11:55:21.176 [DEBUG0] UXM: UsbEventHandler: add /dev/tty35 /devices/virtual/tty/tty35 0 0
Sep 12 11:55:21.177 [ERROR ] UXM: Devpath /devices/virtual/tty/tty35 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.179 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty36.
Sep 12 11:55:21.179 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty36 device_path: /devices/virtual/tty/tty36
Sep 12 11:55:21.180 [DEBUG0] UXM: UsbEventHandler: add /dev/tty36 /devices/virtual/tty/tty36 0 0
Sep 12 11:55:21.181 [ERROR ] UXM: Devpath /devices/virtual/tty/tty36 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.182 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty37.
Sep 12 11:55:21.182 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty37 device_path: /devices/virtual/tty/tty37
Sep 12 11:55:21.184 [DEBUG0] UXM: UsbEventHandler: add /dev/tty37 /devices/virtual/tty/tty37 0 0
Sep 12 11:55:21.185 [ERROR ] UXM: Devpath /devices/virtual/tty/tty37 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.187 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty38.
Sep 12 11:55:21.187 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty38 device_path: /devices/virtual/tty/tty38
Sep 12 11:55:21.188 [DEBUG0] UXM: UsbEventHandler: add /dev/tty38 /devices/virtual/tty/tty38 0 0
Sep 12 11:55:21.189 [ERROR ] UXM: Devpath /devices/virtual/tty/tty38 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.190 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty39.
Sep 12 11:55:21.190 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty39 device_path: /devices/virtual/tty/tty39
Sep 12 11:55:21.191 [DEBUG0] UXM: UsbEventHandler: add /dev/tty39 /devices/virtual/tty/tty39 0 0
Sep 12 11:55:21.192 [ERROR ] UXM: Devpath /devices/virtual/tty/tty39 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.195 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty4.
Sep 12 11:55:21.195 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty4 device_path: /devices/virtual/tty/tty4
Sep 12 11:55:21.196 [DEBUG0] UXM: UsbEventHandler: add /dev/tty4 /devices/virtual/tty/tty4 0 0
Sep 12 11:55:21.197 [ERROR ] UXM: Devpath /devices/virtual/tty/tty4 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.198 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty40.
Sep 12 11:55:21.198 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty40 device_path: /devices/virtual/tty/tty40
Sep 12 11:55:21.199 [DEBUG0] UXM: UsbEventHandler: add /dev/tty40 /devices/virtual/tty/tty40 0 0
Sep 12 11:55:21.200 [ERROR ] UXM: Devpath /devices/virtual/tty/tty40 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.202 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty41.
Sep 12 11:55:21.202 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty41 device_path: /devices/virtual/tty/tty41
Sep 12 11:55:21.203 [DEBUG0] UXM: UsbEventHandler: add /dev/tty41 /devices/virtual/tty/tty41 0 0
Sep 12 11:55:21.205 [ERROR ] UXM: Devpath /devices/virtual/tty/tty41 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.206 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty42.
Sep 12 11:55:21.206 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty42 device_path: /devices/virtual/tty/tty42
Sep 12 11:55:21.207 [DEBUG0] UXM: UsbEventHandler: add /dev/tty42 /devices/virtual/tty/tty42 0 0
Sep 12 11:55:21.208 [ERROR ] UXM: Devpath /devices/virtual/tty/tty42 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.210 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty43.
Sep 12 11:55:21.210 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty43 device_path: /devices/virtual/tty/tty43
Sep 12 11:55:21.211 [DEBUG0] UXM: UsbEventHandler: add /dev/tty43 /devices/virtual/tty/tty43 0 0
Sep 12 11:55:21.212 [ERROR ] UXM: Devpath /devices/virtual/tty/tty43 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.213 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty44.
Sep 12 11:55:21.214 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty44 device_path: /devices/virtual/tty/tty44
Sep 12 11:55:21.215 [DEBUG0] UXM: UsbEventHandler: add /dev/tty44 /devices/virtual/tty/tty44 0 0
Sep 12 11:55:21.216 [ERROR ] UXM: Devpath /devices/virtual/tty/tty44 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.218 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty45.
Sep 12 11:55:21.218 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty45 device_path: /devices/virtual/tty/tty45
Sep 12 11:55:21.219 [DEBUG0] UXM: UsbEventHandler: add /dev/tty45 /devices/virtual/tty/tty45 0 0
Sep 12 11:55:21.220 [ERROR ] UXM: Devpath /devices/virtual/tty/tty45 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.221 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty46.
Sep 12 11:55:21.221 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty46 device_path: /devices/virtual/tty/tty46
Sep 12 11:55:21.222 [DEBUG0] UXM: UsbEventHandler: add /dev/tty46 /devices/virtual/tty/tty46 0 0
Sep 12 11:55:21.224 [ERROR ] UXM: Devpath /devices/virtual/tty/tty46 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.226 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty47.
Sep 12 11:55:21.226 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty47 device_path: /devices/virtual/tty/tty47
Sep 12 11:55:21.227 [DEBUG0] UXM: UsbEventHandler: add /dev/tty47 /devices/virtual/tty/tty47 0 0
Sep 12 11:55:21.228 [ERROR ] UXM: Devpath /devices/virtual/tty/tty47 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.229 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty48.
Sep 12 11:55:21.229 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty48 device_path: /devices/virtual/tty/tty48
Sep 12 11:55:21.230 [DEBUG0] UXM: UsbEventHandler: add /dev/tty48 /devices/virtual/tty/tty48 0 0
Sep 12 11:55:21.231 [ERROR ] UXM: Devpath /devices/virtual/tty/tty48 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.232 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty49.
Sep 12 11:55:21.233 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty49 device_path: /devices/virtual/tty/tty49
Sep 12 11:55:21.235 [DEBUG0] UXM: UsbEventHandler: add /dev/tty49 /devices/virtual/tty/tty49 0 0
Sep 12 11:55:21.236 [ERROR ] UXM: Devpath /devices/virtual/tty/tty49 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.237 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty5.
Sep 12 11:55:21.237 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty5 device_path: /devices/virtual/tty/tty5
Sep 12 11:55:21.238 [DEBUG0] UXM: UsbEventHandler: add /dev/tty5 /devices/virtual/tty/tty5 0 0
Sep 12 11:55:21.239 [ERROR ] UXM: Devpath /devices/virtual/tty/tty5 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.241 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty50.
Sep 12 11:55:21.241 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty50 device_path: /devices/virtual/tty/tty50
Sep 12 11:55:21.242 [DEBUG0] UXM: UsbEventHandler: add /dev/tty50 /devices/virtual/tty/tty50 0 0
Sep 12 11:55:21.243 [ERROR ] UXM: Devpath /devices/virtual/tty/tty50 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.245 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty51.
Sep 12 11:55:21.245 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty51 device_path: /devices/virtual/tty/tty51
Sep 12 11:55:21.246 [DEBUG0] UXM: UsbEventHandler: add /dev/tty51 /devices/virtual/tty/tty51 0 0
Sep 12 11:55:21.247 [ERROR ] UXM: Devpath /devices/virtual/tty/tty51 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.249 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty52.
