BLF: Manually Configuring a Linksys SPA 901, 921, 941, 922, 942, 962 for 3CX
voip2hh
17. Dezember 2014
In der offiziellen Anleitung steht nur wie man die Erweiterungs-Units konfiguriert.
Hier eine kleine ToDo wie man die Tasten rechts neben dem Display konfiguriert:
1. Login into your Linksys Phone in advanced mode: http: //192.168.XXX.XXX/admin/advanced
2. enter on top the "Phone" tab
3. The Kes:
Line Key 1 = dont change this settings (extension phone line)
Line Key 2-6
- Extension: Disabled
- Short Name: Mr. Smith (this will be display on the screen)
- Share Call Appearance: private
- Extended Function: fnc=sd+blf+cp;sub=123@$PROXY;ext=123@$PROXY (the value "123" represents the extension)
Quelle: https://supportforums.cisco.com/discussion/10856141/spa962-blf-konfig
Zitat:
Log in to the web administration interface.
Click Admin Login.
Click advanced.
Click the Phone tab.
Find the first line to configure (line 4 in this example):
a. From the Extension drop down list, choose Disabled.
b. From the Share Call Appearance drop-down list, choose private.
c. Enter the following string in the Extended Function field:
fnc=blf+cp;sub=Patrick@$PROXY;ext=300@$PROXY
Using the following syntax:
fnc=type;sub=stationname@$PROXY;ext=extension#@$PROXY
where:
- fnc: function
- blf: busy lamp field
- cp: call pickup
- sub: station name
- ext: extension
Click Submit All Changes. After the phone reboots, the SPA962 (in this example)
should show the following color LEDs for the monitored lines:
• Green: Available
• Red: Busy
• Red Fast Blink: Ringing
If the phone LEDs display orange or slow blinking orange, there is a problem:
Orange denotes that the phone failed to subscribe (received 4xx response) and
slow blinking orange denotes an undefined problem (there may be no response to
subscribe, or BLF).
MfG :-)
