03/08/2019 8:44:04 AM - Leg L:387.1[Line:10000<<{{CallerNr}}] is terminated: Cause: BYE from local
03/08/2019 8:44:04 AM - L:387.1[Line:10000<<{{CallerNr}}] got Terminated Send Req BYE from 0.0.0.0:0 tid=96328076254ca807 Call-ID=SBCsnlh924l7h9n5h95qh1aels75he7a5sr@SoftX3000_b2b-1:
BYE sip:3C06448F-5C821D1F000DCD9A-7D3D3700@{{TrunkProviderIp}}:5064;transport=udp SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---96328076254ca807;rport
Max-Forwards: 70
Contact: <sip:{{RedirectionNr}}@{{TkIp}}:5060>
To: <sip:{{CallerNr}}@{{TrunkProviderUrl}}>;tag=64BAF5C9-5C821D1F000DB8F2-5788A700
From: <sip:{{RedirectionNr}}@{{TrunkProviderUrl}}>;tag=d07c8920
Call-ID: SBCsnlh924l7h9n5h95qh1aels75he7a5sr@SoftX3000_b2b-1
CSeq: 6 BYE
User-Agent: 3CXPhoneSystem 15.5.15502.6 (15502)
Content-Length: 0
03/08/2019 8:44:04 AM - Terminated from <sip:{{CallerNr}}@{{TrunkProviderUrl}}>;tag=64BAF5C9-5C821D1F000DB8F2-5788A700 to <sip:{{RedirectionNr}}@{{TrunkProviderUrl}}>;tag=d07c8920; reason: LocalBye
03/08/2019 8:44:04 AM - L:387.1[Line:10000<<{{CallerNr}}] Sending: OnSendReq Send Req BYE from 0.0.0.0:0 tid=2e0512126737ae4d Call-ID=SBCsnlh924l7h9n5h95qh1aels75he7a5sr@SoftX3000_b2b-1:
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---2e0512126737ae4d;rport
Max-Forwards: 70
CSeq: 6 BYE
Content-Length: 0
03/08/2019 8:44:04 AM - SendMsg from <sip:{{RedirectionNr}}@{{TrunkProviderUrl}}>;tag=d07c8920 to <sip:{{CallerNr}}@{{TrunkProviderUrl}}>;tag=64BAF5C9-5C821D1F000DB8F2-5788A700
03/08/2019 8:44:04 AM - [CM503008]: Call(C:387): Call is terminated
03/08/2019 8:44:04 AM - Blocking refers for the Call(C:387)
03/08/2019 8:44:04 AM - Call(C:387) is terminated
03/08/2019 8:44:04 AM - Leg L:387.3[Queue:8004] is terminated: Cause: BYE from 127.0.0.1:5488
03/08/2019 8:44:04 AM - L:387.3[Queue:8004] got Terminated Recv Req BYE from 127.0.0.1:5488 tid=0a624c206964df23 Call-ID=U1bp6uFUISioRasOh3VNiA..:
BYE sip:{{CallerNr}}@127.0.0.1:5060 SIP/2.0
Via: SIP/2.0/UDP 127.0.0.1:5488;branch=z9hG4bK-524287-1---0a624c206964df23;rport=5488
Max-Forwards: 70
Contact: <sip:
[email protected]:5488;rinstance=d0403e624c991c0a>
To: <sip:{{CallerNr}}@127.0.0.1:5060;nf=e>;tag=ee5b1b6b
[email protected]>;tag=9a763a7a
Call-ID: U1bp6uFUISioRasOh3VNiA..