Sep 12 11:55:21.249 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty52 device_path: /devices/virtual/tty/tty52
Sep 12 11:55:21.250 [DEBUG0] UXM: UsbEventHandler: add /dev/tty52 /devices/virtual/tty/tty52 0 0
Sep 12 11:55:21.251 [ERROR ] UXM: Devpath /devices/virtual/tty/tty52 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.252 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty53.
Sep 12 11:55:21.252 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty53 device_path: /devices/virtual/tty/tty53
Sep 12 11:55:21.254 [DEBUG0] UXM: UsbEventHandler: add /dev/tty53 /devices/virtual/tty/tty53 0 0
Sep 12 11:55:21.255 [ERROR ] UXM: Devpath /devices/virtual/tty/tty53 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.257 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty54.
Sep 12 11:55:21.257 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty54 device_path: /devices/virtual/tty/tty54
Sep 12 11:55:21.258 [DEBUG0] UXM: UsbEventHandler: add /dev/tty54 /devices/virtual/tty/tty54 0 0
Sep 12 11:55:21.259 [ERROR ] UXM: Devpath /devices/virtual/tty/tty54 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.260 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty55.
Sep 12 11:55:21.260 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty55 device_path: /devices/virtual/tty/tty55
Sep 12 11:55:21.261 [DEBUG0] UXM: UsbEventHandler: add /dev/tty55 /devices/virtual/tty/tty55 0 0
Sep 12 11:55:21.262 [ERROR ] UXM: Devpath /devices/virtual/tty/tty55 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.265 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty56.
Sep 12 11:55:21.265 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty56 device_path: /devices/virtual/tty/tty56
Sep 12 11:55:21.266 [DEBUG0] UXM: UsbEventHandler: add /dev/tty56 /devices/virtual/tty/tty56 0 0
Sep 12 11:55:21.267 [ERROR ] UXM: Devpath /devices/virtual/tty/tty56 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.268 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty57.
Sep 12 11:55:21.268 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty57 device_path: /devices/virtual/tty/tty57
Sep 12 11:55:21.269 [DEBUG0] UXM: UsbEventHandler: add /dev/tty57 /devices/virtual/tty/tty57 0 0
Sep 12 11:55:21.270 [ERROR ] UXM: Devpath /devices/virtual/tty/tty57 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.271 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty58.
Sep 12 11:55:21.272 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty58 device_path: /devices/virtual/tty/tty58
Sep 12 11:55:21.273 [DEBUG0] UXM: UsbEventHandler: add /dev/tty58 /devices/virtual/tty/tty58 0 0
Sep 12 11:55:21.275 [ERROR ] UXM: Devpath /devices/virtual/tty/tty58 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.276 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty59.
Sep 12 11:55:21.276 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty59 device_path: /devices/virtual/tty/tty59
Sep 12 11:55:21.277 [DEBUG0] UXM: UsbEventHandler: add /dev/tty59 /devices/virtual/tty/tty59 0 0
Sep 12 11:55:21.278 [ERROR ] UXM: Devpath /devices/virtual/tty/tty59 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.280 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty6.
Sep 12 11:55:21.280 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty6 device_path: /devices/virtual/tty/tty6
Sep 12 11:55:21.281 [DEBUG0] UXM: UsbEventHandler: add /dev/tty6 /devices/virtual/tty/tty6 0 0
Sep 12 11:55:21.282 [ERROR ] UXM: Devpath /devices/virtual/tty/tty6 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.284 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty60.
Sep 12 11:55:21.284 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty60 device_path: /devices/virtual/tty/tty60
Sep 12 11:55:21.285 [DEBUG0] UXM: UsbEventHandler: add /dev/tty60 /devices/virtual/tty/tty60 0 0
Sep 12 11:55:21.286 [ERROR ] UXM: Devpath /devices/virtual/tty/tty60 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.287 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty61.
Sep 12 11:55:21.288 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty61 device_path: /devices/virtual/tty/tty61
Sep 12 11:55:21.289 [DEBUG0] UXM: UsbEventHandler: add /dev/tty61 /devices/virtual/tty/tty61 0 0
Sep 12 11:55:21.290 [ERROR ] UXM: Devpath /devices/virtual/tty/tty61 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.291 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty62.
Sep 12 11:55:21.291 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty62 device_path: /devices/virtual/tty/tty62
Sep 12 11:55:21.292 [DEBUG0] UXM: UsbEventHandler: add /dev/tty62 /devices/virtual/tty/tty62 0 0
Sep 12 11:55:21.294 [ERROR ] UXM: Devpath /devices/virtual/tty/tty62 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.296 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty63.
Sep 12 11:55:21.296 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty63 device_path: /devices/virtual/tty/tty63
Sep 12 11:55:21.297 [DEBUG0] UXM: UsbEventHandler: add /dev/tty63 /devices/virtual/tty/tty63 0 0
Sep 12 11:55:21.298 [ERROR ] UXM: Devpath /devices/virtual/tty/tty63 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.299 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty7.
Sep 12 11:55:21.299 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty7 device_path: /devices/virtual/tty/tty7
Sep 12 11:55:21.300 [DEBUG0] UXM: UsbEventHandler: add /dev/tty7 /devices/virtual/tty/tty7 0 0
Sep 12 11:55:21.301 [ERROR ] UXM: Devpath /devices/virtual/tty/tty7 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.303 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty8.
Sep 12 11:55:21.303 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty8 device_path: /devices/virtual/tty/tty8
Sep 12 11:55:21.305 [DEBUG0] UXM: UsbEventHandler: add /dev/tty8 /devices/virtual/tty/tty8 0 0
Sep 12 11:55:21.306 [ERROR ] UXM: Devpath /devices/virtual/tty/tty8 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.307 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/tty9.
Sep 12 11:55:21.307 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/tty9 device_path: /devices/virtual/tty/tty9
Sep 12 11:55:21.308 [DEBUG0] UXM: UsbEventHandler: add /dev/tty9 /devices/virtual/tty/tty9 0 0
Sep 12 11:55:21.309 [ERROR ] UXM: Devpath /devices/virtual/tty/tty9 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.311 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyp0.
Sep 12 11:55:21.311 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyp0 device_path: /devices/virtual/tty/ttyp0
Sep 12 11:55:21.312 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyp0 /devices/virtual/tty/ttyp0 0 0
Sep 12 11:55:21.313 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyp0 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.315 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyp1.
Sep 12 11:55:21.316 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyp1 device_path: /devices/virtual/tty/ttyp1
Sep 12 11:55:21.316 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyp1 /devices/virtual/tty/ttyp1 0 0
Sep 12 11:55:21.317 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyp1 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.319 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyp2.
Sep 12 11:55:21.319 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyp2 device_path: /devices/virtual/tty/ttyp2
Sep 12 11:55:21.320 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyp2 /devices/virtual/tty/ttyp2 0 0
Sep 12 11:55:21.321 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyp2 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.322 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyp3.
Sep 12 11:55:21.323 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyp3 device_path: /devices/virtual/tty/ttyp3
Sep 12 11:55:21.329 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyp3 /devices/virtual/tty/ttyp3 0 0
Sep 12 11:55:21.330 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyp3 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.331 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyp4.
