Configuring a trial installation
Can I have a trial with this software without having PRI lines? I have simple data card (A simple GSM modem) which is used to connect internet and also it supports for making calls through it. Is it possible to implement trail connection using that modem?
What are the minimum requirements for establishing a trial connection (with single connection or multiple connections)?
If yes, how can i configure it?
Please anyone help me
uvitas