CSeq: 6 BYE
User-Agent: 3CX Queue Manager (q=8004)
Reason: SIP;text=User Hung Up
Content-Length: 0
[email protected]>;tag=9a763a7a to <sip:{{CallerNr}}@127.0.0.1:5060;nf=e>;tag=ee5b1b6b; reason: RemoteBye
03/08/2019 8:44:04 AM - L:387.3[Queue:8004] Sending: OnSendResp Send 200/BYE from 0.0.0.0:0 tid=0a624c206964df23 Call-ID=U1bp6uFUISioRasOh3VNiA..:
SIP/2.0 200 OK
Contact: <sip:{{CallerNr}}@127.0.0.1:5060>
CSeq: 6 BYE
Content-Length: 0
03/08/2019 8:44:04 AM - SendMsg from <sip:{{CallerNr}}@127.0.0.1:5060;nf=e>;tag=ee5b1b6b to <sip:
03/08/2019 8:44:04 AM - Default best-route IP is determined as {{LocaleIp}}
03/08/2019 8:44:04 AM - Leg L:387.4[Line:10000>>{{RedirectionNr}}] is terminated: Cause: BYE from {{TrunkProviderIp}}:5064
03/08/2019 8:44:04 AM - L:387.4[Line:10000>>{{RedirectionNr}}] got Terminated Recv Req BYE from {{TrunkProviderIp}}:5064 tid=FMdPraw7cU3W7 Call-ID=ft3qqyamaXv1dWgqp5ac0g..:
BYE sip:004989{{OurNumber}}@{{TkIp}}:5060 SIP/2.0
Via: SIP/2.0/UDP {{TrunkProviderIp}}:5064;branch=z9hG4bKFMdPraw7cU3W7;rport=5064
Max-Forwards: 67
To: "{{CallerNr}}" <sip:004989{{OurNumber}}@{{TrunkProviderUrl}}:5064>;tag=14229d09
From: <sip:{{RedirectionNr}}@{{TrunkProviderUrl}}:5064>;tag=7E2DA73C-5C821D3C000493CA-4CF23700
Call-ID: ft3qqyamaXv1dWgqp5ac0g..
CSeq: 10 BYE
Reason: Q.850;cause=41, SIP;cause=503;text="Service Unavailable"
Content-Length: 0
03/08/2019 8:44:04 AM - Terminated from <sip:{{RedirectionNr}}@{{TrunkProviderUrl}}:5064>;tag=7E2DA73C-5C821D3C000493CA-4CF23700 to "{{CallerNr}}"<sip:004989{{OurNumber}}@{{TrunkProviderUrl}}:5064>;tag=14229d09; reason: RemoteBye
03/08/2019 8:44:04 AM - L:387.4[Line:10000>>{{RedirectionNr}}] Sending: OnSendResp Send 200/BYE from 0.0.0.0:0 tid=FMdPraw7cU3W7 Call-ID=ft3qqyamaXv1dWgqp5ac0g..:
SIP/2.0 200 OK
Contact: <sip:004989{{OurNumber}}@{{TkIp}}:5060>
To: "{{CallerNr}}"<sip:004989{{OurNumber}}@{{TrunkProviderUrl}}:5064>;tag=14229d09
CSeq: 10 BYE
Content-Length: 0
03/08/2019 8:44:04 AM - SendMsg from "{{CallerNr}}"<sip:004989{{OurNumber}}@{{TrunkProviderUrl}}:5064>;tag=14229d09 to <sip:{{RedirectionNr}}@{{TrunkProviderUrl}}:5064>;tag=7E2DA73C-5C821D3C000493CA-4CF23700
03/08/2019 8:44:03 AM - L:387.4[Line:10000>>{{RedirectionNr}}] Sending: OnSendReq Send Req ACK from 0.0.0.0:0 tid=a6014a16ee0baf5e Call-ID=ft3qqyamaXv1dWgqp5ac0g..:
ACK sip:52469044-5C821D3C00032C5B-28212700@{{TrunkProviderIp}}:5064;transport=udp SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---a6014a16ee0baf5e;rport
Max-Forwards: 70
To: <sip:{{RedirectionNr}}@{{TrunkProviderUrl}}:5064>;tag=7E2DA73C-5C821D3C000493CA-4CF23700
From: "{{CallerNr}}"<sip:004989{{OurNumber}}@{{TrunkProviderUrl}}:5064>;tag=14229d09
CSeq: 2 ACK
Content-Type: application/sdp
Content-Length: 131
v=0
o=3cxPS 261607129088 264660582401 IN IP4 {{TkIp}}
s=3cxPS Audio call
c=IN IP4 {{TkIp}}
t=0 0
m=audio 0 RTP/AVP