Sep 12 11:55:21.331 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyp4 device_path: /devices/virtual/tty/ttyp4
Sep 12 11:55:21.332 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyp4 /devices/virtual/tty/ttyp4 0 0
Sep 12 11:55:21.334 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyp4 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.336 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyp5.
Sep 12 11:55:21.336 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyp5 device_path: /devices/virtual/tty/ttyp5
Sep 12 11:55:21.337 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyp5 /devices/virtual/tty/ttyp5 0 0
Sep 12 11:55:21.338 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyp5 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.339 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyp6.
Sep 12 11:55:21.339 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyp6 device_path: /devices/virtual/tty/ttyp6
Sep 12 11:55:21.340 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyp6 /devices/virtual/tty/ttyp6 0 0
Sep 12 11:55:21.341 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyp6 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.343 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyp7.
Sep 12 11:55:21.344 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyp7 device_path: /devices/virtual/tty/ttyp7
Sep 12 11:55:21.345 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyp7 /devices/virtual/tty/ttyp7 0 0
Sep 12 11:55:21.346 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyp7 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.347 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyp8.
Sep 12 11:55:21.348 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyp8 device_path: /devices/virtual/tty/ttyp8
Sep 12 11:55:21.348 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyp8 /devices/virtual/tty/ttyp8 0 0
Sep 12 11:55:21.349 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyp8 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.351 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyp9.
Sep 12 11:55:21.351 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyp9 device_path: /devices/virtual/tty/ttyp9
Sep 12 11:55:21.352 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyp9 /devices/virtual/tty/ttyp9 0 0
Sep 12 11:55:21.353 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyp9 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.355 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttypa.
Sep 12 11:55:21.356 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttypa device_path: /devices/virtual/tty/ttypa
Sep 12 11:55:21.357 [DEBUG0] UXM: UsbEventHandler: add /dev/ttypa /devices/virtual/tty/ttypa 0 0
Sep 12 11:55:21.357 [ERROR ] UXM: Devpath /devices/virtual/tty/ttypa doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.359 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttypb.
Sep 12 11:55:21.359 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttypb device_path: /devices/virtual/tty/ttypb
Sep 12 11:55:21.360 [DEBUG0] UXM: UsbEventHandler: add /dev/ttypb /devices/virtual/tty/ttypb 0 0
Sep 12 11:55:21.361 [ERROR ] UXM: Devpath /devices/virtual/tty/ttypb doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.362 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttypc.
Sep 12 11:55:21.363 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttypc device_path: /devices/virtual/tty/ttypc
Sep 12 11:55:21.364 [DEBUG0] UXM: UsbEventHandler: add /dev/ttypc /devices/virtual/tty/ttypc 0 0
Sep 12 11:55:21.365 [ERROR ] UXM: Devpath /devices/virtual/tty/ttypc doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.367 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttypd.
Sep 12 11:55:21.367 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttypd device_path: /devices/virtual/tty/ttypd
Sep 12 11:55:21.368 [DEBUG0] UXM: UsbEventHandler: add /dev/ttypd /devices/virtual/tty/ttypd 0 0
Sep 12 11:55:21.369 [ERROR ] UXM: Devpath /devices/virtual/tty/ttypd doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.370 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttype.
Sep 12 11:55:21.371 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttype device_path: /devices/virtual/tty/ttype
Sep 12 11:55:21.371 [DEBUG0] UXM: UsbEventHandler: add /dev/ttype /devices/virtual/tty/ttype 0 0
Sep 12 11:55:21.372 [ERROR ] UXM: Devpath /devices/virtual/tty/ttype doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.375 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttypf.
Sep 12 11:55:21.375 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttypf device_path: /devices/virtual/tty/ttypf
Sep 12 11:55:21.376 [DEBUG0] UXM: UsbEventHandler: add /dev/ttypf /devices/virtual/tty/ttypf 0 0
Sep 12 11:55:21.377 [ERROR ] UXM: Devpath /devices/virtual/tty/ttypf doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.378 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyq0.
Sep 12 11:55:21.379 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyq0 device_path: /devices/virtual/tty/ttyq0
Sep 12 11:55:21.379 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyq0 /devices/virtual/tty/ttyq0 0 0
Sep 12 11:55:21.380 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyq0 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.382 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyq1.
Sep 12 11:55:21.382 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyq1 device_path: /devices/virtual/tty/ttyq1
Sep 12 11:55:21.383 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyq1 /devices/virtual/tty/ttyq1 0 0
Sep 12 11:55:21.385 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyq1 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.386 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyq2.
Sep 12 11:55:21.386 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyq2 device_path: /devices/virtual/tty/ttyq2
Sep 12 11:55:21.387 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyq2 /devices/virtual/tty/ttyq2 0 0
Sep 12 11:55:21.388 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyq2 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.390 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyq3.
Sep 12 11:55:21.390 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyq3 device_path: /devices/virtual/tty/ttyq3
Sep 12 11:55:21.391 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyq3 /devices/virtual/tty/ttyq3 0 0
Sep 12 11:55:21.392 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyq3 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.395 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyq4.
Sep 12 11:55:21.395 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyq4 device_path: /devices/virtual/tty/ttyq4
Sep 12 11:55:21.396 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyq4 /devices/virtual/tty/ttyq4 0 0
Sep 12 11:55:21.397 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyq4 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.398 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyq5.
Sep 12 11:55:21.398 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyq5 device_path: /devices/virtual/tty/ttyq5
Sep 12 11:55:21.399 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyq5 /devices/virtual/tty/ttyq5 0 0
Sep 12 11:55:21.400 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyq5 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.401 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyq6.
Sep 12 11:55:21.402 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyq6 device_path: /devices/virtual/tty/ttyq6
Sep 12 11:55:21.403 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyq6 /devices/virtual/tty/ttyq6 0 0
Sep 12 11:55:21.405 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyq6 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.406 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyq7.
Sep 12 11:55:21.406 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyq7 device_path: /devices/virtual/tty/ttyq7
Sep 12 11:55:21.407 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyq7 /devices/virtual/tty/ttyq7 0 0
Sep 12 11:55:21.408 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyq7 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.409 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyq8.
Sep 12 11:55:21.410 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyq8 device_path: /devices/virtual/tty/ttyq8
Sep 12 11:55:21.411 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyq8 /devices/virtual/tty/ttyq8 0 0
Sep 12 11:55:21.411 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyq8 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.413 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyq9.
Sep 12 11:55:21.413 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyq9 device_path: /devices/virtual/tty/ttyq9
Sep 12 11:55:21.415 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyq9 /devices/virtual/tty/ttyq9 0 0
Sep 12 11:55:21.416 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyq9 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.417 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyqa.
Sep 12 11:55:21.418 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyqa device_path: /devices/virtual/tty/ttyqa
Sep 12 11:55:21.419 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyqa /devices/virtual/tty/ttyqa 0 0
Sep 12 11:55:21.420 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyqa doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.421 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyqb.
