Fehler beim Anrufen (trunk Fail)
mp-
17. Januar 2022
Was kann das für ein Problem sein?
Zielrufnummer durch "xxx" ersetzt.
13.09.2022 11:37:10 - Currently active calls [none]
13.09.2022 11:37:05 - Leg L:2277.1[Extn:23] is terminated: Cause: BYE from PBX
13.09.2022 11:37:05 - Terminated from "Julian Patzak"<sip:[email protected]:5062>;tag=HAJQc0cBPpKw1AMpUnn3VjeQqIv2YsUf to <sip:[email protected]:5062;tag3cx=olvgtohd>;tag=95837237; reason: Rejected
13.09.2022 11:37:05 - L:2277.1[Extn:23] Sending: OnSendResp Send 480/INVITE from 0.0.0.0:0 tid=PjwyqekHOUmNjjXE4wWPi506QrJVVQOM2u Call-ID=NNeLCe2jjt09gMgFQ1k10hhEKoR4J.kL: SIP/2.0 480 Temporarily Unavailable Via: SIP/2.0/UDP 127.0.0.1:5080;branch=z9hG4bK-524287-2---PjwyqekHOUmNjjXE4wWPi506QrJVVQOM2u;rport=5080 Via: SIP/2.0/UDP [::ffff:80.187.83.152]:24551;branch=z9hG4bK-524287-1---tunneltid;rport;tnlid=clnt.0-3mytg72sdt9pfljrdevj8n.8ewoeafwm_12137902 Via: SIP/2.0/TCP 127.0.0.1:50195;rport;branch=z9hG4bKPjwyqekHOUmNjjXE4wWPi506QrJVVQOM2u;alias To: <sip:[email protected]:5062;tag3cx=olvgtohd>;tag=95837237 From: "Julian Patzak"<sip:[email protected]:5062>;tag=HAJQc0cBPpKw1AMpUnn3VjeQqIv2YsUf Call-ID: NNeLCe2jjt09gMgFQ1k10hhEKoR4J.kL CSeq: 3823 INVITE Warning: 499 raspberrypi "Not available" Content-Length: 0
13.09.2022 11:37:05 - SendMsg from <sip:[email protected]:5062;tag3cx=olvgtohd>;tag=95837237 to "Julian Patzak"<sip:[email protected]:5062>;tag=HAJQc0cBPpKw1AMpUnn3VjeQqIv2YsUf
13.09.2022 11:37:05 - Call(C:2277) is terminated
13.09.2022 11:37:05 - [CM503020]: Call(C:2277): Normal call termination. Call originator: Extn:23. Reason: Not available
13.09.2022 11:37:05 - [CM503016]: Call(C:2277): Attempt to reach <sip:[email protected]:5062> from Extn:23 has failed. Reason: Temporarily Unavailable
13.09.2022 11:37:05 - [Flow] Current call diversion path:[]
13.09.2022 11:37:05 - L:2277.1[Extn:23] failed to reach Out#:>>Rule{out-al}>>xxx, reason Temporarily Unavailable
13.09.2022 11:37:05 - RerouteReq
13.09.2022 11:37:05 - [CM503016]: Call(C:2277): Attempt to reach <sip:@megaphon-gmbh.on3cx.de:5062> from Extn:23 has failed. Reason: Temporarily Unavailablexxx
13.09.2022 11:37:05 - ~Target=UnknownTrunk:8
13.09.2022 11:37:05 - [CM503026]: Call(C:2277): Route 1 to UnknownTrunk:8 is not active (Busy/Not registered)
13.09.2022 11:37:05 - [CM303003]: There are no available outbound lines on gateway MEGAphon GmbH 08 at this time. First line: Lc:10000(@MEGAphon GmbH 08[<sip:[email protected]:0/TCP>])
13.09.2022 11:37:05 - External line Lc:10000(@MEGAphon GmbH 08[<sip:[email protected]:0/TCP>]) is not registered!
