30.09.2022 16:23:55 - Leg L:51.2[Ivr:80] is terminated: Cause: BYE from local
30.09.2022 16:23:55 - [CM503008]: Call(C:51): Call is terminated
30.09.2022 16:23:55 - Leg L:51.1[Line:10001<<000000000000] is terminated: Cause: BYE from 192.168.xxx.x:5060
30.09.2022 16:23:49 - Currently active calls - 1: [51]
30.09.2022 16:23:39 - [CM503007]: Call(C:51): Line:10001<<000000000000 has joined, contact <sip:[email protected]:0/UDP>
30.09.2022 16:23:39 - [CM503007]: Call(C:51): Ivr:80 has joined, contact <sip:[email protected]:5483/UDP>
30.09.2022 16:23:39 - L:51.2[Ivr:80] has joined to L:51.1[Line:10001<<000000000000]
30.09.2022 16:23:39 - [CM505001]: Endpoint Ivr:80: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX IVR] PBX contact: [sip:[email protected]:5060]
30.09.2022 16:23:39 - [CM503002]: Call(C:51): Alerting Ivr:80 by contact <sip:[email protected]:5483/UDP>
30.09.2022 16:23:39 - [CM503025]: Call(C:51): Calling T:Ivr:80@[Dev:sip:[email protected]:5483;rinstance=1188e972e2506c52] for L:51.1[Line:10001<<000000000000]
30.09.2022 16:23:39 - [CM503027]: Call(C:51): From: Line:10001<<000000000000 ("000000000000" <sip:[email protected]:5060>) to T:Ivr:80@[Dev:sip:[email protected]:5483;rinstance=1188e972e2506c52]
30.09.2022 16:23:38 - [CM503004]: Call(C:51): Route 1: from L:51.1[Line:10001<<000000000000] to T:Ivr:80@[Dev:sip:[email protected]:5483;rinstance=1188e972e2506c52]
30.09.2022 16:23:38 - [Flow] Call(C:51): has built target endpoint: Ivr:80 for call from L:51.1[Line:10001<<000000000000]
30.09.2022 16:23:38 - [Flow] Target endpoint for 80 is Ivr:80
30.09.2022 16:23:38 - [CM503010]: Call(C:51): Making route(s) from Line:10001<<000000000000 to <sip:[email protected]:5060/UDP>
30.09.2022 16:23:38 - [CM505003]: Provider:[Generic SIP Trunk] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [AVM FRITZ!Box 7490 113.07.29 (Oct 26 2021)] PBX contact: [sip:[email protected]:5060]
30.09.2022 16:23:38 - [CM500002]: Call(C:51): Info on incoming INVITE from Line:10001<<000000000000:
Invite-IN Recv Req INVITE from 192.168.xxx.x:5060 tid=062BD48AB62F26CD [email protected]:
INVITE sip:[email protected]:5060;rinstance=109e2c5dfe19ce61 SIP/2.0
Via: SIP/2.0/UDP 192.168.xxx.x:5060;branch=z9hG4bK062BD48AB62F26CD
Max-Forwards: 70
Contact: <sip:[email protected]>
To: "017600000000" <sip:[email protected]:5060;rinstance=109e2c5dfe19ce61>
From: "HH pri" <sip:[email protected]>;tag=BC723DFFD648E3A9
Call-ID: [email protected]
CSeq: 67 INVITE
Expires: 120
Session-Expires: 600;refresher=uac
Min-SE: 90
Accept: application/sdp, multipart/mixed
Accept-Encoding: identity
Allow: INVITE, ACK, OPTIONS, CANCEL, BYE, UPDATE, PRACK, INFO, SUBSCRIBE, NOTIFY, REFER, MESSAGE, PUBLISH
Content-Type: application/sdp
Supported: 100rel, replaces, timer
User-Agent: AVM FRITZ!Box 7490 113.07.29 (Oct 26 2021)
Allow-Events: telephone-event, refer
P-Called-Party-ID: <sip:[email protected]>
Content-Length: 361
v=0
o=user 16554357 16554357 IN IP4 192.168.xxx.x
s=call
c=IN IP4 192.168.xxx.x
t=0 0
m=audio 7078 RTP/AVP 8 0 2 102 100 99 97 101
a=sendrecv
a=rtpmap:2 G726-32/8000
a=rtpmap:102 G726-32/8000
a=rtpmap:100 G726-40/8000
a=rtpmap:99 G726-24/8000
a=rtpmap:97 iLBC/8000
a=fmtp:97 mode=30
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=rtcp:7079
30.09.2022 16:23:38 - [CM503001]: Call(C:51): Incoming call from Line:10001<<000000000000 to <sip:[email protected]:5060>
30.09.2022 16:23:38 - Line limit check: Current # of calls for line Lc:10001(@Generic SIP Trunk[<sip:[email protected]:0/UDP>]) is 1; limit is 1
30.09.2022 16:23:38 - [CM503012]: Inbound office hours rule (unnamed) for 10001 forwards to DN:80
30.09.2022 16:23:38 - [Flow] No office hours set, office hours assumed
30.09.2022 16:23:38 - [Flow] Looking for inbound target: called=MobilSim; caller="000000000000" <sip:000000000000@:0>