Sep 12 11:55:21.421 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyqb device_path: /devices/virtual/tty/ttyqb
Sep 12 11:55:21.422 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyqb /devices/virtual/tty/ttyqb 0 0
Sep 12 11:55:21.423 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyqb doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.425 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyqc.
Sep 12 11:55:21.426 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyqc device_path: /devices/virtual/tty/ttyqc
Sep 12 11:55:21.426 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyqc /devices/virtual/tty/ttyqc 0 0
Sep 12 11:55:21.427 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyqc doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.429 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyqd.
Sep 12 11:55:21.429 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyqd device_path: /devices/virtual/tty/ttyqd
Sep 12 11:55:21.430 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyqd /devices/virtual/tty/ttyqd 0 0
Sep 12 11:55:21.431 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyqd doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.432 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyqe.
Sep 12 11:55:21.433 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyqe device_path: /devices/virtual/tty/ttyqe
Sep 12 11:55:21.435 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyqe /devices/virtual/tty/ttyqe 0 0
Sep 12 11:55:21.436 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyqe doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.437 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyqf.
Sep 12 11:55:21.437 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyqf device_path: /devices/virtual/tty/ttyqf
Sep 12 11:55:21.438 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyqf /devices/virtual/tty/ttyqf 0 0
Sep 12 11:55:21.439 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyqf doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.440 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyr0.
Sep 12 11:55:21.441 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyr0 device_path: /devices/virtual/tty/ttyr0
Sep 12 11:55:21.442 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyr0 /devices/virtual/tty/ttyr0 0 0
Sep 12 11:55:21.443 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyr0 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.445 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyr1.
Sep 12 11:55:21.445 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyr1 device_path: /devices/virtual/tty/ttyr1
Sep 12 11:55:21.446 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyr1 /devices/virtual/tty/ttyr1 0 0
Sep 12 11:55:21.447 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyr1 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.448 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyr2.
Sep 12 11:55:21.449 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyr2 device_path: /devices/virtual/tty/ttyr2
Sep 12 11:55:21.450 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyr2 /devices/virtual/tty/ttyr2 0 0
Sep 12 11:55:21.450 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyr2 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.452 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyr3.
Sep 12 11:55:21.452 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyr3 device_path: /devices/virtual/tty/ttyr3
Sep 12 11:55:21.453 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyr3 /devices/virtual/tty/ttyr3 0 0
Sep 12 11:55:21.455 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyr3 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.456 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyr4.
Sep 12 11:55:21.457 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyr4 device_path: /devices/virtual/tty/ttyr4
Sep 12 11:55:21.457 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyr4 /devices/virtual/tty/ttyr4 0 0
Sep 12 11:55:21.458 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyr4 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.460 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyr5.
Sep 12 11:55:21.460 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyr5 device_path: /devices/virtual/tty/ttyr5
Sep 12 11:55:21.461 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyr5 /devices/virtual/tty/ttyr5 0 0
Sep 12 11:55:21.462 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyr5 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.464 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyr6.
Sep 12 11:55:21.465 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyr6 device_path: /devices/virtual/tty/ttyr6
Sep 12 11:55:21.465 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyr6 /devices/virtual/tty/ttyr6 0 0
Sep 12 11:55:21.466 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyr6 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.468 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyr7.
Sep 12 11:55:21.468 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyr7 device_path: /devices/virtual/tty/ttyr7
Sep 12 11:55:21.469 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyr7 /devices/virtual/tty/ttyr7 0 0
Sep 12 11:55:21.470 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyr7 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.471 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyr8.
Sep 12 11:55:21.471 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyr8 device_path: /devices/virtual/tty/ttyr8
Sep 12 11:55:21.472 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyr8 /devices/virtual/tty/ttyr8 0 0
Sep 12 11:55:21.474 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyr8 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.476 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyr9.
Sep 12 11:55:21.476 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyr9 device_path: /devices/virtual/tty/ttyr9
Sep 12 11:55:21.477 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyr9 /devices/virtual/tty/ttyr9 0 0
Sep 12 11:55:21.478 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyr9 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.479 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyra.
Sep 12 11:55:21.480 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyra device_path: /devices/virtual/tty/ttyra
Sep 12 11:55:21.481 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyra /devices/virtual/tty/ttyra 0 0
Sep 12 11:55:21.481 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyra doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.483 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyrb.
Sep 12 11:55:21.484 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyrb device_path: /devices/virtual/tty/ttyrb
Sep 12 11:55:21.485 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyrb /devices/virtual/tty/ttyrb 0 0
Sep 12 11:55:21.486 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyrb doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.488 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyrc.
Sep 12 11:55:21.488 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyrc device_path: /devices/virtual/tty/ttyrc
Sep 12 11:55:21.489 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyrc /devices/virtual/tty/ttyrc 0 0
Sep 12 11:55:21.490 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyrc doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.491 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyrd.
Sep 12 11:55:21.491 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyrd device_path: /devices/virtual/tty/ttyrd
Sep 12 11:55:21.492 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyrd /devices/virtual/tty/ttyrd 0 0
Sep 12 11:55:21.494 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyrd doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.496 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyre.
Sep 12 11:55:21.496 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyre device_path: /devices/virtual/tty/ttyre
Sep 12 11:55:21.497 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyre /devices/virtual/tty/ttyre 0 0
Sep 12 11:55:21.498 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyre doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.499 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyrf.
Sep 12 11:55:21.500 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyrf device_path: /devices/virtual/tty/ttyrf
Sep 12 11:55:21.500 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyrf /devices/virtual/tty/ttyrf 0 0
Sep 12 11:55:21.501 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyrf doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.503 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttys0.
Sep 12 11:55:21.503 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttys0 device_path: /devices/virtual/tty/ttys0
Sep 12 11:55:21.505 [DEBUG0] UXM: UsbEventHandler: add /dev/ttys0 /devices/virtual/tty/ttys0 0 0
Sep 12 11:55:21.506 [ERROR ] UXM: Devpath /devices/virtual/tty/ttys0 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.507 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttys1.
Sep 12 11:55:21.507 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttys1 device_path: /devices/virtual/tty/ttys1
Sep 12 11:55:21.508 [DEBUG0] UXM: UsbEventHandler: add /dev/ttys1 /devices/virtual/tty/ttys1 0 0
Sep 12 11:55:21.509 [ERROR ] UXM: Devpath /devices/virtual/tty/ttys1 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.511 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttys2.
Sep 12 11:55:21.511 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttys2 device_path: /devices/virtual/tty/ttys2
Sep 12 11:55:21.512 [DEBUG0] UXM: UsbEventHandler: add /dev/ttys2 /devices/virtual/tty/ttys2 0 0
Sep 12 11:55:21.513 [ERROR ] UXM: Devpath /devices/virtual/tty/ttys2 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.515 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttys3.
Sep 12 11:55:21.516 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttys3 device_path: /devices/virtual/tty/ttys3
Sep 12 11:55:21.516 [DEBUG0] UXM: UsbEventHandler: add /dev/ttys3 /devices/virtual/tty/ttys3 0 0
Sep 12 11:55:21.517 [ERROR ] UXM: Devpath /devices/virtual/tty/ttys3 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.519 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttys4.