13.09.2022 11:37:05 - Line limit check: Current # of calls for line Lc:10000(@MEGAphon GmbH 08[<sip:[email protected]:0/TCP>]) is 0; limit is 2
13.09.2022 11:37:05 - Call(C:2277): Call from Extn:23 to xxx matches outbound rule 'out-al'
13.09.2022 11:37:05 - [Flow] Call(C:2277): has built target endpoint: Out#:>>Rule{out-al}>>xxx for call from L:2277.1[Extn:23]
13.09.2022 11:37:05 - [Flow] Target endpoint for xxx is Out#:>>Rule{out-al}>>xxx
13.09.2022 11:37:05 - Selected prefix: 0
13.09.2022 11:37:05 - Looking for outbound rule: dialed = [xxx], processed: [xxx]; from-ext:
13.09.2022 11:37:05 - [Flow] Building target endpoint to xxx from "Julian Patzak" <sip:[email protected]:5062>
13.09.2022 11:37:05 - [CM503010]: Call(C:2277): Making route(s) from Extn:23 to <sip:[email protected]:5062/UDP>
13.09.2022 11:37:05 - Remote SDP is set for leg L:2277.1[Extn:23]
13.09.2022 11:37:05 - [CM505001]: Endpoint Extn:23: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone for iOS 18.0.8.293] PBX contact: [sip:[email protected]:5062]
13.09.2022 11:37:05 - Inbound DID: ''; Phonebook Name: ''
13.09.2022 11:37:05 - [CM500002]: Call(C:2277): Info on incoming INVITE from Extn:23: Invite-IN Recv Req INVITE from 127.0.0.1:5080 tid=PjwyqekHOUmNjjXE4wWPi506QrJVVQOM2u Call-ID=NNeLCe2jjt09gMgFQ1k10hhEKoR4J.kL: INVITE sip:[email protected]:5062;transport=UDP;tag3cx=olvgtohd SIP/2.0 Via: SIP/2.0/UDP 127.0.0.1:5080;branch=z9hG4bK-524287-2---PjwyqekHOUmNjjXE4wWPi506QrJVVQOM2u;rport=5080 Via: SIP/2.0/UDP [::ffff:80.187.83.152]:24551;branch=z9hG4bK-524287-1---tunneltid;rport;tnlid=clnt.0-3mytg72sdt9pfljrdevj8n.8ewoeafwm_12137902 Via: SIP/2.0/TCP 127.0.0.1:50195;rport;branch=z9hG4bKPjwyqekHOUmNjjXE4wWPi506QrJVVQOM2u;alias Max-Forwards: 69 Record-Route: <sip:[email protected]:5080;user=proxy;uri=clnt.0-3mytg72sdt9pfljrdevj8n.8ewoeafwm_12137902> Contact: "Julian Patzak" <sip:[email protected]:5060;rinstance=0-3mytg72sdt9pfljrdevj8n.8ewoeafwm> To: <sip:[email protected]:5062;tag3cx=olvgtohd> From: "Julian Patzak"<sip:[email protected]:5062>;tag=HAJQc0cBPpKw1AMpUnn3VjeQqIv2YsUf Call-ID: NNeLCe2jjt09gMgFQ1k10hhEKoR4J.kL CSeq: 3823 INVITE Session-Expires: 1800 Min-SE: 90 Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, INFO, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS Content-Type: application/sdp Proxy-Authorization: Digest username="90fu8Csggy",realm="3CXPhoneSystem",nonce="414d535963204f4036:4f01fe3de6bbcf24015f1eded98d03c2",uri="sip:[email protected]:5062;tag3cx=olvgtohd",response="4a7c24f649d164633f60010c21855e4c",algorithm=MD5 Supported: replaces, 100rel, timer, norefersub User-Agent: 3CXPhone for iOS 18.0.8.293 Content-Length: 435 v=0 o=- 3872050624 3872050624 IN IP4 192.0.0.1 s=pjmedia b=AS:117 t=0 0 a=X-nat:0 m=audio 10000 RTP/AVP 8 18 9 0 125 101 c=IN IP4 192.0.0.1 b=TIAS:96000 b=AS:117 a=rtcp:10001 a=sendrecv a=rtpmap:8 PCMA/8000 a=rtpmap:18 G729/8000 a=rtpmap:9 G722/8000 a=rtpmap:0 PCMU/8000 a=rtpmap:125 opus/48000/2 a=fmtp:125 useinbandfec=1 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 m=video 0 RTP/AVP 31 c=IN IP4 127.0.0.1
