Exchange-Kontakte für 3CX
mgb
10. Februar 2021
guten morgen zusammen
ich versuche kontakte aus einem öffentlichen ordner zu synchronisieren.
vor der umstellung auf 3cx hosted hat es noch funktioniert.
nun habe ich diese log einträge:
2022/12/14 07:42:27.387|12764|0052|Erro|Error while checking contacts from Public Folder Allgemein/Alle Adressen
2022/12/14 07:42:27.388|12764|0052|Excpt|Microsoft.Exchange.WebServices.Data.ServiceRequestException: The request failed. The remote server returned an error: (401) .
---> System.Net.WebException: The remote server returned an error: (401) .
at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult)
at System.Net.WebRequest.<>c.<GetResponseAsync>b__68_2(IAsyncResult iar)
at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization)
--- End of stack trace from previous location ---
at Microsoft.Exchange.WebServices.Data.EwsHttpWebRequest.Microsoft.Exchange.WebServices.Data.IEwsHttpWebRequest.GetResponse()
at Microsoft.Exchange.WebServices.Data.ServiceRequestBase.GetEwsHttpWebResponse(IEwsHttpWebRequest request)
--- End of inner exception stack trace ---
at Microsoft.Exchange.WebServices.Data.ServiceRequestBase.ValidateAndEmitRequest()
at Microsoft.Exchange.WebServices.Data.SimpleServiceRequestBase.InternalExecuteAsync()
at Microsoft.Exchange.WebServices.Data.MultiResponseServiceRequest`1.ExecuteAsync()
at Microsoft.Exchange.WebServices.Data.ExchangeService.FindFolders(FolderId parentFolderId, FolderView view)
at Integration.Exchange.Contacts.PublicFolderExtensions.GetTopLevelFolder(ExchangeService service, String folderName)
at Integration.Exchange.Contacts.PublicFolderExtensions.GetPublicFolderByPath(ExchangeService service, String ewsFolderPath)
at Integration.Exchange.Contacts.PublicFolderExtensions.GetContactsFromPublicFolder(ExchangeService service, Int32 id, String PublicFolder, String ConvertPlusTo)
at Integration.Exchange.SchedulerJob.SynchronizePublicFolderContacts(String FolderName)
hat jemand eine idee was das problem sein könnte?
das kennwort und den username habe ich überprüft dass ist korrekt XD
liebe grüsse
mgb
Ist die entsprechende Schnittstelle des Exchange auch extern erreichbar? Ich hoffe der Exchange ist entsprechend aktuell und abgesichert um das nach außen zu veröffentlichen...
es handelt sich um ein o365 exchange.
also ja, er ist erreichbar..
Hi @mgb,
die Ausnahme/Exception bekommst du von deinem Exchange und nicht von der 3cx Anlage.
Wie sieht dein Link aus:
  • Exchange Server URL - Full path with FQDN to OWA (Outlook Web Access), e.g.
    /owa
  • Insert the impersonated account details in the “Impersonated User Account” and “User Account Password” fields.
Werden Kontakte im Ordner "Alle Adressen" gepflegt?
guten morgen @avraammich_3CX
besten dank für deine antwort.
ich habe mitlerweile alles auf O365 umgebaut, nun wird es so synchronisiert.
gruss
Reaktionen: avraammich_3CX
michael.wollert@boeppleba