Sep 12 11:55:21.519 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttys4 device_path: /devices/virtual/tty/ttys4
Sep 12 11:55:21.520 [DEBUG0] UXM: UsbEventHandler: add /dev/ttys4 /devices/virtual/tty/ttys4 0 0
Sep 12 11:55:21.521 [ERROR ] UXM: Devpath /devices/virtual/tty/ttys4 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.522 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttys5.
Sep 12 11:55:21.523 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttys5 device_path: /devices/virtual/tty/ttys5
Sep 12 11:55:21.529 [DEBUG0] UXM: UsbEventHandler: add /dev/ttys5 /devices/virtual/tty/ttys5 0 0
Sep 12 11:55:21.530 [ERROR ] UXM: Devpath /devices/virtual/tty/ttys5 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.531 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttys6.
Sep 12 11:55:21.531 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttys6 device_path: /devices/virtual/tty/ttys6
Sep 12 11:55:21.532 [DEBUG0] UXM: UsbEventHandler: add /dev/ttys6 /devices/virtual/tty/ttys6 0 0
Sep 12 11:55:21.534 [ERROR ] UXM: Devpath /devices/virtual/tty/ttys6 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.536 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttys7.
Sep 12 11:55:21.536 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttys7 device_path: /devices/virtual/tty/ttys7
Sep 12 11:55:21.537 [DEBUG0] UXM: UsbEventHandler: add /dev/ttys7 /devices/virtual/tty/ttys7 0 0
Sep 12 11:55:21.538 [ERROR ] UXM: Devpath /devices/virtual/tty/ttys7 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.539 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttys8.
Sep 12 11:55:21.540 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttys8 device_path: /devices/virtual/tty/ttys8
Sep 12 11:55:21.540 [DEBUG0] UXM: UsbEventHandler: add /dev/ttys8 /devices/virtual/tty/ttys8 0 0
Sep 12 11:55:21.541 [ERROR ] UXM: Devpath /devices/virtual/tty/ttys8 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.543 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttys9.
Sep 12 11:55:21.544 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttys9 device_path: /devices/virtual/tty/ttys9
Sep 12 11:55:21.545 [DEBUG0] UXM: UsbEventHandler: add /dev/ttys9 /devices/virtual/tty/ttys9 0 0
Sep 12 11:55:21.546 [ERROR ] UXM: Devpath /devices/virtual/tty/ttys9 doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.547 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttysa.
Sep 12 11:55:21.548 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttysa device_path: /devices/virtual/tty/ttysa
Sep 12 11:55:21.549 [DEBUG0] UXM: UsbEventHandler: add /dev/ttysa /devices/virtual/tty/ttysa 0 0
Sep 12 11:55:21.550 [ERROR ] UXM: Devpath /devices/virtual/tty/ttysa doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.551 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttysb.
Sep 12 11:55:21.551 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttysb device_path: /devices/virtual/tty/ttysb
Sep 12 11:55:21.552 [DEBUG0] UXM: UsbEventHandler: add /dev/ttysb /devices/virtual/tty/ttysb 0 0
Sep 12 11:55:21.553 [ERROR ] UXM: Devpath /devices/virtual/tty/ttysb doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.556 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttysc.
Sep 12 11:55:21.556 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttysc device_path: /devices/virtual/tty/ttysc
Sep 12 11:55:21.557 [DEBUG0] UXM: UsbEventHandler: add /dev/ttysc /devices/virtual/tty/ttysc 0 0
Sep 12 11:55:21.558 [ERROR ] UXM: Devpath /devices/virtual/tty/ttysc doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.559 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttysd.
Sep 12 11:55:21.559 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttysd device_path: /devices/virtual/tty/ttysd
Sep 12 11:55:21.560 [DEBUG0] UXM: UsbEventHandler: add /dev/ttysd /devices/virtual/tty/ttysd 0 0
Sep 12 11:55:21.561 [ERROR ] UXM: Devpath /devices/virtual/tty/ttysd doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.563 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttyse.
Sep 12 11:55:21.563 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttyse device_path: /devices/virtual/tty/ttyse
Sep 12 11:55:21.565 [DEBUG0] UXM: UsbEventHandler: add /dev/ttyse /devices/virtual/tty/ttyse 0 0
Sep 12 11:55:21.566 [ERROR ] UXM: Devpath /devices/virtual/tty/ttyse doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.567 [DEBUG2] UDEV: No parent for devpath /devices/virtual/tty/ttysf.
Sep 12 11:55:21.567 [DEBUG2] UDEV: action: add subsystem: tty device_file_name: /dev/ttysf device_path: /devices/virtual/tty/ttysf
Sep 12 11:55:21.568 [DEBUG0] UXM: UsbEventHandler: add /dev/ttysf /devices/virtual/tty/ttysf 0 0
Sep 12 11:55:21.569 [ERROR ] UXM: Devpath /devices/virtual/tty/ttysf doesn't match regular expression for snom USB expansion modules.
Sep 12 11:55:21.571 [DEBUG0] PHN: TaskMon: LCS/2 PollEvent took 5178 msecs, started Sep 12 11:55:16
Sep 12 11:55:21.621 [ERROR ] GUI: gui_display::flush: return because gui is disabled
Sep 12 11:55:21.622 [DEBUG2] GUI: SetSynthMode: synth 14->0, audio 0, force 0
Sep 12 11:55:21.622 [DEBUG0] MEDIA: Synthesizer Command: PLAY 0 0 0
Sep 12 11:55:21.624 [INFO ] GUI: synth_silent: connected lines: 0 of 0 state: Wizard inIdle: 1 inTerminated: 0