13.09.2022 11:37:05 - [CM503001]: Call(C:2277): Incoming call from Extn:23 to <sip:[email protected]:5062>
13.09.2022 11:37:05 - Dev(1615738482):[sip:[email protected]:5060;rinstance=0-3mytg72sdt9pfljrdevj8n.8ewoeafwm / 23] has updated source address: 127.0.0.1:5080/UDP fk=16 tgt=
13.09.2022 11:37:05 - Updating device Dev(1615738482):[sip:[email protected]:5060;rinstance=0-3mytg72sdt9pfljrdevj8n.8ewoeafwm / 23] by message: DevUpd Recv Req INVITE from 127.0.0.1:5080 tid=PjwyqekHOUmNjjXE4wWPi506QrJVVQOM2u Call-ID=NNeLCe2jjt09gMgFQ1k10hhEKoR4J.kL: INVITE sip:[email protected]:5062;transport=UDP;tag3cx=olvgtohd SIP/2.0 Via: SIP/2.0/UDP 127.0.0.1:5080;branch=z9hG4bK-524287-2---PjwyqekHOUmNjjXE4wWPi506QrJVVQOM2u;rport=5080 Via: SIP/2.0/UDP [::ffff:80.187.83.152]:24551;branch=z9hG4bK-524287-1---tunneltid;rport;tnlid=clnt.0-3mytg72sdt9pfljrdevj8n.8ewoeafwm_12137902 Via: SIP/2.0/TCP 127.0.0.1:50195;rport;branch=z9hG4bKPjwyqekHOUmNjjXE4wWPi506QrJVVQOM2u;alias Max-Forwards: 69 Record-Route: <sip:[email protected]:5080;user=proxy;uri=clnt.0-3mytg72sdt9pfljrdevj8n.8ewoeafwm_12137902> Contact: "Julian Patzak" <sip:[email protected]:5060;rinstance=0-3mytg72sdt9pfljrdevj8n.8ewoeafwm> To: <sip:[email protected]:5062;tag3cx=olvgtohd> From: "Julian Patzak"<sip:[email protected]:5062>;tag=HAJQc0cBPpKw1AMpUnn3VjeQqIv2YsUf Call-ID: NNeLCe2jjt09gMgFQ1k10hhEKoR4J.kL CSeq: 3823 INVITE Session-Expires: 1800 Min-SE: 90 Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, INFO, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS Content-Type: application/sdp Proxy-Authorization: Digest username="90fu8Csggy",realm="3CXPhoneSystem",nonce="414d535963204f4036:4f01fe3de6bbcf24015f1eded98d03c2",uri="sip:[email protected]:5062;tag3cx=olvgtohd",response="4a7c24f649d164633f60010c21855e4c",algorithm=MD5 Supported: replaces, 100rel, timer, norefersub User-Agent: 3CXPhone for iOS 18.0.8.293 Content-Length: 435 v=0 o=- 3872050624 3872050624 IN IP4 192.0.0.1 s=pjmedia b=AS:117 t=0 0 a=X-nat:0 m=audio 10000 RTP/AVP 8 18 9 0 125 101 c=IN IP4 192.0.0.1 b=TIAS:96000 b=AS:117 a=rtcp:10001 a=sendrecv a=rtpmap:8 PCMA/8000 a=rtpmap:18 G729/8000 a=rtpmap:9 G722/8000 a=rtpmap:0 PCMU/8000 a=rtpmap:125 opus/48000/2 a=fmtp:125 useinbandfec=1 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 m=video 0 RTP/AVP 31 c=IN IP4 127.0.0.1
13.09.2022 11:37:05 - IncomingCall: C:2277 from <sip:[email protected]:5062/UDP> to <sip:[email protected]:5062/UDP>
13.09.2022 11:37:05 - Added leg L:C:2277.1[No endpoint yet]
13.09.2022 11:37:05 - Call from "Julian Patzak"<sip:[email protected]:5062>;tag=HAJQc0cBPpKw1AMpUnn3VjeQqIv2YsUf to <sip:[email protected]:5062;tag3cx=olvgtohd>;tag=95837237