03/08/2019 8:44:03 AM - SendMsg from "{{CallerNr}}"<sip:004989{{OurNumber}}@{{TrunkProviderUrl}}:5064>;tag=14229d09 to <sip:{{RedirectionNr}}@{{TrunkProviderUrl}}:5064>;tag=7E2DA73C-5C821D3C000493CA-4CF23700
03/08/2019 8:44:03 AM - Providing SDP for Refer.Target
03/08/2019 8:44:03 AM - Reneg. from L:387.1[Line:10000<<{{CallerNr}}], answer
03/08/2019 8:44:03 AM - Remote SDP is set for leg L:387.1[Line:10000<<{{CallerNr}}]
03/08/2019 8:44:03 AM - Answer SDP arrived on Leg L:387.1[Line:10000<<{{CallerNr}}];
OnAnswer Recv 200/INVITE from {{TrunkProviderIp}}:5064 tid=ac0105291179f544 Call-ID=SBCsnlh924l7h9n5h95qh1aels75he7a5sr@SoftX3000_b2b-1:
SIP/2.0 200 OK
Via: SIP/2.0/UDP {{LocaleIp}}:5060;branch=z9hG4bK-524287-1---ac0105291179f544;rport=5060;received={{TkIp}}
Contact: <sip:3C06448F-5C821D1F000DCD9A-7D3D3700@{{TrunkProviderIp}}:5064;transport=udp>
CSeq: 5 INVITE
Content-Length: 218
v=0
o=- 36885944 36885948 IN IP4 {{TrunkProviderIp}}
s=-
c=IN IP4 {{TrunkProviderIp}}
t=0 0
m=audio 39712 RTP/AVP 8 101
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=direction:both
a=sendrecv
03/08/2019 8:44:03 AM - L:387.1[Line:10000<<{{CallerNr}}] Sending: OnSendReq Send Req ACK from 0.0.0.0:0 tid=f33dce624308f719 Call-ID=SBCsnlh924l7h9n5h95qh1aels75he7a5sr@SoftX3000_b2b-1:
ACK sip:3C06448F-5C821D1F000DCD9A-7D3D3700@{{TrunkProviderIp}}:5064;transport=udp SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---f33dce624308f719;rport
Max-Forwards: 70
CSeq: 5 ACK
Content-Length: 0
03/08/2019 8:44:03 AM - SendMsg from <sip:{{RedirectionNr}}@{{TrunkProviderUrl}}>;tag=d07c8920 to <sip:{{CallerNr}}@{{TrunkProviderUrl}}>;tag=64BAF5C9-5C821D1F000DB8F2-5788A700
03/08/2019 8:44:03 AM - Sending: OnSendReq Send Req NOTIFY from 0.0.0.0:0 tid=b75bc671bc502728 Call-ID=U1bp6uFUISioRasOh3VNiA..:
NOTIFY sip:
[email protected]:5488;rinstance=d0403e624c991c0a SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---b75bc671bc502728;rport
Max-Forwards: 70
To: <sip:
From: <sip:{{CallerNr}}@127.0.0.1:5060;nf=e>;tag=ee5b1b6b
CSeq: 3 NOTIFY
Content-Type: message/sipfrag
Subscription-State: terminated;reason=noresource
Event: refer;id=4
Content-Length: 18
SIP/2.0 200 OK
03/08/2019 8:44:03 AM - [CM503007]: Call(C:387): Line:10000>>{{RedirectionNr}} has joined, contact <sip:004989{{OurNumber}}@{{TrunkProviderUrl}}:5064>
03/08/2019 8:44:03 AM - ~Target=VoIPline:{{RedirectionNr}}@(Ln.10000@{{TrunkName}})
03/08/2019 8:44:03 AM - L:387.1[Line:10000<<{{CallerNr}}] Sending: OnSendReq Send Req INVITE from 0.0.0.0:0 tid=8b3f1f6d70098b12 Call-ID=SBCsnlh924l7h9n5h95qh1aels75he7a5sr@SoftX3000_b2b-1:
INVITE sip:3C06448F-5C821D1F000DCD9A-7D3D3700@{{TrunkProviderIp}}:5064;transport=udp SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---8b3f1f6d70098b12;rport
Max-Forwards: 70
CSeq: 5 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE, UPDATE
Supported: replaces, timer
Content-Length: 250
v=0
o=3cxPS 368981311488 305227890693 IN IP4 {{TkIp}}
s=3cxPS Audio call
c=IN IP4 {{TkIp}}
t=0 0
m=audio 9538 RTP/AVP 8 0 101