Sep 12 11:55:21.624 [INFO ] GUI: synth_silent: lines with call action: 0
Sep 12 11:55:21.625 [INFO ] GUI: synth_silent: set playstate idle and audio mode to none
Sep 12 11:55:21.625 [INFO ] GUI: SetAudioPlaystate: 0
Sep 12 11:55:21.625 [DEBUG0] MEDIA: MediaIpc::SetupAudioDevice: 0 0 - 0 5 0 - 0
Sep 12 11:55:21.636 [DEBUG2] PHN: KMSG: <7>snom715fb: mmap framebuffer P(3fda000)->V(407e4000), size 1000
Sep 12 11:55:21.637 [NOTICE] PHN: MacAddressMgr::GetMacFromKernelBootParams() cmdline: >console=ttyAMA0,115200n8 root=/dev/mtdblock7 rw rootfstype=jffs2 noinitrd ethaddr=00:04:13:75:C4:23 fwenv=/dev/mtd2,0x0,0x4000,0x20000 mtdparts=bcm_umi-nand:0x000a0000(bootloader),0x000e0000(uboot),0x00080000(ubootenv),0x00400000(rescuekernel),0x00800000(rescuefs),0x000c0000(data),0x00400000(kernel),0x06d40000(rootfs)<
Sep 12 11:55:21.638 [NOTICE] PHN: MacAddressMgr::GetMacFromKernelBootParams() mac: >00:04:13:75:C4:23<
Sep 12 11:55:21.638 [NOTICE] PHN: MacAddressMgr::Get() MAC = >00041375C423<
Sep 12 11:55:21.638 [DEBUG2] PHN: Random seed part from mac: 55122
Sep 12 11:55:21.638 [DEBUG2] PHN: Random seed part from usec: 204235
Sep 12 11:55:21.638 [DEBUG2] PHN: Random seed part from audio: 0
Sep 12 11:55:21.639 [DEBUG1] PHN: Random seed: 248473
Sep 12 11:55:21.639 [INFO ] PHN: Watchdog: setting up
Sep 12 11:55:21.639 [INFO ] PHN: Watchdog: setting ><
Sep 12 11:55:21.639 [INFO ] PHN: Watchdog: open device
Sep 12 11:55:21.640 [INFO ] PHN: Watchdog: set timeout to: 960
Sep 12 11:55:21.640 [INFO ] PHN: Watchdog: triggered
Sep 12 11:55:21.640 [INFO ] PHN: Enabled IP Fragmentation DF-Bit=0
Sep 12 11:55:21.640 [DEBUG2] PHN: send lldp advertisment
Sep 12 11:55:21.640 [NOTICE] PHN: DHCP: with_dhcp_v4:1 ><, with_dhcp_v6:0, autoconfig_only:0 ><
Sep 12 11:55:21.641 [DEBUG2] PHN: DHCP: Received answer for ip allocation
Sep 12 11:55:21.641 [NOTICE] PHN: DHCP: Received IP address 192.168.1.189
Sep 12 11:55:21.641 [NOTICE] PHN: DHCP: Parsing answer of type 2
Sep 12 11:55:21.641 [DEBUG1] PHN: DHCP: Received Lease 172800
Sep 12 11:55:21.641 [NOTICE] PHN: DHCP: Parsing answer of type 5
Sep 12 11:55:21.642 [DEBUG1] PHN: DHCP: Received Lease 172800
Sep 12 11:55:21.642 [INFO ] PHN: IPv4: Init Device eth0 with mac 00:04:13:75:C4:23
Sep 12 11:55:21.642 [DEBUG1] PHN: IPv4Monitor: Device eth0, IP , State device init
Sep 12 11:55:21.642 [WARN ] PHN: Already Initialised eth0
Sep 12 11:55:21.643 [DEBUG0] PHN: IPv4: Start Detection on eth0, IP 192.168.1.189
Sep 12 11:55:21.643 [DEBUG1] PHN: IPv4Monitor: Device eth0, IP 192.168.1.189, State detecting
Sep 12 11:55:21.643 [DEBUG1] PHN: IPv4Monitor: Device eth0, IP 192.168.1.189, State detect no conflict
Sep 12 11:55:21.644 [DEBUG0] PHN: IPv4: Start Defending on eth0, IP 192.168.1.189
Sep 12 11:55:21.644 [DEBUG1] PHN: IPv4Monitor: Device eth0, IP 192.168.1.189, State defend no conflict
Sep 12 11:55:21.645 [INFO ] PHN: DHCP: t1=86400
Sep 12 11:55:21.645 [INFO ] PHN: DHCP: t2=151200, reboot=172790
Sep 12 11:55:21.645 [NOTICE] PHN: Finished waiting for DHCP 4; d4.state = dhcp_finished
Sep 12 11:55:21.645 [NOTICE] PHN: 41: >192.168.1.164< 42: >< 61: >< 62: >< 63: >< 64: >< search4: >Herrmann.local< search6: ><
Sep 12 11:55:21.645 [DEBUG1] PHN: FbAppPrint during lcs2: snom715-SIP 8.9.3.96
Sep 12 11:55:21.646 [DEBUG1] PHN: Connect host: 127.0.0.1
Sep 12 11:55:21.646 [INFO ] PHN: LLDP: No Voice Application Type TLV packet found
Sep 12 11:55:21.646 [DEBUG1] PHN: IPv4Monitor: Device eth0, IP 192.168.1.189, State device none
Sep 12 11:55:21.646 [INFO ] PHN: Phone::uboot_version:2010.12-00003-g3143800
Sep 12 11:55:21.647 [DEBUG2] PHN: [PROXY] Deadwood version 3.2.09
Sep 12 11:55:21.647 [DEBUG2] PHN: [PROXY] Deadwood: A DNS UDP non-recursive cache (IPv6 supported)
Sep 12 11:55:21.647 [DEBUG2] PHN: [PROXY] Verbose_level set to 100
Sep 12 11:55:21.647 [DEBUG2] PHN: [PROXY] We bound to 1 addresses
Sep 12 11:55:21.647 [DEBUG2] PHN: [PROXY] add_constant is set to 0x1e1232b5
Sep 12 11:55:21.647 [DEBUG2] PHN: [PROXY] Got DNS query for \014ucupdates\055r2\010herrmann\005local\000\000\001
Sep 12 11:55:21.650 [DEBUG1] SIP: recv 500 SUBSCRIBE (1:
[email protected]) <- Udp:192.168.1.163:5060
Sep 12 11:55:21.651 [DEBUG2] PHN: [PROXY] Looking in cache for query \014ucupdates\055r2\010herrmann\005local\000\000\001
Sep 12 11:55:21.651 [DEBUG2] PHN: [PROXY] Nothing found for \014ucupdates\055r2\010herrmann\005local\000\000\001
Sep 12 11:55:21.651 [DEBUG2] PHN: [PROXY] Caching direct answer at \014ucupdates\055r2\010herrmann\005local\000\000\001
Sep 12 11:55:21.651 [DEBUG2] PHN: [PROXY] Fetching \014ucupdates\055r2\010herrmann\005local\000\000\001 from cache
Sep 12 11:55:21.651 [DEBUG2] PHN: [PROXY] Got DNS query for \014ucupdates\055r2\010herrmann\005local\010herrmann\005local\000\000\001
Sep 12 11:55:21.652 [DEBUG2] PHN: [PROXY] Looking in cache for query \014ucupdates\055r2\010herrmann\005local\010herrmann\005local\000\000\001
Sep 12 11:55:21.652 [DEBUG2] PHN: [PROXY] Nothing found for \014ucupdates\055r2\010herrmann\005local\010herrmann\005local\000\000\001
Sep 12 11:55:21.739 [DEBUG1] SIP: recv 500 SUBSCRIBE (1:
Sep 12 11:55:22.241 [DEBUG1] SIP: recv 500 SUBSCRIBE (1:
Sep 12 11:55:22.613 [NOTICE] GUI: Display re-enabled.