13.09.2022 11:37:03 - Updating device Dev(990823455):[sip:[email protected]:5060 / 42] by message: DevUpd Recv Req REGISTER from 192.168.1.19:5060 tid=1828776008 Call-ID=[email protected]: REGISTER sip:192.168.1.227:5062 SIP/2.0 Via: SIP/2.0/UDP 192.168.1.19:5060;branch=z9hG4bK1828776008;rport=5060 Max-Forwards: 70 Contact: <sip:[email protected]:5060>;reg-id=1;+sip.instance="<urn:uuid:00000000-0000-1000-8000-C074AD4E619F>" To: <sip:[email protected]:5062> From: <sip:[email protected]:5062>;tag=1135814040 Call-ID: [email protected] CSeq: 493945 REGISTER Expires: 120 Allow: INVITE, ACK, OPTIONS, CANCEL, BYE, SUBSCRIBE, NOTIFY, INFO, REFER, UPDATE Proxy-Authorization: Digest username="b3KK7F7ni2",realm="3CXPhoneSystem",nonce="414d535963204f3f11:40a4b8ddb97495d5aff879720db881e8",uri="sip:192.168.1.227:5062",response="a7c5eafaa96196bcea6d134378f6709e",algorithm=MD5 Supported: path User-Agent: Grandstream HT802 1.0.27.2 C074AD4E619F Content-Length: 0
13.09.2022 11:37:03 - Default best-route IP is determined as 192.168.1.227
13.09.2022 11:37:02 - Updating device Dev(983305754):[sip:[email protected]:5483;rinstance=18b207d334a0c9cb / SP4] by message: DevUpd Recv Req REGISTER from 127.0.0.1:5483 tid=9122f5623206c42d Call-ID=DnVDLJ9mgTAtPEEXfm76mA..: REGISTER sip:127.0.0.1:5062 SIP/2.0 Via: SIP/2.0/UDP 127.0.0.1:5483;branch=z9hG4bK-524287-1---9122f5623206c42d;rport=5483 Max-Forwards: 70 Contact: <sip:[email protected]:5483;rinstance=18b207d334a0c9cb> To: "SPSP4:"<sip:[email protected]:5062> From: "SPSP4:"<sip:[email protected]:5062>;tag=aa99a265 Call-ID: DnVDLJ9mgTAtPEEXfm76mA.. CSeq: 95056 REGISTER Expires: 300 Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE Proxy-Authorization: Digest username="SP4",realm="3CXPhoneSystem",nonce="414d535963204f3e36:a23bc2a7b8722ab10d1864bfc90d781f",uri="sip:127.0.0.1:5062",response="7896272d77871e93bf30f986df1aa8b2",algorithm=MD5 Supported: replaces User-Agent: 3CX Parking Orbit Content-Length: 0
13.09.2022 11:36:59 - Updating device Dev(920908909):[sip:[email protected]:5063;rinstance=4499d2130c39c7da / 25] by message: DevUpd Recv Req REGISTER from 127.0.0.1:5063 tid=c9be8966d690264f Call-ID=iNV_CWNHubPFBdE_6pTSaA..: REGISTER sip:127.0.0.1:5062 SIP/2.0 Via: SIP/2.0/UDP 127.0.0.1:5063;branch=z9hG4bK-524287-1---c9be8966d690264f;rport=5063 Max-Forwards: 70 Contact: <sip:[email protected]:5063;rinstance=4499d2130c39c7da> To: <sip:[email protected]:5062> From: <sip:[email protected]:5062>;tag=048ae810 Call-ID: iNV_CWNHubPFBdE_6pTSaA.. CSeq: 78 REGISTER Expires: 60 Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE Proxy-Authorization: Digest username="cmaow4UBcJ",realm="3CXPhoneSystem",nonce="414d535963204f3b21:01c3c9df115193862e2d33feb1e94df4",uri="sip:127.0.0.1:5062",response="4c2b84636cd76111f732448a27f1432f",algorithm=MD5 Supported: replaces User-Agent: 3CX WebRTC proxy Content-Length: 0
13.09.2022 11:36:55 - Timezone offset: 120 min.