a=rtpmap:0 PCMU/8000
a=fmtp:101 0-15
a=sendrecv
03/08/2019 8:44:03 AM - Outbound CID reformat rule for DN:10000 is disabled (<Rules />)
03/08/2019 8:44:03 AM - ~Route=Dev:sip:004989{{OurNumber}}@{{TrunkProviderUrl}}:5064
03/08/2019 8:44:03 AM - L:387.4[Line:10000>>{{RedirectionNr}}] has joined to L:387.1[Line:10000<<{{CallerNr}}]
03/08/2019 8:44:03 AM - OnOffer from <sip:{{RedirectionNr}}@{{TrunkProviderUrl}}:5064>
03/08/2019 8:44:03 AM - L:387.4[Line:10000>>{{RedirectionNr}}] got Connected.UAC Recv 200/INVITE from {{TrunkProviderIp}}:5064 tid=6f79e337d317a86d Call-ID=ft3qqyamaXv1dWgqp5ac0g..:
SIP/2.0 200 OK
Via: SIP/2.0/UDP {{LocaleIp}}:5060;branch=z9hG4bK-524287-1---6f79e337d317a86d;rport=5060;received={{TkIp}}
Contact: <sip:52469044-5C821D3C00032C5B-28212700@{{TrunkProviderIp}}:5064;transport=udp>
CSeq: 2 INVITE
Accept: application/sdp, application/isup, application/dtmf, application/dtmf-relay, multipart/mixed
Allow: INVITE, ACK, CANCEL, BYE, REGISTER, SUBSCRIBE, NOTIFY, PRACK, UPDATE, OPTIONS, MESSAGE, PUBLISH
Content-Length: 202
v=0
o=- 962403 335179 IN IP4 {{TrunkProviderIp}}
s=-
t=0 0
m=audio 39042 RTP/AVP 100
a=rtpmap:100 telephone-event/8000
a=fmtp:100 0-15
a=direction:both
a=sendrecv
a=ptime:20
03/08/2019 8:44:03 AM - Connected(UAC) from <sip:{{RedirectionNr}}@{{TrunkProviderUrl}}:5064>;tag=7E2DA73C-5C821D3C000493CA-4CF23700 to "{{CallerNr}}"<sip:004989{{OurNumber}}@{{TrunkProviderUrl}}:5064>;tag=14229d09
03/08/2019 8:44:03 AM - Remote SDP is set for leg L:387.4[Line:10000>>{{RedirectionNr}}]
03/08/2019 8:44:03 AM - Offer SDP arrived on Leg L:387.4[Line:10000>>{{RedirectionNr}}];
OnOffer Recv 200/INVITE from {{TrunkProviderIp}}:5064 tid=6f79e337d317a86d Call-ID=ft3qqyamaXv1dWgqp5ac0g..:
SIP/2.0 200 OK
CSeq: 2 INVITE
Content-Length: 202
v=0
s=-
t=0 0
a=fmtp:100 0-15
a=direction:both
a=sendrecv
a=ptime:20
03/08/2019 8:44:01 AM - Currently active calls - 1: [387]
03/08/2019 8:44:01 AM - L:387.4[Line:10000>>{{RedirectionNr}}] got Provisional Recv 183/INVITE from {{TrunkProviderIp}}:5064 tid=6f79e337d317a86d Call-ID=ft3qqyamaXv1dWgqp5ac0g..:
SIP/2.0 183 Session Progress
CSeq: 2 INVITE
Content-Length: 0
03/08/2019 8:44:01 AM - Provisional(183) from <sip:{{RedirectionNr}}@{{TrunkProviderUrl}}:5064>;tag=7E2DA73C-5C821D3C000493CA-4CF23700 to "{{CallerNr}}"<sip:004989{{OurNumber}}@{{TrunkProviderUrl}}:5064>;tag=14229d09
03/08/2019 8:43:58 AM - Updating device Dev(2034203768):[sip:
[email protected]:5483;rinstance=d0163ab6a59c5a61 / 7000] by message: DevUpd Recv Req REGISTER from 127.0.0.1:5483 tid=274f4821d4311518 Call-ID=Sl1CkIAKnI3kV2QYb9KRSA..:
REGISTER sip:127.0.0.1:5060 SIP/2.0
Via: SIP/2.0/UDP 127.0.0.1:5483;branch=z9hG4bK-524287-1---274f4821d4311518;rport=5483
Max-Forwards: 70
Contact: <sip:
[email protected]:5483;rinstance=d0163ab6a59c5a61>
To: "Conference Room7000:"<sip:
[email protected]:5060>
[email protected]:5060>;tag=4613fc5f
Call-ID: Sl1CkIAKnI3kV2QYb9KRSA..