Sep 12 11:55:22.729 [DEBUG1] SIP: recv 500 SUBSCRIBE (1:
Sep 12 11:55:22.944 [INFO ] PHN: ETH LINK STATUS: changed first time, not yet to propagate. Link: -1
Sep 12 11:55:23.250 [DEBUG1] SIP: recv 500 SUBSCRIBE (1:
Sep 12 11:55:23.656 [NOTICE] PHN: Setting server prio 1, type redirection, url: >http://192.168.1.163:5000/provisioning/lmn2whmh6c/cfg%7Bmac%7D<
Sep 12 11:55:23.656 [NOTICE] PHN: SetProvisioningActive
Sep 12 11:55:23.657 [INFO ] PHN: ProvisioningReplacements: URL >http://192.168.1.163:5000/provisioning/lmn2whmh6c/cfg%7Bmac%7D<
Sep 12 11:55:23.657 [DEBUG0] PHN: Uri Replace >{mac}< in >http://192.168.1.163:5000/provisioning/lmn2whmh6c/cfg%7Bmac%7D<
Sep 12 11:55:23.658 [DEBUG0] PHN: Uri Replaced result: >http://192.168.1.163:5000/provisioning/lmn2whmh6c/cfg00041375C423<
Sep 12 11:55:23.658 [INFO ] PHN: ProvisioningReplacements mac-step result: >http://192.168.1.163:5000/provisioning/lmn2whmh6c/cfg00041375C423<
Sep 12 11:55:23.658 [DEBUG0] PHN: ReplaceQueryVariables in >http://192.168.1.163:5000/provisioning/lmn2whmh6c/cfg00041375C423<
Sep 12 11:55:23.659 [DEBUG0] PHN: ReplaceQueryVariables replaced: >http://192.168.1.163:5000/provisioning/lmn2whmh6c/cfg00041375C423<
Sep 12 11:55:23.659 [NOTICE] PHN: AddSettingUrl http://192.168.1.163:5000/provisioning/lmn2whmh6c/cfg00041375C423
Sep 12 11:55:23.660 [NOTICE] PHN: AddSettingUrl https://127.0.0.1:443/dummy.htm
Sep 12 11:55:23.660 [NOTICE] PHN: Fetching URL: http://192.168.1.163:5000/provisioning/lmn2whmh6c/cfg00041375C423
Sep 12 11:55:23.661 [DEBUG2] WEBCLIENT: Send TCP none
Sep 12 11:55:23.662 [DEBUG2] WEBCLIENT: Socket 19 connecting
Sep 12 11:55:24.636 [DEBUG1] PHN: Add Cache: ucupdates-r2.herrmann.local= (ttl=60, type=5)
Sep 12 11:55:24.636 [DEBUG0] PHN: AddrInfo for 'ucupdates-r2.herrmann.local' invalid, error: Name or service not known (-2)
Sep 12 11:55:24.636 [DEBUG2] PHN: TplSocket::SetNextIp: ip_list_.size()=1, ip_list_.front()=invalid.ip
Sep 12 11:55:24.636 [DEBUG2] PHN: TplSocket::SetNextIp: ip_list_ is empty
Sep 12 11:55:24.636 [WARN ] PHN: Could not resolve host >ucupdates-r2.Herrmann.local<
Sep 12 11:55:24.636 [DEBUG2] WEBCLIENT: Socket 17 dns_resolve_cache_lookup_has_failed
Sep 12 11:55:24.637 [WARN ] WEBCLIENT: Could not resolve host ucupdates-r2.Herrmann.local
Sep 12 11:55:24.637 [DEBUG2] WEBCLIENT: Socket 17 disconnected
Sep 12 11:55:24.637 [DEBUG2] WEBCLIENT: Socket 17 deleted
Sep 12 11:55:24.637 [NOTICE] PHN: ProvUtils::UcFirmwareUpdateAvailableResponseReceived code: 400
Sep 12 11:55:28.964 [INFO ] PHN: ETH LINK STATUS: changed first time, not yet to propagate. Link: -1
Sep 12 11:55:29.974 [INFO ] PHN: LAN port status: propagated (1)
Sep 12 11:55:39.265 [INFO ] PHN: LLDP: No Voice Application Type TLV packet found
Sep 12 11:55:44.654 [ERROR ] PHN: TPL: Socket Error: 19/34/connecting, connect_cb -> Success (0)
Sep 12 11:55:44.654 [DEBUG2] WEBCLIENT: webclient OnConnectionFailed
Sep 12 11:55:44.655 [DEBUG2] PHN: TplSocket::SetNextIp: ip_list_ is empty
Sep 12 11:55:44.655 [DEBUG2] WEBCLIENT: Socket 19 disconnected
Sep 12 11:55:44.655 [DEBUG2] WEBCLIENT: socket:19 conn_id:2 disconnected Tcp:192.168.1.163:5000
Sep 12 11:55:44.655 [NOTICE] WEBCLIENT: on_tcp_close conn_id:2
Sep 12 11:55:44.655 [DEBUG2] WEBCLIENT: Socket 19 deleted
Sep 12 11:55:44.656 [INFO ] PHN: Config setup: code: 500, uri: http://192.168.1.163:5000/provisioning/lmn2whmh6c/cfg00041375C423
Sep 12 11:55:44.656 [NOTICE] PHN: AddSettingUrl http://192.168.1.163:5000/provisioning/lmn2whmh6c/cfg00041375C423
Sep 12 11:55:44.656 [NOTICE] PHN: Config setup: return code 500; requeueing >http://192.168.1.163:5000/provisioning/lmn2whmh6c/cfg00041375C423<; attempt: 1, state: 6, duration: 20/86
Sep 12 11:55:46.657 [DEBUG0] PHN: TaskMon: LCS/338 PollEvent took 2004 msecs, started Sep 12 11:55:44
Sep 12 11:55:46.657 [DEBUG0] PHN: LoopMon: LCS/338 took 2129 (325) msecs, started Sep 12 11:55:44, 2 tasks
Sep 12 11:55:46.660 [NOTICE] PHN: Fetching URL: http://192.168.1.163:5000/provisioning/lmn2whmh6c/cfg00041375C423
Sep 12 11:55:46.661 [DEBUG2] WEBCLIENT: Send TCP none
Sep 12 11:55:46.663 [DEBUG2] WEBCLIENT: Socket 20 connecting
Sep 12 11:55:48.846 [DEBUG2] PHN: send lldp advertisment
Sep 12 11:55:53.653 [DEBUG1] SIP: remove receive packet: 1, all 5
Sep 12 11:55:53.743 [DEBUG1] SIP: remove receive packet: 2, all 4
Sep 12 11:55:54.243 [DEBUG1] SIP: remove receive packet: 3, all 3
Sep 12 11:55:54.733 [DEBUG1] SIP: remove receive packet: 4, all 2
Sep 12 11:55:55.253 [DEBUG1] SIP: remove receive packet: 5, all 1
Sep 12 11:56:07.653 [ERROR ] PHN: TPL: Socket Error: 20/27/connecting, connect_cb -> Success (0)
Sep 12 11:56:07.654 [DEBUG2] WEBCLIENT: webclient OnConnectionFailed
Sep 12 11:56:07.655 [DEBUG2] PHN: TplSocket::SetNextIp: ip_list_ is empty
Sep 12 11:56:07.655 [DEBUG2] WEBCLIENT: Socket 20 disconnected
Sep 12 11:56:07.655 [DEBUG2] WEBCLIENT: socket:20 conn_id:3 disconnected Tcp:192.168.1.163:5000
Sep 12 11:56:07.655 [NOTICE] WEBCLIENT: on_tcp_close conn_id:3