13.09.2022 11:37:05 - Call from "Julian Patzak"<sip:[email protected]:5062>;tag=HAJQc0cBPpKw1AMpUnn3VjeQqIv2YsUf to <sip:@megaphon-gmbh.on3cx.de:5062;tag3cx=olvgtohd>;tag=95837237xxx
Das klingt für mich als wäre dein Trunk nicht registriert:
Es hat bis vor einer Stunde circa alles gespielt und das seit Monaten.
Der Fehler kam plötzlich und ist wenn wir jemand anrufen wollen.
Unsere Nummer ist eingehend auch nicht erreichnbar.
Wenn der Trunk nicht registriert ist geht natürlich weder aus noch eingehend. Was sagen denn die logs wenn du den trunk versuchst zu registrieren? Wo wird die 3cx denn betrieben?
Auf einem Raspberry Pi4.
  • Trunk L:10003(Fax 07) has changed status to unregistered. This means that no more calls will pass via this trunk. Please check your network connection and the voip provider or other SIP PBX
    SIP Server ID: 4100 13.09.2022 03:04:52
  • Call or Registration to MEGAphon GmbH 08 has failed. sip:[email protected];transport=TCP replied: 403 Forbidden; from IP:217.0.146.133:5060
    SIP Server ID: 12294 13.09.2022 03:04:52
  • Trunk L:10000(MEGAphon GmbH 08) has changed status to unregistered. This means that no more calls will pass via this trunk. Please check your network connection and the voip provider or other SIP PBX
  • Call or Registration to Privat 06 has failed. sip:[email protected];transport=TCP replied: 403 Forbidden; from IP:217.0.146.133:5060
  • Trunk L:10001(Privat 06) has changed status to unregistered. This means that no more calls will pass via this trunk. Please check your network connection and the voip provider or other SIP PBX
  • Call or Registration to viwefo 446 has failed. sip:[email protected];transport=TCP replied: 403 Forbidden; from IP:217.0.146.133:5060
  • Trunk L:10002(viwefo 446) has changed status to unregistered. This means that no more calls will pass via this trunk. Please check your network connection and the voip provider or other SIP PBX
  • 3CX logs and temporary files were deleted to conserve disk space.
    Event Notification Manager ID: 10025 13.09.2022 00:00:15
  • Your public IP has changed and 3CX updated your FQDN records from 93.228.226.209 to 93.228.228.218.
    3CX System Service ID: 10026 12.09.2022 03:05:11
    Event Notification Manager ID: 10025 12.09.2022 00:00:04
  • Trunk L:10002(viwefo 446) has changed status to registered.
    SIP Server ID: 4100 11.09.2022 03:06:49
  • Trunk L:10003(Fax 07) has changed status to registered.
  • Trunk L:10000(MEGAphon GmbH 08) has changed status to registered.
  • Trunk L:10001(Privat 06) has changed status to registered.
  • Your public IP has changed and 3CX updated your FQDN records from 84.184.147.165 to 93.228.226.209.
    3CX System Service ID: 10026 11.09.2022 03:05:09
  • Registration at viwefo 446 has failed. Destination (sip:217.0.146.133:5060;transport=TCP;lr) is not reachable, DNS error resolving FQDN, or service is not available.
    SIP Server ID: 12293 11.09.2022 03:04:48
    SIP Server ID: 4100 11.09.2022 03:04:48
  • Registration at Fax 07 has failed. Destination (sip:217.0.146.133:5060;transport=TCP;lr) is not reachable, DNS error resolving FQDN, or service is not available.
  • Registration at MEGAphon GmbH 08 has failed. Destination (sip:217.0.146.133:5060;transport=TCP;lr) is not reachable, DNS error resolving FQDN, or service is not available.
  • Registration at Privat 06 has failed. Destination (sip:217.0.146.133:5060;transport=TCP;lr) is not reachable, DNS error resolving FQDN, or service is not available.
Dein Registrar ist nicht auflösbar... Welchen DNS Server nutzt du? Was ist vor der 3CX? Firewallcheck ok? Ausgehende Regeln korrekt?
michael.wollert@boeppleba