CSeq: 36170 REGISTER
Expires: 60
Proxy-Authorization: Digest username="7000",realm="3CXPhoneSystem",nonce="414d535c1292ae3e46:f8f43778c61e49b75ebab530493886e2",uri="sip:127.0.0.1:5060",response="2d26c354c5fbe0a95e0298e4b101c5fd",algorithm=MD5
Supported: replaces
User-Agent: 3CX Conference Room
Content-Length: 0
03/08/2019 8:43:57 AM - L:387.4[Line:10000>>{{RedirectionNr}}] got Provisional Recv 183/INVITE from {{TrunkProviderIp}}:5064 tid=6f79e337d317a86d Call-ID=ft3qqyamaXv1dWgqp5ac0g..:
CSeq: 2 INVITE
Content-Length: 0
03/08/2019 8:43:57 AM - Provisional(183) from <sip:{{RedirectionNr}}@{{TrunkProviderUrl}}:5064>;tag=7E2DA73C-5C821D3C000493CA-4CF23700 to "{{CallerNr}}"<sip:004989{{OurNumber}}@{{TrunkProviderUrl}}:5064>;tag=14229d09
03/08/2019 8:43:57 AM - [CM505003]: Provider:[{{TrunkName}}] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:004989{{OurNumber}}@{{TkIp}}:5060]
03/08/2019 8:43:57 AM - [CM503002]: Call(C:387): Alerting Line:10000>>{{RedirectionNr}} by contact <sip:004989{{OurNumber}}@{{TrunkProviderUrl}}:5064>
03/08/2019 8:43:57 AM - Answer from <sip:{{RedirectionNr}}@{{TrunkProviderUrl}}:5064>;tag=7E2DA73C-5C821D3C000493CA-4CF23700 to "{{CallerNr}}"<sip:004989{{OurNumber}}@{{TrunkProviderUrl}}:5064>;tag=14229d09
03/08/2019 8:43:56 AM - [CM503025]: Call(C:387): Calling T:Line:10000>>{{RedirectionNr}}@[Dev:sip:004989{{OurNumber}}@{{TrunkProviderUrl}}:5064] for L:387.1[Line:10000<<{{CallerNr}}]
03/08/2019 8:43:56 AM - Route to L:387.4[Line:10000>>{{RedirectionNr}}] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=444cec61f340cd47 Call-ID=ft3qqyamaXv1dWgqp5ac0g..:
INVITE sip:{{RedirectionNr}}@{{TrunkProviderUrl}}:5064 SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---444cec61f340cd47;rport
Max-Forwards: 70
CSeq: 1 INVITE
Content-Length: 0
03/08/2019 8:43:56 AM - Outbound CID reformat rule for DN:10000 is disabled (<Rules />)
03/08/2019 8:43:56 AM - Dev(1137261301):[sip:004989{{OurNumber}}@{{TrunkProviderUrl}}:5064 / 004989{{OurNumber}}]: PBX contact is public IP: <sip:004989{{OurNumber}}@{{TkIp}}:5060>
03/08/2019 8:43:56 AM - Outbound URI is used: sip:004989{{OurNumber}}@{{TrunkProviderIp}}:5064
03/08/2019 8:43:56 AM - SLA is globally disabled
03/08/2019 8:43:56 AM - Added leg L:387.4[Line:10000>>{{RedirectionNr}}]
03/08/2019 8:43:56 AM - Sending: OnSendReq Send Req NOTIFY from 0.0.0.0:0 tid=26513d6e19334e79 Call-ID=U1bp6uFUISioRasOh3VNiA..:
NOTIFY sip:
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---26513d6e19334e79;rport
Max-Forwards: 70
To: <sip:
CSeq: 2 NOTIFY
Subscription-State: init;expires=60
Event: refer;id=4
Content-Length: 22
SIP/2.0 100 Trying