Sep 12 11:56:07.655 [DEBUG2] WEBCLIENT: Socket 20 deleted
Sep 12 11:56:07.656 [INFO ] PHN: Config setup: code: 500, uri: http://192.168.1.163:5000/provisioning/lmn2whmh6c/cfg00041375C423
Sep 12 11:56:07.656 [NOTICE] PHN: AddSettingUrl http://192.168.1.163:5000/provisioning/lmn2whmh6c/cfg00041375C423
Sep 12 11:56:07.656 [NOTICE] PHN: Config setup: return code 500; requeueing >http://192.168.1.163:5000/provisioning/lmn2whmh6c/cfg00041375C423<; attempt: 2, state: 6, duration: 43/86
Sep 12 11:56:09.657 [DEBUG0] PHN: TaskMon: LCS/736 PollEvent took 2003 msecs, started Sep 12 11:56:07
Sep 12 11:56:09.657 [DEBUG0] PHN: LoopMon: LCS/736 took 2060 (267) msecs, started Sep 12 11:56:07, 1 tasks
Sep 12 11:56:09.660 [NOTICE] PHN: Fetching URL: http://192.168.1.163:5000/provisioning/lmn2whmh6c/cfg00041375C423
Sep 12 11:56:09.661 [DEBUG2] WEBCLIENT: Send TCP none
Sep 12 11:56:09.662 [DEBUG2] WEBCLIENT: Socket 21 connecting
Sep 12 11:56:09.664 [INFO ] PHN: LLDP: No Voice Application Type TLV packet found
Sep 12 11:56:17.953 [DEBUG1] PHN: Sending Keepalive to Watchdog
Sep 12 11:56:17.956 [INFO ] PHN: Watchdog: keep fd dog = 5
Sep 12 11:56:17.956 [INFO ] PHN: Watchdog: set timing to: 60
Sep 12 11:56:24.643 [DEBUG1] PHN: Removing addrinfo ucupdates-r2.herrmann.local:
Sep 12 11:56:30.653 [ERROR ] PHN: TPL: Socket Error: 21/27/connecting, connect_cb -> Success (0)
Sep 12 11:56:30.654 [DEBUG2] WEBCLIENT: webclient OnConnectionFailed
Sep 12 11:56:30.655 [DEBUG2] PHN: TplSocket::SetNextIp: ip_list_ is empty
Sep 12 11:56:30.655 [DEBUG2] WEBCLIENT: Socket 21 disconnected
Sep 12 11:56:30.655 [DEBUG2] WEBCLIENT: socket:21 conn_id:4 disconnected Tcp:192.168.1.163:5000
Sep 12 11:56:30.655 [NOTICE] WEBCLIENT: on_tcp_close conn_id:4
Sep 12 11:56:30.655 [DEBUG2] WEBCLIENT: Socket 21 deleted
Sep 12 11:56:30.656 [INFO ] PHN: Config setup: code: 500, uri: http://192.168.1.163:5000/provisioning/lmn2whmh6c/cfg00041375C423
Sep 12 11:56:30.656 [NOTICE] PHN: AddSettingUrl http://192.168.1.163:5000/provisioning/lmn2whmh6c/cfg00041375C423
Sep 12 11:56:30.656 [NOTICE] PHN: Config setup: return code 500; requeueing >http://192.168.1.163:5000/provisioning/lmn2whmh6c/cfg00041375C423<; attempt: 3, state: 6, duration: 66/86
Sep 12 11:56:32.657 [DEBUG0] PHN: TaskMon: LCS/1133 PollEvent took 2003 msecs, started Sep 12 11:56:30
Sep 12 11:56:32.657 [DEBUG0] PHN: LoopMon: LCS/1133 took 2281 (497) msecs, started Sep 12 11:56:30, 2 tasks
Sep 12 11:56:32.660 [NOTICE] PHN: Fetching URL: http://192.168.1.163:5000/provisioning/lmn2whmh6c/cfg00041375C423
Sep 12 11:56:32.661 [DEBUG2] WEBCLIENT: Send TCP none
Sep 12 11:56:32.662 [DEBUG2] WEBCLIENT: Socket 22 connecting
Sep 12 11:56:39.316 [INFO ] PHN: LLDP: No Voice Application Type TLV packet found
Sep 12 11:56:47.963 [DEBUG1] PHN: Sending Keepalive to Watchdog
Sep 12 11:56:47.966 [INFO ] PHN: Watchdog: keep fd dog = 5
Sep 12 11:56:48.856 [DEBUG2] PHN: send lldp advertisment
Sep 12 11:56:53.653 [ERROR ] PHN: TPL: Socket Error: 22/27/connecting, connect_cb -> Success (0)
Sep 12 11:56:53.654 [DEBUG2] WEBCLIENT: webclient OnConnectionFailed
Sep 12 11:56:53.655 [DEBUG2] PHN: TplSocket::SetNextIp: ip_list_ is empty
Sep 12 11:56:53.655 [DEBUG2] WEBCLIENT: Socket 22 disconnected
Sep 12 11:56:53.655 [DEBUG2] WEBCLIENT: socket:22 conn_id:5 disconnected Tcp:192.168.1.163:5000
Sep 12 11:56:53.655 [NOTICE] WEBCLIENT: on_tcp_close conn_id:5
Sep 12 11:56:53.655 [DEBUG2] WEBCLIENT: Socket 22 deleted
Sep 12 11:56:53.656 [INFO ] PHN: Config setup: code: 500, uri: http://192.168.1.163:5000/provisioning/lmn2whmh6c/cfg00041375C423
Sep 12 11:56:53.656 [NOTICE] PHN: SetProvisioningDone
Sep 12 11:56:53.656 [NOTICE] PHN: Config setup: return code 500; giving up on >http://192.168.1.163:5000/provisioning/lmn2whmh6c/cfg00041375C423<
Sep 12 11:56:53.657 [NOTICE] PHN: SetProvisioningDone
Sep 12 11:56:53.657 [NOTICE] PHN: Skipping prio 2 setting server, type pnp, url: ><
Sep 12 11:56:53.657 [NOTICE] PHN: Skipping prio 3 setting server, type dhcp, url: ><
Sep 12 11:56:53.657 [NOTICE] PHN: Skipping prio 4 setting server, type tr69, url: ><
Sep 12 11:56:53.657 [NOTICE] PHN: Go to wizzard if all settings have been read.
Sep 12 11:56:53.667 [INFO ] PHN: MessageTrace::InitTrace: SIP Trace initialized: enabled=1, max_trace_size=100, max_body_size=-1
Sep 12 11:56:53.668 [NOTICE] PHN: ExpansionDisplay::InitAll: loading fonts
Sep 12 11:56:53.716 [DEBUG0] PHN: MonochromeFontInterface::LoadFont: font_id=1, font_path_name=/snom/fonts/snomfont_v02.bdf, size=14, real_size=18, pixel_size=0, base_line=-2, space_width=8
Sep 12 11:56:53.929 [DEBUG0] PHN: MonochromeFontInterface::LoadFont: font_id=2, font_path_name=/snom/fonts/mono-bold-de.ttf, size=14, real_size=14, pixel_size=14, base_line=-2, space_width=4
Sep 12 11:56:53.929 [DEBUG0] PHN: MonochromeFontInterface::LoadFont: font_id=1, font_path_name=/snom/fonts/snomfont_v02.bdf, size=14, real_size=18, pixel_size=0, base_line=-2, space_width=8
Sep 12 11:56:54.018 [DEBUG0] MEDIA: MediaIpc::setLogLevel: 4