03/08/2019 8:43:56 AM - Sending: OnSendResp Send 202/REFER from 0.0.0.0:0 tid=4568850da8177b6e Call-ID=U1bp6uFUISioRasOh3VNiA..:
SIP/2.0 202 OK
Via: SIP/2.0/UDP 127.0.0.1:5488;branch=z9hG4bK-524287-1---4568850da8177b6e;rport=5488
CSeq: 4 REFER
Expires: 60
Content-Length: 0
03/08/2019 8:43:56 AM - [Flow] Call(C:387): making call from L:387.1[Line:10000<<{{CallerNr}}] to T:Line:10000>>{{RedirectionNr}}@[Dev:sip:004989{{OurNumber}}@{{TrunkProviderUrl}}:5064]
03/08/2019 8:43:56 AM - [CM503027]: Call(C:387): From: Line:10000<<{{CallerNr}} (<sip:{{CallerNr}}@{{Our3cxFQDN}}:5060>) to T:Line:10000>>{{RedirectionNr}}@[Dev:sip:004989{{OurNumber}}@{{TrunkProviderUrl}}:5064]
03/08/2019 8:43:56 AM - [CM503004]: Call(C:387): Route 1: from L:387.1[Line:10000<<{{CallerNr}}] to T:Line:10000>>{{RedirectionNr}}@[Dev:sip:004989{{OurNumber}}@{{TrunkProviderUrl}}:5064]
03/08/2019 8:43:56 AM - Line limit check: Current # of calls for line Lc:10000(@{{TrunkName}}[<sip:004989{{OurNumber}}@{{TrunkProviderUrl}}:5064>]) is 1; limit is 100
03/08/2019 8:43:56 AM - Call(C:387): Call from Line:10000<<{{CallerNr}} to {{RedirectionNr}} matches outbound rule 'Outgoing'
03/08/2019 8:43:56 AM - [Flow] Call(C:387): has built target endpoint: Out#:>>Rule{Outgoing}>>{{RedirectionNr}} for call from L:387.1[Line:10000<<{{CallerNr}}]
03/08/2019 8:43:56 AM - [Flow] Target endpoint for {{RedirectionNr}} is Out#:>>Rule{Outgoing}>>{{RedirectionNr}}
03/08/2019 8:43:56 AM - Looking for outbound rule: dialed = [{{RedirectionNr}}], processed: [{{RedirectionNr}}]; from-ext:
03/08/2019 8:43:56 AM - [Flow] Building target endpoint to {{RedirectionNr}} from <sip:{{CallerNr}}@{{Our3cxFQDN}}:5060>
03/08/2019 8:43:56 AM - [CM503010]: Call(C:387): Making route(s) from Line:10000<<{{CallerNr}} to <sip:{{RedirectionNr}}@127.0.0.1:5060>
03/08/2019 8:43:56 AM - L:387.1[Line:10000<<{{CallerNr}}]: Updated OutCID: '004989{{OurNumber}}00' and DNName: ''
03/08/2019 8:43:56 AM - Call(C:387): Referred(i): src=<sip:{{CallerNr}}@{{Our3cxFQDN}}:5060;nf=e>; dst=<sip:
03/08/2019 8:43:56 AM - [Flow] Refer: RefTo=<sip:{{RedirectionNr}}@127.0.0.1:5060>; was call from=<sip:
[email protected]:5060> to=<sip:{{CallerNr}}@127.0.0.1:5060>
03/08/2019 8:43:56 AM - Call transfer requested on Leg L:387.3[Queue:8004]; subscr. ID=Refer.SrvSubscr(297561){
[email protected]}
Refer Recv Req REFER from 127.0.0.1:5488 tid=4568850da8177b6e Call-ID=U1bp6uFUISioRasOh3VNiA..:
REFER sip:{{CallerNr}}@127.0.0.1:5060 SIP/2.0
Max-Forwards: 70
Contact: <sip:
CSeq: 4 REFER
Refer-To: <sip:{{RedirectionNr}}@127.0.0.1:5060>
Referred-By: <sip:
[email protected]>
Content-Length: 0
